Question about GE Refrigerators
Refrigerator leaks underneath
Leakes small amount of water underneath occasionally.
  • 420 Answers
Check to make sure the drain pan under the fridge is not over filling, out of place or cracked. The water that collects there during defrost is evaporated by the condenser fan, if the fan is not running or it and the condenser coil are fouled with dust clean them and the issue should go away.
Posted on May 27, 2009
My dishwasher has leaked a smal amount of water from underneath
Jackie, It is probably a seal(gasket) leaking, you may want a service tech. to have a look.
Mar 09, 2016 | Hotpoint 24 in. FDW60 Free-standing...
Fix the leak in the small blue cap that feeds water to the refrigerator?
sounds like ur water inlet valve is bad or is it just a connector? see pics
Sep 13, 2014 | Kenmore Refrigerators
A/C unit in attic is leaking a substantial amount of water
It can be a low refrigerant(freon) issue,dirty coils,too slow fan motor.
Jul 16, 2010 | Heating & Cooling
A small amount of water is leaking out of the front of the refrigerator onto the floor every day and I can not fine the source of the water. Is there a drain pan and if so where is it? If it is not the...
older fridges drained water into a pan with the compressor in it, thus cooling the compressor and evaporating the water, this is located at the bottom back of the fridge. if this fridge has a water and/or ice dispensor, the water could be leaking from many a place.
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Once a day my frigidaire refrigerator pushes out a small amount of water from underneath but I cant fiqure out where its coming from
Check the collection pan for a leak. Sounds like the defrost cycle operates and the collector is leaking. Eric
Aug 10, 2009 | Frigidaire Refrigerators
Kenmore side by side - water dispenser leaks from time to time.
The problem is most likely at the water inlet valve located at the floor at the back of the refrigerator. These valves have a seal that should close off after use but sometimes stick or get a foreign object in the seat. It is intermittent causing only an occasional leak. Sadly, there is no service to the valve and you can only replace it. Good luck, AJ
May 22, 2009 | Frigidaire FRS6R5EMB Side by Side...
Water leaking from freezer
Check for a blocked defrost drain. Take the panel off at the back of the freezer section and find the small hole at the very bottom center below the cooling coils. Use hot (but not boiling) water and a turkey baster to flush it out until water runs through it. (it will go into the defrost drain pan, where it will evaporate)
This will prevent water from comming out the freezer door and leaking onto your floor and running down your copper pipe to the basement.
May 12, 2009 | Hotpoint HSS25GFP Side by Side...
Water leaking from bottom of unit
check to see if if drip pan leaking may be water line
Apr 07, 2009 | Magic Chef CTF1826AR Top Freezer...
Leakage of water from underneath when filling machine up
it's prabably your pump it has two metal strips that snap on from the motor to the pump un-snap them and undo your hoses and get yourself a new pump
Apr 03, 2009 | Washing Machines
Ice maker is leaking small amounts of water.
Is the amount of water to much for the tray size , you can adjust it with the small screw behind the icemaker cover . is the line entering the back of the icemaker jammed up to far causing it to spray ? Or is the icemaker or refrigerator not level
Nov 04, 2008 | Frigidaire FRS26ZSG
Refrigerators Logo
107 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
