Question about Toshiba 57H93 57" Rear Projection HDTV
How to change a fuse on toshiba 5793 when a power surge occurs
Is there a fuse i can change on the toshiba 57h93 when theres a power surge
  • Toshiba Master
  • 1,525 Answers
Hello yes there are fuses. the main one is located in the power supply it glass type it might be black where it has shorted if you replace it and it blows again then you have a dead short in the power supply good luck. ps on the main there are wickman fuses these are solder in to the board
shaun
Posted on May 27, 2009
Ix 2000 surging
YOU NEED TO AJUST THE FUEL MIX ON THE CARBURTOR
Nov 06, 2012 | Generac 5793R iX2000 iX Series 2000 Watt...
57h93 flashing screen
If the set when first turned on has noise lines or distortion (left to right usually) but after several minutes they diminish and go away you have a bad HYPER board.
If this is the case let me know and I will advise you on options.
May 17, 2012 | Toshiba 57H93 57" Rear Projection HDTV
My Toshiba 57H93 has too much red in it. I cannot get the colors to look right anymore. Convergance seems ok. Any thoughts on how to fix this?
I had the same problem and called sears they only chare $99 to come out free estimate. it was a circuit board had to be resoldered and it works great
Dec 24, 2010 | Toshiba 57H93 57" Rear Projection HDTV
Hello! I have a Toshiba 57" TV, model # 57H93. When I plug it in, I can hear the relays click, but then nothing happens - no power, nothing. I was wondering if there are quick checks I can do to figure...
This set uses up to 7 fuses, some are normal glass and others are what are called pico fuses--see attached photo.
Check with set unplugged, just like any fuse.
If any are blown set will detect no voltage and set will not come on.
Let me know what you find, allow the site here is supposed to notify me by email if you comment, but major problems with that right now.
SD TECH
iF THIS INFORMATION HELPS RATE THIS SOLUTION AS VERY HELPFUL AS I do this here for free.
Aug 21, 2010 | Toshiba 57H82 57" Rear Projection...
How to replace power supply?
Toshiba model 57H93 worked perfectly last night. Turned off and went to bed. Turned on this morning, and nothing, it won't turn on. Checked all cords and cables, pushed reset button, and still won't turn on. What could cause this to happen?
Dec 14, 2009 | Toshiba 57H93 57" Rear Projection HDTV
No power
has a short in the power supply I suggest it is a technical revs
Oct 27, 2009 | Toshiba 57H93 57" Rear Projection HDTV
My toshiba 57h93 worked fine this morning power went out
Ur DM power board is dead,must be replaced.Try this
website for the board.Tv repair World.com.
Oct 20, 2009 | Toshiba 57H93 57" Rear Projection HDTV
After power surge my tv (toshiba 52') will not power on
after a power surge if you dont have in on a surge protector it probably fried the main board in the tv so it wont work anymore..woudl probably be cheaper to buy a new tv than to try to repair the one you have now
Dec 15, 2008 | Toshiba 57H93 57" Rear Projection HDTV
57H93 Toshiba
Protect screen Part # 23311038.......117.30
Fresnel screen ( inside ) # 23311014 ...65.47
Lenticular screen ( middle) # 23311128....81.96
You should only need the protector screen......T.
Nov 28, 2007 | Toshiba 57H93 57" Rear Projection HDTV
Power surge issue
This is a fault in the motor, could be a shorted turn in the motor windings. This has nothing to do with fuses.
Oct 06, 2007 | Eureka 4467AV Upright Vacuum
Open Questions:
Toshiba 57H93 57" Rear Projection HDTV Logo
444 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
