Question about Jenn-Air 30 in. Pro-Style Range Hood
Jenn-Air 30 in. Under Cabinet Hood had no instructions on how to
Need instructions on how to wire?
  • sallymir May 26, 2009
    What is the yellow wire with a green stripe? Where does it go?
  • 10,865 Answers
This is a straight forward wiring project involving 110 volts of electricity and a 15 amp circuit.
If there is already power available at this location use it. If not, run a wire to the cabinet above the hood location with enough extra to drop down into the hood area and hook it up.
Once you have the power wire in place it is just a matter of hooking the wires up black-black, white-white, ground-ground screw.
enjoy your new hood.
Posted on May 26, 2009
  • Joe Hogan May 27, 2009
    The yellow and green wire is a ground wire. Attach it the ground wire coming from your electrical source, which is typically a bare wire.
Recent rain storm, water came out from failed baffle, the power did not trip the circuit, but the unit no longer power's up?
Depending how the unit is installed..you may have a ground fault type outlet up in the cabinet someplace. Maybe on top of the cabinets. This will cut power to the unit without tripping the breaker. Just find the outlet & reset the GFI outlet. Fix the leak.
Mar 01, 2016 | Kobe Brillia CHX191 Series 30-inch Under...
Uninstallation of Jenn-Air JED8430BDB cooktop
There are 2 clips under the cooktop, attached to the counter.
Remove the drawers under the cooktop to see the clips.
Jul 05, 2013 | Jenn-Air 30 in. CVE3401 Electric Cooktop
What is the cabinet cut out for a Jenn-air 30" prostyle cooktop model# jcp430adp. The manufacturers specs are not specific
The pictures that are posted on the Jenn Air site are confusing. I waited until I received the unit to make the cuts. I am glad that I did.
Jul 18, 2009 | Jenn-Air 30 in. Pro-Style CCGP2420P Gas...
Jenn Air stove wired backwards
The fan is likely 120-volt fan, and swapping the wire likely put 220 across the fan. Did the fan seem to rev up very fast? The control is also likely 120-volt, and that too had 220 applied to it.
Give me the model number, and I'll find what parts you need to replace
May 13, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Jenn Air broken flap on outside exhaust hood
I have the same problem. How do I get the new outside cover when I don't know a part number?
Dec 07, 2008 | Jenn-Air JXT5830AD Kitchen Hood
Broken Handle on Jenn-Air Model M406 Under Cabninet Microwave
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Nov 24, 2008 | Microwave Ovens
Wiring 4 wire cook top to 3 wire outlet
What you have is a 220v and a 110v circuit within the cook top. It needs a 4 wire feed to supply 2 hots, 1ground, and 1 neutral. The 3 wire outlet only has 2hots and a ground no neutral, which will probably not allow your control circuit to operate. You nee to run a neutral wire to obtain a 110v circuit. DO NOT try to run neutral off the ground or you will energize your cook top cabinet and it will shock you. Your solution is to run a neutarl wire from the closest circuit that you can find.
If you need further asst.
Eboukater@gmail.com
Sep 24, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air Glass Door - How to Clean
Sounds familiar. I saw this thread this afternoon while trying to clean my own oven window. My sense is it is definitely a design flaw. It's just too easy to drip something down the top door vents onto the inside of the multiple glass panes.
Here's what I did. I removed the door, following the manual instructions. Open the door to 1/4 and lift it up. Then I put it down on a soft surface and started removing screws until it came apart. It wasn't too complicated though it took some time. Be sure to keep track of your screws as you do this as there are a few different kinds.
Aug 28, 2007 | Jenn-Air Jenn Air French Door Floating...
Jenn-Air 30 in. Pro-Style Range Hood Logo
186 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
