Question about GE Refrigerators
Not cooling, unpluged for few hours, it worked fro couple of weeks, stopped cooling again 2 days ago, I unplugged for few hours, It is working now
Fridge stopped cooling, I unplugged and cleaned the back, plugged it in, it worked for almost 3 weeks. It stopped cooling again 2 days ago. I unplugged for few hours, plugged it in again and it is working. What is the problem? How much would it cost to fix?
  • GE Master
  • 3,361 Answers
Your defrost system is bad. Replace the defrost thermostat and defrost heater in the freezer.
Posted on May 26, 2009
Intermittently starts beeping 3 times and some time later (hours to days) stops cooling. Works again, for a week or so, after unplugging for 10 minutes or so
Hi, your suggestion is good. Also consider an overbuild up of frost which the autodefrost can't cope with. I don't know what to suggest you do about it apart from minimising the moisture content of the food that you put into it.
Just seen your post regarding replacing the control unit yourself. I think that it's feasible if you have a reasonable amount of experience. However, the final decision is yours, I cannot suggest that this is something that you should do.
Jun 29, 2015 | Frigidaire Pro PHS69EJSS Stainless Steel...
Model FRT045GB
Good Morning Jr. Riojas,
I see that you are having trouble with your Frigidaire compact refrigerator, model# FRT045GB, and it not cooling. I also see that you have reset your refrigerator, by unplugging it, and it works fine for two weeks, then you have to repeat resetting it. I suggest contacting either the manufacturer or your local authorized technician for further assistance. They should be able to better assist as to why your refrigerator cools for a few weeks and then you have to unplug it for it to cool a couple more. Hope this is helpful.
-Best Regards-
WP
Apr 23, 2014 | Frigidaire 4.4 Cu. Ft. Compact...
Hello, my frig gets real cold but one day compressor stopped frozen stuff started melting. unplug plugged in few hours later it works for a week off again cycle continues for a few weeks. I replaced the...
0ba250e7-c31b-40ec-b003-ff0da31d62e4.jpgThis could be caused by a couple of things. If the condenser fan is defective and stopping while you don't see the fan stop it will cause the compressor to overheat and stop. The other possibility is a defective=> 12784415 Main Control Board or JAZZ Board A defective relay on this board will cause the same symptoms, Sea Breeze
I am here if you have questions...JT
Sep 21, 2013 | Maytag Refrigerators
My wii will not turn on
Unplug it for a few hours to a day or so, mine did that but afteer i unplugged it then plugged it in a day later it worked again.
Jan 28, 2012 | Nintendo Wii Console
I bought the amp a few weeks ago and it worked perfectly for a couple of days and then for some reason the controlls just froze. the tap tempo light went out and the channel control light stayed the same...
Exercise your warranty IMMEDIATELY since you just bought it! If you bought this used, you LIKELY bought someone else's problem. The problem is likely in the digital effects area... probably a bad cable contact... but if under warranty DO NOT mess with it... return it for replacement or repair.
Sep 09, 2011 | Marshall Amplification Marshall MG30FX...
My Magic Chef refrigerator has stopped cooling. When I unplug it for a few days, and then plug it in, it will work for about a week, and then quit cooling again. The freezer is perfect, and continues to...
The most likely cause is that the defrost system is not working. After about a week it builds up with enough frost to stop the cold air from getting to the refrigerator section. The most common problem is the defrost timer, defrost heater or defrost thermostat.
Aug 26, 2009 | Magic Chef CTB1502AR Top Freezer...
Freezer works frige dont unplug for an hour then it works .
I would suggest check the coils to make sure they are clean . Also check the fan which cools the compressor to make sure it is working . When you unplug , it gives the compressor time to cool down a bit , but after it restarts , it will get hot again and stop cooling .
Jul 06, 2009 | Refrigerators
GE Profile Artica Refrigerator
OK, it sounds like you have a defrost problem. When left unplugged for a few days the frost melted off the evaporator (the cooling coils behind the freezer wall) but after you ran it again, the coils blocked the air flow again, usually happens after a week or so, depending on # of door openings, humidity in home, etc. Most likely you have a burnt out defrost heater.
Aug 27, 2008 | GE Profile Arctica Stainless Steel Top...
Refrigerator buzzing for 10 seconds every 4 or 5 minutes
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
Apr 20, 2008 | Refrigerators
Refrigerators Logo
802 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
