Question about Panasonic SC-HT895 System
Error F16 on my panasonic SA-Ht895 dvd player
My dvd player keeps saying F16 on the screen and wont turn on i have no idea what to do please help Sarah my panasonic dvd player is showing f16 error message and wount turn on
My Panasonic SA-HT895 DVD f 61
I would look at consulting the manual/operating instructions. If you do not have them, check the online version of this manual:
Panasonic SC HT895 Operating Instructions Manual
Best of luck!
Feb 14, 2016 | Panasonic Audio Players & Recorders
I have a SA-HT730. i get the F61 error code and then turns off. Please help
Check this site. It has details about the error codes to Panasonic HTs. http://electronicshelponline.blogspot.com/
Pull up previous posts, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option. Select view option by the drop-down view box, at the top left or the display window.
Aug 15, 2013 | Panasonic DVD-F61 Multi-disc DVD Player
Why my dvd players show error f 16.i aslo cant`t on my player and then the error dissappear.why?
Are you sure you are not getting a code F61? I don't see in the manual a code f-16. It's says to "When a unit displays F61 - check and correct the speaker cable connections, If this does not fix the problem then consult the dealer." That is strait out of the manual for your theater system. I have uploaded a couple of diagrams to aid you with double checking your wiring. Should this not work then you must contact your dealer.
Regards,
Tont
Apr 18, 2011 | Panasonic SC-HT895 System
Panasonic dvd player, wont play error code HO3 keeps coming up, took it back to shop they wont help as cant find receipt
On my DVD-LV50, I was able to re-initialize and fix a different error (error code H05). It might work for you, too.
With no disk in the player, press and hold these buttons for 4 seconds:
  1. Back skip -- [ |<< ]
  2. Pause -- [ || ]
  3. Play -- [ > ]
The screen will go blank, then say "Initialized."
After that, it worked like new.
I hope that helps.
Oct 17, 2008 | Panasonic DVD-LV50 Portable DVD Player...
PANASONIC SA-HT800V
servo problems will need to replace dvd board...is that cost effective ?..replacement price??
Jun 13, 2008 | Panasonic sa-ht800V Home Theater Audio...
Wont read disc-error message HO7
Please chande your dvd lense you can purchase it from the market please note the lense number and may be the mechanisum problem.
Jun 10, 2008 | Panasonic DVD-CP67 Multi-disc DVD Player
F16 error
constant f 16 shown on screen on my Panasonic mini hifi set what the problem.,
Jan 22, 2008 | Audio Players & Recorders
Panasonic SC-HT895 System Logo
266 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
