Question about GE JRP15 Electric Single Oven
GE lower oven displaying code F8. Clear off does not clear code
Full ode shows F8 FAU LE, model JKP76GP/ JKP77WP
  • GE Master
  • 3,361 Answers
Your ERC(clock) has failed. Replace the electronic oven control.
Posted on May 26, 2009
Frigidaire Gallery series model GLEB30T8CBA key pad not working
Hello Dana, thank you for your post!
From my understanding your Frigidaire oven is displaying an error code of "F8" and your keypad is not working properly. An "F8" error stands for runaway temperature (overheating). I would recommend performing a reset on your oven and you can do that by disconnecting the power cord for at least ten minutes.
If that does not help correct your issue then you could have a problem with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would suggest having a professional technician out to perform a proper diagnosis and repair. I hope this information is helpful. -Matt
Jan 10, 2016 | Frigidaire 30 in. Electric Gallery Series...
How do I clear an error code FO on my GE oven
it usually means the touch pad or the oven control is defective.
Dec 05, 2015 | GE Ovens
How do I fix my GE True temp oven which shows F7 on the display?
https://www.youtube.com/watch?v=Rg7Dp4LBxtA
it seems its the connections ribbons on the control panel is wrong
will give you a clue look down the replys to the video to get more info
some very carefull cleaning is needed inside the front panel rework some connections
i use deoxit 5 and a rag
spray the deoxit to a rag then wipe the connection ribbons
then dowse the plugs with the deoxite
wait a while and re plug then carefully
should cure it
i would add a blob of grease to the sockets once its all running
to avoid further corrossion
hope this helps
Dec 11, 2014 | GE Ovens
Error f19
Error code F-19 means "Lower oven is not heating".
The manual suggests:
"Press UPPER CLEAR/OFF or
LOWER CLEAR/OFF to clear the display
and stop beeping. Reprogram oven. If fault
reoccurs, record fault number. Press UPPER
CLEAR/OFF or LOWER CLEAR/OFF and
contact a qualified service technician."
May 04, 2014 | LG LWD3081ST Electric Double Oven
Cant clear code or use oven after small power surge - stove top still works. GE web site does not have a F81 code they have an F8 and F1 which both say problem with keypad and electronic control needs to...
You didn't post model, but with a surge you probably looking at replacing the ERC. Does the manual say to unplug to reset, or check again on reset the control.
Some have this for reset, can't hurt to try.
  • Press the BAKEand BROIL HI/LO pads at the same time for 3-5 seconds until the display shows SF.
  • Press the COOKTIME and BROIL HI/LO button (on some models press Broil only, refer to your use and care manual). The display should show C. Press the button again until F shows in the display.
  • Press START to complete the change.
  • If this clears control, do it again to reset to Fahrenheit.
    This way actually resets for a error also besides temp.
    You can check the price of a control here,
    http://www.repairclinic.com/
    And you can google search for more places to shop prices.
    Mar 30, 2013 | Ovens
    What does F7 meanon my ge oven
    The F7 error code means that a button on the touch pad is bad,you can clear the error code by the pushing clear/cancel button if it doesn't reoccur all is well. If it returns (what i have heard from my customers is that it always reoccurs in the middle of the night when their fast asleep) the touch will need to be replaced
    I hope this helps ,if it does please give me a 4 thumbs up rating
    Gene
    Jul 30, 2011 | GE Ovens
    I had the oven on 350 for 45 min. baking potatoes and then the oven beeped twice and F1 showed up on the screen where it had said 350 so I turned the oven off and the time then showed on the screen. ...
    The manual says error code "F1" means a problem occurred in the circuitry and suggests pressing "CLEAR" to reset it. If the problem persists, contact a repair guy.
    See page 19: http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257104en.pdf
    "This oven is equipped with a state of the art electronic oven control. Among its many features is a full time oven circuit diagnostics system. The control constantly monitors its internal circuitry as well as several crucial oven circuits to insure they are all operating correctly. If at any time one of these systems fails, the control will immediately stop operation, and beep continuously (flashing an error code of F1, F3 or F9 in the display window, if equipped). Electronic control has detected a fault condition. Press CLEAR to clear the display and stop the beeping. Reprogram oven. If fault recurs, record fault number, press CLEAR and contact an authorized servicer."
    Mar 14, 2011 | Ovens
    Oven beeps and shows F7.
    These codes mean that the oven's electronic control has detected a condition it needs to check. When you see a code, follow these steps:
    • Press "Stop/Clear" to clear the display and stop the beeping.
    • Reprogram the oven.
    • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes before turning it back on
    thanks.
    Sep 29, 2010 | GE JGRP17 Gas Single Oven
    GE Profile oven beeps and displays FO
    Your electronic oven control(clock) is bad and must be replaced.
    Sep 02, 2009 | GE Ovens
    GE Oven MODEL J KP27WOP2 WG - WILL NOT HOLD TEMP
    You can re-calibrate the oven as follows;
    press BAKE pad.
    select temp of 500 degress or more.
    immediately PRESS and HOLD the BAKE pad until "00" appears.
    Then press the + or _ pad to adjust temp up or down 5 degrees at a time.
    When fimished press the Clear/Off pad.
    Mar 15, 2009 | GE JTP15 Electric Single Oven
    GE JRP15 Electric Single Oven Logo
    510 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
