Question about Canon PIXMA MX850 multifunction InkJet Printer
Scanner stopped functioning
My scanner has suddenly stopped working on my Canon MX850. If I press the scann button then go through the menu options local (USB) Document (ADF Simplex) Save as PDF file, and then start It gives a message "processing please wait momentarily" Normally after this the message comes as "scanner warming up." However now nothing happens and it goes back to scan with the image (expecting you to press on start button)
  • sgrover1_99 May 26, 2009
    Problem solved. There was a pop-up message (hidden behind various windows) So after trying to reboot my printer several times, I decided to reboot my computer and that is when I found it.
    Thanks
  • Michael Rodriques May 11, 2010
    What version(s) of Adobe do you have installed on the machine?
  • 68 Answers
R u already try reinstall your driver?if not, try it 1st and see the result..i'm afraid the driver is damages....try to download from canon support website in order to get the updated one...hopes it will help ; )
Posted on May 26, 2009
  • Abang Bat
    Abang Bat May 27, 2009
    ok..hope u can be a problem solver to others...and try to vote other to help each other..thank you...
In lan scanner xerox is not coonected i have alredy install the drivers for scanner but he doesnt reply when ping command fire
did you press the scann button on the copier?
If not press scann button and then try to ping it.
Hope that helps!
Jul 15, 2011 | Canon imageRUNNER 2018 Copier
DR-5020 Path-Through Scanner: can't fing the drivers for the canon dr5020 scanne...
You can down load drivers from Canon Europe site. http://software.canon-europe.com/products/0000672.asp
S. Mohan
May 18, 2010 | Canon DR-5020 Path-Through Scanner
Scanner problems Its stays on Auto-Scann and buttons dont work
Resetting or initializing the scanner may clear your problem.
To RESET the scanner:
- Turn the power OFF, then turn it ON again.
- Insert a pointed object (paper clip end, ballpoint pen tip, etc.) into the RESET opening on the side of the scanner, then press and release the button inside the opening.
If the above doesn't clear the problem, try the more drastic INITIALIZE procedure. NOTE: this step will erase all data that you have programmed into the scanner and restore it to original factory settings. To INITIALIZE the unit:
- Turn the scanner OFF then ON again. The scanner briefly displays the DSP boot version, then "Welcome to Digital Trunking" displays.
- Press "0". The scanner displays "System Tests Select Test Exits if no Key Press"
- Press "1". The scanner displays "Factory Unit Erase Memory ENTER if Yes CL to Exit"
- Press ENTER. The scanner displays "Initializing Clr Main Mem V-Scan is OK Please Wait"
- Do not power the scanner OFF until INITIALIZE is complete. When the process is complete the scanner will display "M0000" on the top line and "Bank 0 Ch 0" on the bottom line.
If neither of the above steps works for scanner I recommend that you take it to your nearest Radio shack and arrange certified repairs.
Need the manual for your scanner? You can download/print it here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-96/pro96.pdf
For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
Bill B
Apr 21, 2010 | Radio Shack Pro-96 Scanner
Canon Pixma MX850 won't scan - says 'set the pc to start scan'
Do you have more than one PC connected to the scanner? I have both a PC and a Mac connected to it, and I think my scanner is trying to connect to the Mac, which requires image capture software to be installed, rather than the PC. Don't know how to tell it to go to the PC, though...
Feb 01, 2010 | Canon PIXMA MX850 Multifunction Printer
Error E42
Scanner light should come on at power up. Found ribbon cable connecting scanner unit to base had come unplugged from socket on circuit board. The ribbon cable is one of three found near back hinge of scanner and is hidden underneath the other two. It should drape over the edge of circuit board and then plug into small recepticle on inner side of board. I plugged it in and printer works again. Hope this helps.
Or try:----------------
TRY THIS STEPS... Reset Counter Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
IF THIS STEPS DOESN'T WORK, YOU NEED TO BRING THE UNIT TO YOUR NEAREST SERVICE CENTER...
Aug 30, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
MY MP160 FLASHES E AND # 3 ALTERNATELY
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
button pressing
procedures below.
procedures below.
Aug 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Scanner not found
Have you installed ISIS/TWAIN Drivers? If not download item 4 from this link http://software.canon-europe.com/products/0010203.asp
If you are using Vista, you must install corresponding drivers.
S. Mohan, Chennai, India
Apr 12, 2009 | Canon DR-5010C Scanner
Error E 4, 2 canon pixma mp 160
E42 means scanner error. May require a hard reset(disconnect from power supply for 30 min). Otherwise may require factory reset procedure to be applied. Follow the steps below:
Mp160 Reset Counter
press the Power button while pressing and holding the Stop/ Reset button.
the printer will move into a service mode. (Waiting for menu selection)
according to the function listed in the table below.
the LED lights alternately in orange and green, starting with orange.)
The number of the Reset button pressing LED Function Remarks
4 times Green Waste ink counter reset See waste ink counter reset procedures below.
5 times Orange Destination setting See Destination setting procedures below.
Jun 29, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Scanner not working
TRY THIS STEPS...
Mp150 Reset Counter
button pressing
procedures below.
procedures below.
Nov 05, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon Pixma MP150 Error code E 42
Had exact same problem. Scanner light should come on at power up. Found ribbon cable connecting scanner unit to base had come unplugged from socket on circuit board. The ribbon cable is one of three found near back hinge of scanner and is hidden underneath the other two. It should drape over the edge of circuit board and then plug into small recepticle on inner side of board. I plugged it in and printer works again. Hope this helps.
Nov 04, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MX850 multifunction InkJet Printer Logo
413 people viewed this question
old marine
old marine
