Key board problems
I have a toshiba laptop and the key board suddenly stopped working. the caps lock light doesnt come on either. some one please help.
    Scholar:
  • 89 Answers
It sounds like your having a system board problem, you will need to take the machine into a repair shop to have it looked at and make sure that it's still plugged into the system board correct.
You can also try hooking up an external keyboard to the laptop in the meantime.
Posted on May 26, 2009
Toshiba Qosmio x875 keyboard suddenly stops working
pls remove the key board ribbon cable and re seat again
Sep 08, 2017 | Toshiba Qosmio Computers & Internet
I have a renault megane 1998, central locking suddenly stopped working tested key fob thats OK
It could be your onboard computer or locking module, as the guy next door had an identical problem on his Megane. A tech came and changed a module then programmed the 'brains'.
Oct 29, 2017 | Renault 181 Cars & Trucks
Light for caps lock will not come on
I have reviewed your problem and have the fallowing for you to aces.
First, If when you hit the cap lock key the cap lock works, the key board is OK and you may have just blown a led.
If your cap light does not work correctly when hit, you will need to replace the keyboard.
cost is about $16.00 plus shipping on ebay.
Nov 11, 2009 | HP Pavilion dv6000z Notebook
The m and caps lock keys on my Toshiba satellite
Bad keyboard. This series have a higher frequency of keyboard problems because ... well .. the keyboard cable got folded by design. Just replace it. The A40's uses the same keyboard as a A10, A15, A55, A60, A64, 1400, 1405, 1410, 1415, 2400, 2405, 2410, 2415 ... and many others. A new replacement keyboard should run about $20 on eBay.
Replacing the KB is easy: lift up the power button board above the keyboard, remove the three screws holding the keyboard down, then remove the keyboard connector cover panel, and you'll be able to disconnect the keyboard.
Oct 11, 2009 | Toshiba Satellite A40 Notebook
My caps lock key does not light up. does my
you should have 1 on the caps lock key. a black dot on the top right of the caps lock key
Oct 07, 2009 | Toshiba Satellite L25-S119 Notebook
MY KEYBOARD DOES NOT WORK WELL. FOR INSTANCE, I CAN NOT TYPE M WIthout holding the right side shift.
brand new Compaq 620 the keys stopped working. FIrst with 6,7, "_", then some other character keys also stopped working. Please let me know how to fix it.
Jun 20, 2009 | Computers & Internet
Nothing comes on my screen when i power on
you have to resit the ram,if the problem is not solved then dislplay adapter is gone, you have to send it for repair
May 31, 2008 | Toshiba Satellite P25-S5263 Notebook
Start up
yr problem should be from the screen to really confirm if yr laptop is truly on cos u dont just gudge by seing the power led on. to check if yr system is on press the caps lock key or press the fn+num lock key if the indicator led comes on then yr system os on now troubleshoot yr screen by checking the module,connector n fuses. if the caps lock led doesnt come on then yr system just powered on because it saw a power source in that case try to replace the memory(ram) next the processor.
guess this helps
thanks for using fixya
May 26, 2008 | Toshiba Satellite A135-S4427 Notebook
Toshiba A105 laptop
Hi Harry! Did you remove the ram? Sounds like it is either not compatible. Good luck!
Jan 08, 2008 | Acer Aspire 5050-3242 Notebook
Laptop won't boot up
Key board make sure it is hooked up right.
Mouse make sure it is hooked up right as will.
Num lock is- the only light that should be on at all times.
Click on : Scroll Lock make sure light (is off)
Caps Light - is for Capital letters
Hope this helps ya .
Nov 29, 2007 | Dell Latitude D800 Notebook
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
