Question about Kitchen Ranges
Oven not heating properly
Have an Electrolux Slide-in Range, Model GLES388DSA. Turn on oven, preheat signals that heating is complete. With a oven thermometer, set oven at 200, thermometer reads 100; set at 300, reads 150. Top element does NOT turn red when turned onto broil, nor is it hot to touch when oven has heated. Not receiving any error messages on control unit, which makes us think it's not the sensor.
Any ideas on circuit test, either a continuity or voltage test?
  • 10,865 Answers
Hello. You have done an excellent job of explaining your problem. Read over the info. below as it sounds like your top element is not working.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
  • Posted on May 26, 2009
    GE Model J S968S0F4SS. During bake display goes bake, oven turns off.
    Oven Does Not Heat, But The Burners Heat - GE Appliances
    products.geappliances.com/appliance/gea-support-search-content?...
    Range - Oven Does Not Heat, But The Burners Heat. To minimize the ... Turn yourrange OFF and either remove the fuses or turn the breaker OFF. Then unplug ...
    How To Fix Oven With Little or No Heat When Baking ...
    Troubleshooting Why Your Oven Won't Heat ' PartSelect ...
    ? 2:54
    https://www.youtube.com/watch?v=ketJHf3rrSk
    Sep 14, 2011 - Uploaded by PartSelect
    In this video you'll learn why your oven may not be heatingproperly. ... Neither the bake or broil elements ..
    Oct 31, 2015 | GE Kitchen Ranges
    My Frigidiare model GLES388DSA will not bake or broil
    Good Afternoon Friend,
    I understand your Frigidaire range, model# GLES388DSA, will not bake or broil. I suggest resetting your range, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Restore power and try preheating your oven. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
    Jun 17, 2014 | Frigidaire Kitchen Ranges
    Oven heats very slowly
    15 minutes until the signal beeps? completely normal, BUT it will take up to 45 minutes for any oven to properly preheat COMPLETELY.
    Mar 18, 2014 | Thermador C302U Electric Double Oven
    Preheating?
    Standard problem with this unit sorry to tell you! I've worked on several.The main oven would take 20-22 minutes to pre-heat, even on the "rapid pre-heat setting". I was told by Electrolux techs that it is the way the range is designed because of the "hidden element." Very sorry to tell you I found this model to just be very Unreliable. To many issues......
    Jun 10, 2013 | Electrolux EW30DS65GS Dual Fuel (Electric...
    Sensor
    must read 1100 ohms at room temp. If open or shorted that is yer probo. Could also just be a greasy quick connect not making a good connection.
    Jan 10, 2013 | Electrolux EI30EF55GS Electric Range
    Electrolux oven will not heat
    Hello Michael Anderson - From what you have described it sounds like the unit has faulty elements or could possibly be experiencing a wiring issue with the EOC. Try resetting the oven by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately to properly diagnose the unit.
    Jan 01, 2013 | Electrolux EW30ES65GS 30" Slide-in...
    Frigidaire FES367ASE Slide in range
    Someone mis-wired the new control. Turn off the power to the range. Open the control console,switch the bake and broil wires on the oven control.
    Sep 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
    Frigidaire electric range oven and top burners wont come on
    It sounds like you only have one side of the 220v current coming into the range. I suggest checking the outlet feeding the range for proper power. The problem could actually be in your circuit breaker, only sending power via one of the conductors.
    Mar 11, 2009 | Electrolux 30" Self-Cleaning Freestanding...
    Preheat taking long time
    If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
    Post back if you have any more questions.
    Oct 29, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
    Kitchen Ranges Logo
    780 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
