Question about Asrock K7S8XE Motherboard
Beeps beeps beeps everwhere on my desktop
Just installed new psu, switched it on to hear most annoying....beep.beep.beep.....beep.beep.beep.....beep.beep.beep.... you get the picture i am sure...help me please before i reach for the hammer. i have taken everything out of slots, i have changed the memory sticks around, still beep.beep.beep its ringing in my ears. :o(
  • vipes1977 May 26, 2009
    Guys, thanks for your advice, dont want to seem ungreatful but i said PSU power supply unit not CPU. the thing is still driving me nuts. will post my spec 2moro as it is time for bed. cheers.
  • vipes1977 May 27, 2009
    well, tried all today, even took it to the computer bloke and the of them looked at it tried all sorts and came to the conclusion my mother board had been taken out too by the power cut. now have a hdd case connected to my laptop. cheers guys for your help.
    Scholar:
  • 66 Answers
AMD Duron, AMD Athlon are the only supported cpu's for this motherboard
and for memory it only supports
up to 3gb of DDR SDRAM at 400, 333, or 266 Mhz if you are using anythingng else that could be the main problem
Posted on May 26, 2009
  • tonyw514
    tonyw514 May 26, 2009
    i need to know the specs on your memory.
    you must only use
    DDR SDRAM
    400, 333, 266 MHz
    and can be no more than 3 gigs total
    also it only supports AMD Duron, AMD Athlon processors.
    it would a great help to know the specs of the memory and processor you are using.
  • 232 Answers
Depends on the BIOS. The beep code means ether the memory or CPU. Since you are attempting to install a another CPU its probably a problem with the CPU itself (dameged or incompatible) or a BIOS setting problem. Also make sure you always use thermal paste. The replacement CPU might be heating up and not functioning.
  • Teddi B May 26, 2009
    Yea I totally missed that one I thought you misspelled. What's the power supply brand and model? If you know your motherboard's BIOS you can probrably find information on beep-codes.
I rebuilt computer with new parts, now won't start up. No POST. Power LED lights up, no cpu fans spin, no beeps. Psu works with paper clip test. New mobo, ram, psu, cpu.
Check display without cabinet maybe motherboard getting short with cabinet and try new Power supply check all the power supply connectors connected or not .
Nov 14, 2016 | Computers & Internet
Dell OptiPlex GX240 PC Desktop cannot power up
Do you hear any beep sound when you power on the PC? Check the following componente PSU,video card (if you hear one long beep),or RAM memory if you hear 3 long beeps.
Apr 06, 2014 | Dell OptiPlex GX240 PC Desktop
Standby blinking green button went off and now cannot turn on. cord connection ok and eveything unplugged that might interfere
I guess your power supply died. try to disable the power supply and enable it again (switch behind the tower) otherwise you should get it checked out by a professional.
Mar 02, 2011 | Dell Dimension 4700C PC Desktop
I just got this Vectra VL420 from a surplus store. I try to start up I get this funny music and then two beeps. I understand two beeps indicate power problems. But not sure what to do to rectify this....
From memory I would say you are in the right ball park.
I remember now. Error 2 means the power supply is in protect mode.
First check the wiring going to the Motherboard from the PSU. There is a four pin connector that lets the PSU know if all is well with the main board. If that is not connected, that may cause your problem
Try a new PSU. They are fairly cheap. Match the power on the specification panel stuck to the PSU.
If those don't fix it, a new motherboard is the next step.
Hope this helps.
Nov 22, 2010 | HP Vectra VL420 PC Desktop
Dell Dimension E510 will not turn on
It could be.
When you switch on after it has been turned off for a while look at the fan on the PSU as you switch on.
If it spins or tries to spin for a very short time then I would indeed suspect the psu.
If however the psu fan does spin for longer and you can hear any beeps then that would be an indication of a different problem.
Should that be the case then check here.
http://www.computerhope.com/beep.htm
or here
http://www.pchell.com/hardware/beepcodes.shtml
  • If you found this information useful please click
Aug 13, 2009 | Dell Dimension E510 PC Desktop
My computer is switching on and nothing displays in the monitor. After switching on, after a minute it automatically switch off. Mother board is Intel 845 GVSR processor 2.4 GHz. Service centre person is...
Try a bios reset first.
Second pull out the memories (RAM). If you hear beeps on startup the the motherboard and the processor is ok.
If not, possibly could be the processor.
Also try with other power source.
Jul 28, 2009 | Intel Desktop Board D845GLLY Motherboard
Motherboard problem
These more up to date cards have a special PCI-E connector actually on the card which you have to connect to your psu too.
It shouldnt beep if theres no problems
If you cant get video or anything , make sure that the cardrs power conenctor is plugged into the psu
Jan 07, 2009 | Computers & Internet
I purchased an emachine desktop at an estate sale that had a note on the tower saying it had a new had drive installed and never used. So I purchase it and brought it home, hooked it up and turned it on. ...
Is the 'New hard drive installed, never used' bit relevant? Open the tower, get hard drive...
PC bought at auction won't switch on ?? Anything is possible, from 'It's really an empty tower with a brick in it for weight' .. to any number of usual suspects.. The fact that most PC computer 's make a beep and light up stuff when switched on for instance relies on the presence of a working PSU.
Your diagnostic approach would begin there.
Nov 21, 2008 | Gateway Computers & Internet
P5k motherboard
remove the ram, do you hear beeps?
you might want to get your hands on one of these
http://cgi.ebay.com/New-8digit-PC-Motherboard-CPU-Ram-Analyzer-Test-Card_W0QQitemZ190231285206QQcmdZViewItem?IMSfp=TL0806211611r25031
if link broken click here
Reseing the bios shouldn't be a problem go ahead, or is there something I don't know? does it void the warranty? I don't think so.
Jun 23, 2008 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
Asrock K7S8XE Motherboard Logo
1,094 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
