Question about Panasonic KX-TDA50 Phone
Problem with KXTDA50 CO 4 Connected to Gate entry system
CO 4 is connected to a Door King Gate Entry System operating in a CO mode. This has worked with no problem with other Panasonic KSU systems but with the TDA50, since there in no dial tone from the Gate Entry System, it generates a fast busy. Is there a programming option for the CO line for it to work without looking for the dial tone?
  • 3 more comments
  • flyairnick May 27, 2009
    Thanks for your help and shedding light...I am aware of talk batteries, and no, Door King does not provide that option so I'll use my own. I'm a little surprised by the seemingly backward step by Panasonic since the 816, 1232, 624 and 824 systems (as well as others) all work fine with the Door king on a CO port with no talk battery needed.
  • flyairnick May 30, 2009
    Thanks for your follow up...it was determined that the Door King was not putting out the talk voltage it is supposed to (I found out after the fact that this Door King was previously working fine with this system, that's what happens when you come into the middle of something and aren't given all the details) , anyway, the gate company is due to replace the Door King PC Board and it should be working again. My main experience has been wit Panasonic earlier models through the 824 as well as the hybrid 848 and none of them ever displayed the fast busy upon loss of dial tone or talk voltage, Thanks again for your diligence.
  • Carl Navarro
    Carl Navarro May 11, 2010
    How did you make out on your talk battery issue? In reading the material, I missed your Door King model number. Some of them are polarity sensitive, so you may have to make sure the RING side of the line has the negative voltage. I'm still not crazy about only 9 volts DC for TB, only because Panasonic may mark the trunk busy on such low voltage.
  • Carl Navarro
    It's not a step backward, it's just a trunk. A lot of systems time out if they don't get talk battery on trunks. It does tend to s u c k (just in case the filter works on that word), but we see it a lot in other systems. It's annoying when you try to do a poor man's paging on a trunk as you have to allow for it, but I think even the TD system requred battery to hold up a page.
  • Carl Navarro
    Ahhh, REST of the story. It's not the dial tone, it's the missing talk battery. Check your Door King installation manual and see if you can set a switch to provide battery.
    Believe it or not, Rube, a well regulated 9v DC supply in series with the door connections and the trunk MIGHT be enough to keep the connection up...24 volts will definitely work. Viking Electronics makes a C-1000 door controller, but it's not inexpensive (but less than the Door King system).
    carl
  • 28 Answers
You can increase the timer that the system checks for dial tone... but you BEST bet would be to put the doorking into Intercom mode
Posted on Jan 07, 2011
2002 pontiac bonneville door locks and interior lights doesnt works
This may be a bad rear integrated control module. or connection or wiring to it.
REAR INTEGRATION MODULE (RIM)
The CTD system is an internal function of the rear integration module (RIM) which utilizes class 2 serial data and various switch input information to perform CTD functions. When the RIM detects an unauthorized entry, the RIM sends a message via the serial data circuit to the DIM to activate the horns and exterior lamps. The RIM has 5 basic modes. Disarmed, standby, delayed, armed, and alarm for operating the CTD system. The 5 modes transition from one step to the next in the following order:
When in the disarmed mode, ignition is OFF and any door is open the RIM commands the instrument cluster to flash the SECURITY indicator via the class 2 serial data circuit. The RIM has the CTD system in a disarmed mode until the following conditions are detected:
Ignition key turned to the OFF position
Any door open
Doors locked by either the power door lock switch or the LOCK button on the keyless entry transmitter
The RIM enters the standby mode when the above conditions are detected. In standby mode the RIM commands the instrument cluster to illuminate the SECURITY indicator via the class 2 serial data circuit. If all the doors are closed and the LOCK button on the keyless entry transmitter is used, the RIM enters the delayed mode.
When the last door is closed, the RIM enters the delayed mode for 30 seconds . In delayed mode the RIM commands the instrument cluster to illuminate the SECURITY indicator on steady via the class 2 serial data circuit.
After 30 seconds , the RIM enters the armed mode. In armed mode the RIM commands the instrument cluster to turn off the SECURITY indicator via the class 2 serial data circuit. Any forced entry activates the alarm mode.
