Question about One For All URC 7740 Remote Control
Orion tv combi wont responde to the menu button one one for all remote.Hense no tuning of channels any help on correct code.
Have an irion tv video combi, I own a one for all remote but the hand set wont control the menu or tuning buttons.Anyone know the code?
  • Anonymous Mar 20, 2014
    I tuned for the first time and negligently forgot to plug the AERIEL in.The screen message now invites me to "...go to the install and retune menu ..."
    Where do I find this - I cannot see an appropriate button on the remote control
  • 110 Answers
I am trying to reprogram the channels available on an Orion TV VCR/VHS combo without a remote and no menu button on this device's face for access
Hello
It is impossible to make an auto tune function to this TV without its remote control, as there is no Menu button on its front panel. OK.
Nov 24, 2011 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
I have an sony rm-ez2 and i want it to work with my orion Model #tv1934 whats the code or will it work
As far as I can tell, Sony doesn't have any codes for Orion TVs. You can try searching through all of the codes in the remote. Turn on the TV, press and hold the Set button and then press the Power button. Release the buttons. Then press TV button (component button). Press the CH+ button followed by the Power button. Repeat the CH+ and Power combination until the TV responds (powers off, changes channel). Then press ENT. Check if the TV responds to the remote on other functions. If it doesn't repeat the steps from press and hold the Set button.
This can take up to 70 tries.
Alternatively, try a replacement remote for the TV or a USB programmable universal remote. http://www.remotes.com/store/orion/tv1934.html is a substitute remote that should handle all of the functions.
I hope this helps.
Sep 06, 2010 | Sony RM-EZ2 Remote Control
My TV remote comtrol will not work when I try. I need the code.
Hi.
Manual Programming:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode.
3.Press and release power button. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
3. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on.
4. When the device turns on, press OK to store the code.
5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Codes for orion TV are
096,10,146
Thanx
Jul 27, 2010 | Brookstone 538744 Remote Control
Am i able to get into the menu of small orion tv without a remote
It may be possible to access the menu by holding down both volume buttons for 10 seconds. If not you probobly need the remote.
Dec 13, 2008 | Orion STV2763 27" TV
#4 & #5 buttons do not work on my remote. Channel 55 wont come in either on my tv
I had that problem 2 my channels disapeared one by one and some will skip yes...
I always use on my remote controll :
1 menu
2 Ch tuning
3 auto
and then wait untill it has found all the channels
Oct 02, 2008 | Orion1934 19" TV
Tuning in my orion tv
Do you just mean to select channels, or do you need to have it search for active channels (programming mode)? If just select channels, then most remotes have channel up & down buttons, in addition to the number pad. To select by numbers, use 2 digits: 04, 06, 08, 10, 22 and so forth.
If the set needs to be placed in the setup or autoprogram mode to search for active channels, then the menu functions must be used.
You may be able to find an online manual on Orion's website. Use your TV model number.
Jan 08, 2008 | Orion STV2763 27" TV
URC22B universal remote controller 15 in 1
Doing some searching I came across this, I hope it helps.
From instruction booklet
Power on the control device or VCR and put the tape in.
Press on the SET key continuously,then press the device key you want to set.For example, TV1/2,or VCR1/2,or SAT/CBL or AUX.
Then the LED is on, release the key you press.
Press the SET key again and release it,then you will go into QUICK SEARCH MODE and the LED will flash all the time.
Press the POWER key once at the device,URC22B will send another POWER signal of the next code.(If VCR/AUX, you will press the POWER or PLAY key). Observe if the device works(POWER OFF or PLAY),if it works, go to next step , otherwise repeat the step
whenever you want to leave SEARCH MODE,please press the device key,(TV1/2,or VCR1/2,or SAT/CBL or AUX.)
then the LED is off.
Then check other keys like [CH+/-],[VOL+/-] if they can be controlled.If cant be controlled,go back to the step
Nov 27, 2007 | Zenith ZN110 Remote Control
Orion stv 2750 27" TV
if you dont already have the remote set up then find the codes and t it up. the remote should have a button that says either tv/video or input. depending on the tv it should take you to a few channels through this button. look for either input 1 or 2, or even GAME. these should be the channels it will play on.
Oct 26, 2007 | Orion STV2763 27" TV
Orion TV remote
my orion if you channel down below channel 2 it goes to aux.
Oct 24, 2007 | Orion1934 19" TV
Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
Turn the set on, hook the cable directly to the TV, take the remote control and press 1 - 1 and if the TV tunes in channel 11 then your set is fine. If the TV was autoprogrammed when hooked to a cable box then the only channels that will be stored in memory are 3, maybe 4 and AUX. To correct this simply go back into the menu and look for the "autoprogram" option and perform the autoprogram while the cable is directly connected to the TV, without a cable box.
Jul 29, 2007 | Orion1934 19" TV
One For All URC 7740 Remote Control Logo
177 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
