Home | Bissell | 7901-1 ProHeat Scotchgard Upright Wet... | My carpet cleaner wil...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Problem for Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
My carpet cleaner will not spray. Maybe a little thru the tool but not enough pressure to SPRAY
By doodiehead on May 26, 2009
my carpet cleaner will not spray liquid out My Bissell Proheat has stopped spraying also. The tool will spray a little but doesn't seem to have enough pressure to really SPRAY.
Best Solution
posted on Sep 26, 2009
Very Helpful)
WaterdownRob
Rank: Master
Rating: 94%, 9 votes
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!!
p.s. Make sure you do give it about a minute after you turn it on before you try spraying. If the pump is not allowed sufficient time to prime, you may not get proper flow.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jun 02, 2009
Somewhat Helpful)
specialbill
Rank: Apprentice
Rating: 92%, 3 votes
Remove the bottom in order to access the innards and clean out all teh gunk you will no doubt find gathered there. Unhook one end of each clear plastic hose. Obtain a very small test-tube brush (only slightly smaller than the opening in the plastic tubes, approx. 3mm) and carefull scrub out each tube, then use the crevice tool from a vacuum cleaner (Bissell, of course), tape closed all but a small operening with ubiquitous duck tape, **** out the dirty water and any debris. Then reassemble the unit (good luck on that deal if you do not first secure an exploded diagram. Do not fail to do this or your wonderful Bissell will be laid to rest in your garage or landfill!) Before using, run several cups of clear water and a strong detergent like TSP to be sure all the "pipes" are clear and you see spray.  Good luck, Bill
Was this helpful?
Yes
No
Popular Solutions for Bissell 7901-1 ProHeat
Questions and Unsolved Problems for Bissell 7901-1 ProHeat
Do you recommend Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum?
Answer
Answer
I am having problems with my Bissel 7901-1. It isn't working at all. If I remember right it didn't... (More)
Answer
belt assembly diagram. Looking for a picture to see if something is missing holding the belt on.
Answer
I want to clean fluff from underneath the transparent front panel of my Bissell 11 7901. I have... (More)
Answer
my bissell cleaner is not picking up the solution and my my knob to switch it from carpets to tools... (More)
Answer
7901 series carpet cleaner sprays but does not **** the water back up. Got it appart right now and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bissell 7901-1 ProHeat...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
