Question about Lexmark X6170 All-In-One InkJet Printer
My printer is saying cartridge error and will not print
  • 210 Answers
Try cleaning the contact on both the ink cartridges and the carriage with a cotton swab dipped in alcohol. It that doesn't work, replace the ink cartridges.
Posted on Jul 30, 2009
Printer
The steps below should help you override the error and make the printer accept the cartridges and allow you to print.
Instructions
    • 1
      Remove and replace the print cartridge. If that doesn't solve the error, move on to Step 2.
    • 2
      Remove the print cartridge from the machine.
      • 3
        Wet the end of a cotton swab with rubbing alcohol.
      • 4
        Wipe the copper colored contacts on the print cartridge with the cotton swab to clean.
      • 5
        Wipe the contacts in the printer where the cartridge sits.
      • 6
        Replace the cartridge and try a test print. If removing residue for a clean connection didn't solve the error, move on to step 7.
      • 7
        Turn off the printer.
      • 8
        Unplug the printer from the power source and leave it unplugged for 15 to 30 minutes. This will reset the printer.
      • 9
        Plug the printer back into the power source and turn it on.
      • 10
        Print a test page.
    Regards,
    Suhail
    May 20, 2012 | Lexmark X1240 All-In-One InkJet Printer
    I put a cheaper replacement cartridge in for the printer and it says on the printer Error#1203. It also says cartridge error
    Cartridge Error: 1203 Your print cartridge has a short.
    1. Press Power to turn your All-In-One off.
    2. Unplug your All-In-One from the wall outlet.
    3. Plug in your All-In-One.
    4. Reinstall the cartridges.
    Hope this helps
    Mar 23, 2010 | Lexmark All-in-One Printer with PictBridge
    Hp psc 1210xi all in one printer says refilled cartridge is defective. HP says printer remembers cartridge serial number, counts number of prints executed & after certain number of prints, won't...
    Well, if the electronic circuit on the cartridge has blown, you have no other alternative then to buy a new cartridge. You can remove the cartridge and gently wipe the cartridge contacts. Turn off your printer, wait for a few min, then turn it back on. Put the cartridge back.
    If that doesn't work,
    1. Open the cartridge access door.
    2. Remove either cartridge (not both).
    3. Close the cartridge access door.
      • If the computer message is Print Cartridge Error , then the print cartridge that is still in the printer is the problem cartridge.
      • If the computer message is NOT Print Cartridge Error (instead, it says that the cartridge you have removed is ...Either missing, not detected, or incorrectly installed ), then the cartridge you have removed is the problem cartridge.
    There is a cmos battery in the printer, and, yes, when you remove it, the printer forgets everything (serial number, number of copies, etc). I have found a clip, but it says it only works for some HP printers. You can try that, but I am not sure that will help solve your problem.
    Jan 28, 2010 | HP PSC 1210 All-In-One InkJet Printer
    Check print cartridge blinking cartridges refilled today and installed laptop not recognising printer as result
      • If the message on the computer does not identify a particular cartridge (it says only Print cartridge error ), follow the steps below to determine which cartridge is causing the problem.
          • If the computer message is NOT Print Cartridge Error (instead, it says that the cartridge you have removed is ...Either missing, not detected, or incorrectly installed), then the cartridge you have removed is the problem cartridge.
    • If the problem still occurs, the electrical contact between the cartridges and the printer might be bad. Removing and reseating the cartridges might help. Also, you can clean the electric contacts on the cartridges with a dry cloth.
    Hope that will help solve your problem!
    Jan 16, 2010 | HP PSC 1205 InkJet Printer
    J4580 Print Cartridge Problem:[Tri-Color]Refer to Device Documen.
    hi i dont have the tricolor cartridge in my hp 5610 and i want to work only with black cartridge and my printer says there is no cartridge on the left , is it posible to solve this problem and work with one cartridge only ? i can print but copy and fax doesnt work . thanx
    Jul 27, 2009 | HP Officejet 5610 All-In-One InkJet...
    The ink is printing out fine, but in cartridge warning window says they are empty, and then stopped printing saying to remove cartridges. Now printer has error of 1203 and won't work. It won't shut off,...
    Try to remove the Ink Cartridge while printer is on then install it back after a minute. If you still getting the same error, possible the Ink Cartridge or Printer is faulty.
    Jun 16, 2009 | Dell 924 All-in-One InkJet Printer
    Just stoped printing;print cartridge problem
    Remove print catrige and clean it with cotton cloth then refix it.
    May 19, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    Cartridge error
    Please first check whether there is paper jam in the printer roller or else please check the cartridges is fixed properly
    Sep 24, 2008 | HP Officejet 4355 All-In-One InkJet...
    6150 Lexmark
    is printer Cartridge new? if now try to purchase new cartridge. If it doesnt work your print cartrige is the problem.
    Jan 17, 2008 | Office Equipment & Supplies
    Lexmark X6170 All-In-One InkJet Printer Logo
    85 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
