Question about Kenmore Elite 45986 Front Load Washer
Check Pump on front loader kenmore HE3 elite
How do i check the pump in an He3 elite front loader from kenmore The machine will fill and agatate but not drain or spin. F-19 error
  • Kenmore Master
  • 3,361 Answers
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
Posted on May 26, 2009
Water leaks into drum and machine intermittantly
The mixing value is leaking. I ordered a new one and will replace it.
Dec 20, 2009 | Kenmore Washing Machines
What is the most common reason for my washer to leak water
leaks are usualy from the drain or fill pipes, or door seal(front loaders), and lastly, the pump.
I recommend starting at the hoses, then check seal, then pump
Nov 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
How do you get to the drain filter on a kenmore elite he3 washer to clean it?
The following link explains how to access the drain pump on a Kenmore Elite HE3 front loader to clean the drain pump:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If you are experiencing drainage issues and cleaning the pump does not work, you may have to replace the drain pump. You will usually experience an "F2", "SUD" or "F21" error code (depending on model number) for a drain blockage problem. Since this error code occurs when the drain cycle exceeds 8 minutes, if the pump motor or impeller becomes damaged, the pump will not pump at the required volume and the error code will continue to occur. Replacement pumps can be purchased on line at:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop all of them for the best deal.
NOTE: Make sure you also check the drain hose and the inlet hose that runs from the bottom of the wash tub to the drain pump. Small articles of clothing can commonly get lodged in this area.
If you have any questions, please let me know. I hope this helps you.
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
I have kenmore elite he3 and it is flashing f 02 and then it will flash sud. Water will not all drain out of it,
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 27, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore elite dryer runs cold no heat
Most of the time its the thermal fuse part # 3390719
Jul 21, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 front loader keeps getting F02 error message, most often when I wash towels. I was able to workaround by pulling half the load, but that no longer does the trick.
Long Drain
F02
Potential Causes
Jul 13, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 front loader shows an error message of F02. It doesn't complete the rinse cycle as a result.
There is a trap on washer pump I just found to be full of the same **** you find in sink trapp. That is probably why I had same problem. could also be kinked hose or pump issue. The experts at fixya just walked me through it. best ten bucks i ever spent.
Good luck Scott
Apr 05, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 will not HOLD water, drips out into the pedestal
check to see if there are any rips in the door seal,then take the bottom of the washer off you will see 3 screws holding it on. see if the water is coming out of the pump that is right behind the panel that you took off.
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Front loader washer doesn't spin clothes as dry as before
The out-put pump is possible clogged up and not moving the water efficiently, also check the pully belt is tight
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 washer keeps filling with water
The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
956 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
