Question about Tomtom ONE XL GPS
Tomtom option problem
The extra selection option is not showing on my tomtom screen
  • 515 Answers
Tap screen -> Change Preferences -> Arrow to page 3 of 3
Tap Show ALL menu options.
Posted on May 27, 2009
Unit is one year old. Worked fine this morning, got back into car and GPS asking set-up questions but a the time prompt it flashes off and starts the set up over againi with language prompt. Keeps...
try this originally posted by gt3rs i just did it and it worked for me Here is a solution that worked in my case (constant reboots after voice select)
  1. Plug your tomtom into your PC.
  2. Run TomTom Home
  3. Select the option to run your TomTom through your PC (TT Home)
  4. You should be greated with the select language screen
  5. Then simply select language etc.
  6. When you get to the voice selection: select a voice (here TTHome should freeze) <- also strangely enough notice the cancel button doesn't on the screen (as it does when doing this on the device)
  7. Don't panic TT Home should start working again in a few seconds
  8. Disconnect your TomTom and that should have solved the problem, the normal map screen should show up upon starting up your TomTom
This solved the issue for me, hope it does for you good luck!
May 10, 2011 | Tomtom One XL GPS Receiver
GPS unit is stuck on the main screen, and wont turn off
This means it is not reading the SD card and that it needs to be re-formatted.
This is best done in a card reader and not the tomtom itself.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
Then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card
It should now work
Dec 20, 2009 | Tomtom ONE XL GPS
Last week I updated my TomTom One with the latest maps, etc. Since then whenever I use my TomTom it keeps displaying a "Shutting down in 10 seconds" screen, with follow up screens, and then it shuts down....
Make sure you have "never turn off screen" checked, To do this tap "change prferences" tap the forward arrow until you see "battery saving preferences". Tap "battery saving preferences" then tap "never turn screen off". Tap "done" and make sure that "switch off when external power is lost" is not checked. Tap "done". If you do not see this option go back into "change preferences" tap the forward arrow until you see "show menu options" it should read "show fewer munu options"
Sep 26, 2009 | Tomtom One XL GPS Receiver
Screen stuck on tom tom with red hands
Remove the SD card
The card needs to be formatted properly first that's all,
formatting is better done in a card reader.
It should now work
Sep 21, 2009 | Tomtom GO 300 GPS Receiver
Large white X in red circle flashing
This works for most tomtoms so there is nothing to loose and everything to gain
Remove the SD card
formatting is better done in a card reader.(opionions vary)
then just copy ALL the files from the tom tom to your sd card
It should now work
Aug 27, 2009 | Tomtom GO 930 GPS Receiver
!!!!! HELP !!!! BIG RED CROSS WHEN ENTER SD CARD
Hi there
This happens because files on your card are corrupted after an unsuccessful download.
If you have a card backup at hand, put the card into a computer, format it , and restore backup.
After that the TOMTOM will restart working normally.
If you did not make a copy or backup of the original card, or you cannot reach the computer hosting the last backup.Then follow the procedure below to restore your data :
1. Uninstall the application
2. Reinstall the application
attention_25.gif We highly recommend backing up your device before continuing. questionmark_25.gif
This will preserve any maps and voices you may have purchased.
1. Connect your device to your computer.
2. Go to Computer (Vista), My Computer (XP) or your Desktop (Mac).
3. Double-click the TomTom disk drive to open your TomTom.
4. Make sure that hidden folders and files are shown. To do this:
  • Vista: Go to Organize > Folder and Search Options, click on the View tab and select the option Show hidden files and folders.
  • XP: Tools > Folder Options..., click on the View tab and select the option Show hidden files and folders.
  • Mac: With the exception of some system files, your Mac should already show all hidden files and folders on the TomTom drive.
5. Identify the map folders on the TomTom. These are named for countries or regions such as USA_and_Canada, North_America or any other country or geographical region.
6. Delete all files EXCEPT these map folder(s) and the folder titled ASR, if it exists (the ASR folder will not appear on every device).
7. Properly disconnect the TomTom from the computer and exit TomTom HOME, if it is open.
  • Vista/XP: Right-click the TomTom drive and choose Eject.
  • Mac: Drag the TomTom drive to your Trash.
8. When the TomTom boots you should see a screen with the flashing X.
Proceed to reinstall the application (below):
Apr 26, 2009 | Tomtom GO 300 GPS Receiver
My screen goes dark when I use my navigator
change screen settings. here's how to; goto change pref, -safety pref- (ignore first screen)-done-- done--done--then it will come up with---turn off map display, select never option then done , you will also need to check to see if your screen saver option are set to slide show and turn these off as well.
Jan 05, 2009 | Tomtom GO 910 GPS Receiver
TomTom GO700
Hi there
Sep 09, 2008 | Tomtom GO 700 GPS Receiver
TomTom frozen
uninstall and then reinstall the app again:
www.tomtom.com/9091
Jun 29, 2008 | Tomtom ONE GPS Receiver
When turns on shows a computer screen and red cross
Hi there
Apr 20, 2008 | Tomtom ONE GPS Receiver
Tomtom ONE XL GPS Logo
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
