Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Both Fridge and Freezer quit working properly at the same time.
I have a Whirlpool Refidgerator/Freezer. The were bought neww 3 years ago. Friday I got in the Freezer and my icecream was soft, I assumed the door was not closed tight ( I have kids. I made sure the door was closed and went to bed. Saturday the fridge was still working fine, icecream still soft. Sunday both fridge and freezer not working. The food is hot. There is a motor running, I pulled it out and cleaned everything real good, and turned temp to the coldest on both. What should I do?
  • bethturner_7 May 27, 2009
    The Model for my fridge is ED5VHGXMQ10.
  • Whirlpool Master
  • 4,654 Answers
I will need the model number as shown in photo below where the locations are most likely to be. While I am waiting I am going to go over some models like yours to see what may possibly be wrong.
http://servicepartstec.blogspot.com/Both Fridge and Freezer quit working properly at t - e6dabfb.gif
Posted on May 26, 2009
  • John Tripp
    John Tripp May 27, 2009
    Your refrigerator has something called an Adaptive defrost board inside the fresh food compartment behind the the controls. This may be defective and caused the refrigerator not to cool or defrost. The part number is 4388932 you will need to unplug the refrigerator and examine this part. At this point I think that the refrigerator will not function properly until the part is replaced. I have been wrong before so while the refrigerator is unplugged I want you to also remove the back panel to the freezer compartment and tell me if everything looks normal. You said that the refrigerator runs. Does the compressor and fans run also? Place the model number that you sent in the model search feature at the link I provided above. This takes you to your refrigerator and break down of its parts. Do get a good look at the Adaptive Defrost Board. Let me know what you see and answer the questions I asked, we will find out what is going on, Sea Breeze
  • John Tripp
    Thank You for your vote!
Kenmore freezer won't reach freezing temperature
When the compressor gets worn it loses it's ability to cool. 18 years is a long time for a fridge. The last fridge that did this to me, I paid the appliance guy $20 to tell me it was broke (I knew that part). Then he told me it wasn't worth the money to repair it and to buy a new one. Time for a new fridge.
Nov 27, 2013 | Refrigerators
Whirlpool Gold GB2SHTXTS00, I bought it in 2007, but 3 days ago, the cooling suddenly is not working, but freezer and lights are fine
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 06, 2011 | Whirlpool Gold Series GB2SHTXTS (219 cu...
Whirlpool quit working - can hear short buzzing and fan
you might want to try a 3in1 starter kit for the compressor,you can get it from your local appliance parts store,it has instuctions on it,it is easy to do-mike
Feb 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Sometimes the refidgerator freezes and then leaks
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you have any other question. Mike
Oct 12, 2009 | Whirlpool Refrigerators
Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer not cold but fridge is cool
quickest and cheapest way is to switch the unit off overnight. possibly missed a proper defrost cycle and evap.coil is blocked. when properly defrosted,switch on and you could be back on line
Aug 09, 2008 | Whirlpool GS6NBEXR Side by Side...
Fridge and freezer not cold enough since we moved
remove the panel at the reaar of the freezer. you should have a full frost pattern on your evaporator (frosted not snow packed) and the fan should be running. if you do not have a full frost pattern then you have a sealed system leak. covered under the first five years of your warranty
Feb 17, 2008 | Whirlpool ED5SHAXM Side by Side...
Refrigerator will not get cold, but freezer works
Do you know if the compressor in the back is running? If you can check that out get back to me and we can go from there. Most times if the fan in the freezer is running the defrost timer is ok.
Jul 09, 2007 | Amana ARSE66MB Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
219 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