Jun 28, 2017 | Pontiac Cars & Trucks
I have a 2003 trailblazer and i bought a fob and it does not work after programing Everything thing works on my truck but the fob. Any ideas?
How was it programmed ? Was a scan tool used ?
Program All Key Fobs
To complete this programming operation, all keyless entry transmitters associated with the vehicle must be available for programming. Once placed into program mode, all previously programmed transmitters will be erased from memory upon the receipt of the programming signal from the first transmitter.
  1. Close the lift gate.
  2. Ignition ON, access the scan tool Lift gate Module Setup menu and select Program All Key Fobs.
  3. Follow the scan tool on screen instructions in order to program the transmitters. Select "Start" on the scan tool to enter the program mode.
  4. As each transmitter is successfully programmed, the scan tool will show how many transmitters have been placed into memory.
  5. When all transmitters are programmed, exit the program mode by selecting "Stop" on the scan tool. The vehicle will not respond to the transmitters until the program mode is exited.
  6. Operate the transmitter functions in order to verify correct system operation.
Program Individual Key Fob
If there are less than four keyless entry transmitters programmed to the vehicle, an individual fob transmitter can be added. This method will not erase previously programmed transmitters from memory.
  2. Ignition ON, access the scan tool Lift gate Module Setup menu and select Program Individual Key Fob.
  3. Select "Program additional Key Fob" on the scan tool.
  4. Follow the scan tool on screen instructions in order to program the transmitter.
  5. Operate the transmitter functions in order to verify correct system operation.
Apr 08, 2016 | Cars & Trucks
How do you reset the alarm system on a 98 olds silhouette after it triggers without the remote entry
Theft Deterrent Arm/Disarm Modes
Important: Although mode 2 provides increased security, the content theft deterrent system disarms only by pressing unlock on the keyless entry transmitter. This can pose a problem if the keyless entry transmitter is damaged, lost, or inoperative for any reason while you attempt to disarm the content theft deterrent system.
Mode 1: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter. The system does not arm when you lock the doors with a power door lock switch.
Mode 2: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the doors with the keyless entry transmitter. The system does not disarm when you unlock the doors with the key.
Mode 3: The system arms when you lock the doors using a power door lock switch or the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter.
Changing the Feature Customization Modes
  1. Turn off the IP dimmer switch.
  2. Turn the ignition switch to the LOCK position.
  3. Remove the BCM PRGRM fuse.
  4. Turn the ignition switch to the ACC position. The BCM flashes the fasten belts indicator and sounds the chime 4 times, which indicates that BCM type 4 is installed on the vehicle. At this point, the BCM has entered the feature customization mode.
  5. In order to change the theft deterrent/shock sensor mode, turn the headlamp switch from OFF to PARK and back to OFF.
  6. The BCM flashes the fasten belts indicator and sounds the chime a number of times equivalent to the theft deterrent/shock sensor mode. A transition past mode 4 repeats the sequence starting with mode 1.
  7. Complete the following steps in order to change the theft deterrent arm/disarm mode:
6.1.
Insert the key in the left front, right front, or liftgate door lock cylinder.
6.2.
Rotate the key from the center to the unlock position.
6.3.
Press the horn button on the remote keyless entry transmitter.
6.4.
Count the number of chimes that you hear. The number of chimes tells you which mode you have set.
6.5.
Press the horn button again in order to change the mode. Continue to press the button until you hear the number of chimes that indicates the mode that you want.
6.6.
Turn the key back to the center position and remove the key from the door key cylinder.
In order to exit and save the current feature customization modes use the following procedure:
  1. Turn the ignition switch to the LOCK position.
  2. Reinstall the BCM PRGRM fuse.
If you are unable to change locking modes Theft Deterrent System Feature Customization Inoperative
Aug 25, 2015 | Cars & Trucks
Doorlock operation won't work on new Avital 4103. Why? 1990Buick LeSabre
The door locks on the car are reverse polarity so u have to put realys in between the system and the door lock
Oct 21, 2012 | 4103LX 4Button Remote Start System with...
