Question about Amana SXD524VW Side by Side Refrigerator
Have Amana side-by-side about 14 yrs old. The icemaker overfills ice tray by about 8oz of water? Please help!
I have Amana side-by-side about 14 yrs old. The icemaker overfills ice tray by about 8oz of water? Please help!
  • Amana Master
  • 3,361 Answers
Unless someone has made a water level adjustment there is,
Only one repair. Replace the ice maker.
If someone has made a water level adjustment you can try this.
Remove the ice maker plastic cover. Locate the water level screw adjust it to a minimum setting and try it there.
If that does not correct the problem, replace the ice maker.
Posted on May 26, 2009
I have an Amana Side by Side Refrigerator with an icemaker and water dispenser. I don't have a water line to hook up to the refrigerator. Is there an on/off switch for the icemaker?
There should be a stop control near the icemaker where it collects ice in the tray. It should be an L-shaped lever. move it to the stop position.
Oct 02, 2012 | Amana Refrigerators
ICEMAKER OVER FILLS TRAY
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Nov 04, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker overfills and leaks into the ice bin.
I have had a similar problem several times. What I have found is that the ice tray coating has begun to flake off. Then, the ice sticks or partially dumps. Next more ice builds up and when the valve opens the water runs over the partially emptied tray and spills into the bin making "icebergs". The remedy is to replace the tray or if that is not possible, then, the whole icemaker. In fact, I have one down stairs to put in tomorrow. They don't seem to last more than about 4 years or so.
Jul 11, 2009 | Amana ARS266ZBS Side by Side Refrigerator
ICE DISPENSER
Dmuehr,
Are you sure it is a leak. Is the solenoid actually cutting off BEFORE the tray is full of water? If not, it is not a leak. The filling time for the icemaker water tray (where the ice freezes) varies depending on the local water pressure. With higher pressure, the tray may overfill. Your icemaker motor module timer may be set too long for your specific water pressure, so that the tray overfills. There is an adjustment on the module for shorter or longer fill time. You will need to remove the icemaker (3 screws probably) and reset the timer. It may take 2 or 3 tries to get it so the trays are about 80 to 90% full.
Jan 07, 2009 | Whirlpool GS6NBEXR Side by Side...
11 year old amana bottom freezer icemaker drips water when filling tray
as long as the temp in the frz is normal. the i/m could have a bad thermostat that, could be causing it cycling too soon or the tray is leaking water. either way i/m needs to be replaced, sorry
Sep 26, 2008 | Amana ABB1927DE Bottom Freezer...
KENMORE REFRIGERATOR 106.57024601
the problem is most likely the water valve behind the machine. it is closing too slow and letting too much water flow into the icemaker. c30b276.jpg
Jul 16, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Ice maker leaking water
replace the icemaker fill switch in the icemaker its self its a micro switch behind the gold panel on the front of the icemaker
May 03, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Ice Maker overflow
my icemaker overfill can you help
Oct 31, 2007 | Refrigerators
Water runs out of the water in the door when the ice maker fills
It is possible that your icemaker tray is overfilling and the excess water is running out of the ice chute. There is an adjustment screw on the icemaker head beneath the large white cover which can be adjusted to compensate for this. If not then the icemaker head may need to be changed to correct this.
Mar 09, 2007 | Amana SXD524VW Side by Side Refrigerator
Amana SXD524VW Side by Side Refrigerator Logo
491 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
