Question about Kenmore Refrigerators
Fridge top, frezzer bottom kenmor model 59675932402. Frezzer working top not, read comments I belive it my be the deforst timer, but I read where you can turn it manually, but where can I find it?? An
Seems every once in a while the bottom freezer ices up and the top refrig gets warm. If I manually twist the little red knob under the refrig (defrost timer) until it turns off it seems to work great defrosting the freezer. I do it like 2-3 times and it fixes the issue. Kenmore 596.71103101 about 5years old. Gasket seems ok, maybe it needs to be cleaned? Also, i just vacuumed a ton of dust off the coil/radiator looking thing underneath of the refrig from the front. since this keeps happening time to time, what is the likely cause? timer, thermostat, heater? thanks! I have a fridge top not working freezer working, I read all the comments and replys but I don't see any knobs to turn manually for deforst timer, can you tell me where it is pls. Model 59675932402. Your help would be appreciated.
  • 1 more comment
  • www_dstarks May 26, 2009
    No, my request was mixed up with someone eles, My problem is top part of fridge is not working the frezzer is, I was reading comments from people with simlar problems, they stated they could turn the defrost timer manually, I want to know where to find the defrost timer at on my kenmore Model#59675939402, Fridge less than 3 yrs old.
  • GammyT May 11, 2010
    Cleaning the "coil/radiator looking thing underneath" is regular maintenance. Was this the first time you did it in 5 years?
    You also say the gasket seems fine but needs cleaning, also regular maintenance.
    Do a super clean on the coils and gasket as your first step in diagnosis.
5 Suggested Answers
the dr
  • 447 Answers
SOURCE: Defrost issue
its the timer if you manually advance it and it heats the back of the freezer please rate my advice...
Posted on Oct 03, 2007
aasc
  • 1606 Answers
SOURCE: ge fridge makes a clicking noise fan in frezzer
Main control board bad . The board controls the fan opperation and the clicking , sounds like a relay on the board . Replacing the board should solve the problem(s) .
Posted on Aug 06, 2009
martineznoe8
  • 92 Answers
SOURCE: hi,i have fisher pakel E522B
HI,CHECK FOR CONTINUITY ON THE DEFROST ELEMENT AND B-METAL IF THOSE COMPONENTS PASS THE TEST MAYBE THE TIMER OR DEFROST CONTROL COULD BE BAD IN YOUR REFRIGERATOR..GOOD LUCK..
Posted on Jul 04, 2011
  • 2330 Answers
SOURCE: my frezzer works but refrig doesnt cool well
open the freezer door,do you hear the fan blowing,if not hold in the door switch for a few deconds and let it go,if the fan isn't blowing this is your problem.all that happens is the freezer gets cold,the evap fan blows cold air through the damper and into the fridge section so if the freezer is fine you have a bad evap fan motor or the damper isn't opening all the way
Posted on Nov 19, 2011
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
I have a ffa90 futre fridge & bottom frezzer. the fridge is frezzing the food in the door & in the fridge. have tryed water in botles & they get ice on it .in the door the food frezzers so
Find where the supply air is coming into the fridge part. It comes from the freezer and could easily be supplying -18 air direct to the door. This would give you a 2 in the fridge but anything in the direct air path could freeze.
Sep 07, 2012 | Hotpoint FFA90 Bottom Freezer Refrigerator
Fridge not getting cold
if the frezzer is on top in this model and food is frozen it may be the ciculation fan motor.You can advance the defrost timer,located where the control knob is inside the frdge.with a phillips head screwdriver inserted into hole turn defrost timer it should make a clicking sound if this goes all the way around and the fan does not come on it is probablly burned out
Jan 29, 2012 | Kenmore Refrigerators
Hi,i have fisher pakel E522B with frezzer on the bottom the fridge goes warm and the frezzer section is all iced up.pulled back cover of frezzer off and removed fan,tested fan across 5v ph charger fan...
Jul 04, 2011 | Fisher and Paykel Active Smart E522B...
Water is leaking under the frezzer into the frig and it ices uo in the frig to right in the middel where the cool air comes from the frezzer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 10, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Sep 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Refridgerator/Freezer does not work.
check your damper vent door located between the fridge and freezer and make sure its opening up to let cold air into the fridge,also check the evaporator fan motor and make sure its operating to blow the air around the inside of the unit
May 23, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Where is the deforst timer on my maytag
Some units are different. Some are located behind the temp control unit, others located up inside top of unit behind the panels. There is usually a diagram on the back of your fridge
Jul 09, 2009 | Maytag MZD2666K Side by Side Refrigerator
FRIDGE STAYING AROUND 25 DEGREES
you have a gas leak , a refrigeration mechanic is required.
May 10, 2009 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
125 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