How to take automate car alarm off silent mode
{: ) When armed, the content theft deterrent (CTD) system is designed to deter vehicle content theft by pulsing the horns and exterior lamps for approximately 30 seconds when an unauthorized vehicle entry is detected.
An unauthorized entry can be any of the following with the CTD system armed:
• When any door is opened without first being unlocked using the keyless entry transmitter • After a battery reconnect, if the battery was disconnected with the CTD system armed
Disarming an Armed System/Silencing an Alarm
If system arming has been requested by the power door lock switch or the keyless entry transmitter, it must be disarmed.
Important: Using the power door unlock switch or manually unlocking the doors does not disable the content theft deterrent (CTD) arm mode. Also, disconnecting the battery or pulling fuses does not disable the arm mode, since the BCM stores the CTD mode status in memory.
• To disarm the CTD system in standby mode, perform one of the following: - Press the UNLOCK button on the keyless entry transmitter. - Insert a valid key into the ignition and switch to the ON position. • To disarm the CTD system in the armed mode (non-event) or when activated (during an alarm event): - Press the UNLOCK button on the keyless entry transmitter. - Insert a valid key into the ignition and switch to the ON position Locking the Vehicle Without Arming the CTD System Locking the vehicle may be accomplished without arming the content theft deterrent (CTD) system. Use of the manual door locks or using the key to lock the doors will lock the vehicle, but will not arm the CTD system.
Apr 23, 2011 | 2007 Chevrolet Tahoe
I have a 2004 GMC Envoy with 6 cyl engine. Both remote keyless entry went dead at same time and now I can't unlock the back hatch door. I had to release it manually but the sensor keeps locking it back....
Take it an have it check at a qualified repair shop for DTC'S - diagnostic trouble codes . Could have problem with the liftgate/endgate module. Don't try guessing to find a repair .
The keyless entry system has the following main components:
• The transmitters
• The endgate module (EGM) (XUV only)
• The liftgate module (LGM) (Except XUV)
When you press a button on a transmitter, the transmitter sends a signal to the liftgate module. The module interprets the signal and activates the requested function via a class 2 message over the serial data line.
Do you know what class 2 serial data communication network is ?
You need a scan tool to program the remotes .
Ignition ON, access the scan tool Liftgate Module Setup menu and select Program All Key Fobs.
Follow the the scan tool on screen instructions in order to program the transmitters. Select "Start" on the scan tool to enter the program mode.
012 GM Class II Communications
Jul 25, 2017 | GMC Envoy Cars & Trucks
2006 F-150 no manual.. does this model have a garage door opener built-in ?
It is not standard equipment.
Here is what the manual says (copied and pasted from owners manual)
HOMELINK WIRELESS CONTROL SYSTEM
(IF EQUIPPED )
The HomeLink Wireless Control
System, located on the driver's visor,
provides a convenient way to
replace up to three hand-held
transmitters with a single built-in
device. This feature will learn the
radio frequency codes of most
transmitters to operate garage
doors, entry gate operators, security systems, entry door locks, and
home or office lighting
Feb 27, 2011 | Ford F-150 Cars & Trucks
Just bought a new PD210DM opener but still have
I don't know this model. (in australia). the chamberlains here are probably the same. the 4 digit code you first put in the keypad is what you have to use. push the learn button on your operator then punch in your 4 digit No. Hold the enter button on your keypad until the light flashes on the operator.
That should code it in.
freddy51
Feb 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Keyless entry wont work 2002 chevy s10
The only way to program them is with a scan tool so you'll need to visit your local dealer to have it done. Here is how it is done.
  1. Install a scan tool.
  2. Use the scan tool in order to access programming: Vehicle Control System/Computer Integrating System/Module Setup/BCM/Program Key Fobs.
  3. Press the START soft key on the scan tool. Important: The scan tool must stay connected until all of the transmitters are programmed.
  4. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 5-10 seconds, the scan tool will indicate that the transmitter is programmed.
  5. Repeat the previous step in order to program up to 4 transmitters.
  6. Remove the scan tool.
  7. Operate the transmitter functions in order to verify correct system operation.
Sep 02, 2009 | 2002 Chevrolet S-10
Panasonic KX-TDA50 Phone Logo
293 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
