Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Screen flickering my screen right before it goes on a battery saving mode and the screen goes darker, it starts to flicker just like a candle about to go off, does anyone have any clue about this problem? I have a mackbook intel core 2 duo, 2.0 Ghz, 1Gb Ram
  • Apple Master
  • 4,338 Answers
Not sure if this is your issue, but when the brightness is on full with AC plugged in, the ambient light sensor isn't as sensitive. Unplugged, it is. The ambient light sensor judges the light in the room and responses by automatically adjusting the brightness. What you could be seeing is your shift in movement blocks/allows more light to the sensor (the camera at teh top) and thus adjusting your brightness. To disable system preferences> display> uncheck "automatically adjust brightness.
Also, it may be the LCD, If you are in warranty, bring it to your local Apple store for repair.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 31, 2009
I have the Amertac Westek/Amerelle 75206 LED Rechargeable Candle Kit, 6-Pack2 of the candles don't flicker their just on why is this when I was told their suppose to flicker?
Swap the candles around in the charger. The two in question may not be charging properly or their rechargeable batteries may be defective. Chargers of this type tend to be sensitive to incorrect installation of the candles. I have also found that the candles do not hold a charge very long.
Jun 28, 2014 | Westek Amertac 75206 LED Rechargeable...
I have this model N3735w Viewsonic LCD flatscreen TV and it is flickering. The screen is also getting darker.
Try turning off the automatic brightness feature . This mode adjusts the brightness according to the light level in the room.
Dec 26, 2013 | ViewSonic N3735W 37 in. LCD TV
Need some kind of flameless candles for dark, antique birdcage with very small opening in the back.
You can purchase battery-powered LED candles that flicker realistically. They are approximately the size of a tea candle
Sep 13, 2013 | Candle Impressions 16" Birdcage with...
Flickering screen. Picture is darker and the left side of the screen(when looking at screen) is weaker than the right side. Flickers for about 15 seconds then screen goes black
Ur LCD inverter board is dying.Must replaced this board,to get picture back good.Tries Shopjimmy.com,Ebay.com for the board.It a long board.
Jan 10, 2010 | Astar LTV-3001 Television
Monitor goes blank
Try restarting the computer in Safe Mode and then check. In case it flickers in Safe Mode too, then the LCD screen might be damaged and you might need to replace it.
Aug 08, 2009 | Dell Inspiron 1525 Notebook
Laptop screen flickers and goes off .
You could have a faulty inverter but
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 13, 2009 | Sony VAIO VGN-C140G/B Notebook
Wont turn on C-160, flicking screen
Dear emjay187,
i have the same camera and experiencing the same problem, it doesn't matter what batteries i put in (fully charged rechargables or dry cell AA) the low battery icon flashes then the screen flickers and goes off. i suspect it to be another onboard battery so i have found a small button 3v battery soldered to the main board. i have desoldered it and am now sourcing one so when i find it and try it i will contact you to confirm my results.
regards
Michael.
Nov 20, 2008 | Olympus Camedia C-160 Digital Camera
Dell Latitude cpx
Symptoms of a Bad Video Driver
Monitor Resolution issues:
screen flickers, screen is cloudy, screen shows horizontal lines, screen goes black, goes blank, goes into sleep mode, goes into power mode, size magnifies or reduces, video is jittery, fonts change, screensaver will not appear, cannot extend display on dual monitors.
Download it from here
VIDEO DRIVER FOR LATITUDE
May 28, 2008 | Dell Latitude CPX Notebook
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
145 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
