Question about Saws
Need to wire a new switch and reset button and wires got crossed up. Need to know which wires go where.
  • m_stewart96 May 26, 2009
    The saw is a MK 880
    There is five wires coming out of the motor and I think they are all black. The wires coming from the power cord are black, white, and green. There is a capacitor under the switch cover with two black wires. The reset button has three connections. The on / off toggle switch has four connections.
  • 3,230 Answers
First of all You forgot to mention make and model number of that machine.
Please provide the information so i can help you.
Thanks
Posted on May 26, 2009
  • Mukesh Kumar May 26, 2009
    The Switching should go like this
    (single letters denote wire color)
    Y---o o---R
    B---o o---B
    The contacts where the black wires attach are the points on the switch that break when continuity is checked.
    Good Luck!!
    It's very difficult to find perfect color code from here.
    if you do some wrong code combination, than it compleatly damage your machine.
    Sorry for that..
    Regards
    all-guru
I rear ended a vehicle in my 1985 Ford F150 manual transmission. I reset the inertia switch but I still can't get my truck to start. Any suggestions?
Was the inertia switch actually activated? If so the button would pop up. You need to determine whether or not there is a lack of spark or fuel causing the no start.You may have a defective inertia switch if it was activated and will not reset. You can unplug it and by-pass the wiring of the inertia switch by crossing over the wires at the plug to see if it will start
May 18, 2015 | Ford Cars & Trucks
Kenmore Model 11086407120 Electric dryer fuse blows.
You have a short or a bad ground. You will need to check the complete wire harness for any signs of wear or a crossed wire.
Apr 25, 2012 | Dryers
The reset button poped and it wont stay set
inspect all low voltage wiring inside blower, condensing, controls compartment and related switches for a short to ground or crossed to common. May also be short in thermostat, disconnect wiring from thermostat and see if the reset stays, may also be bad transformer.
Aug 25, 2011 | Carrier 38CKC036 Air Conditioner
I have a Intermatic ST01C installed with a 3-way connection. The other day it started "clicking" on-off..on-off..on-off etc. and would not stop till I operated the non-timer switch leg in my...
Wiring could be suspect.
I have tested this timer.
ST01C works like this in 3-way circuit.
Timer program turns lights on-off.
When blue wire and red wire are connected together, then timer reverses on-off program.
So the only function of second 3-way switch is to connect and disconnect blue and red wires on the timer.
The second 3-way switch is wired differently than ordinary 3-way.
See illustration below.
http://waterheatertimer.org/ST01C-program.html#3way
Either the switch or timer have malfunctioned.
My bet is the timer.
1) Replace 3-way switch and see if problem clears up
2) Manual says: reset timer when encountering problems.
Hold down on-off button and push-and-release reset button.
Keep holding on-off until INIT displays.
3) You have to completely reprogram timer after reset.
Link above has ez steps.
ST01C manual:
http://waterheatertimer.org/Intermatic-st01c.pdf
Feb 22, 2011 | Intermatic Inc. ST01C Digital In-Wall...
7 Day Wall Switch Timer ( older model with acrilc cover) when its on the lights start blinking and they dont stop util you take out the battery......thanks
Question: Is this old timer that started malfunctioning?
If this is older timer, that worked correctly before, then the timer has gone bad.
You can reset timer, and then re-programming.
But without knowing which timer, it's hard to say if timer has reset button or if you hold down two buttons to perform the reset.
Add a comment with better description of timer: plug-in, outdoor, in-wall, programmable, or dial-type.
Describe buttons and location exactly.
Is there a switch on the side? Or a slide button on top.
Is outlet 3-prong? How many outlets? Are outlets on front of timer or sides?
Nobody carries repair parts for old timers.
I can probably find new model with same features
If this is new installation, and timer replaces wall switch, it sounds like the wiring is wrong or timer is busted.
Again I need a very specific description of the timer, and the timer wires, and the wires inside box, and the switch it replaced.
There are 100's of timers out there, in all shapes and sizes, with different features ... and I know most of them.
But need more info.
http://picclick.com/Amazon/Home-Improvement/Electrical/Timers/
Dec 13, 2010 | Hardware & Accessories
Switched stereo installed new car now no power
If your stereo has a fuse it will be in line with the hot wire (usually a red and/or yellow). The neutral is usually the black wire.
Unless you crossed the neutral wire by cutting it, you probably didn't blow a fuse. Plugging in a wiring harness will not blow the fuse. You can go to an ie. Autozone store and buy a car fuse tester or use a volt ohm meter to check your fuses. With the volt ohm meter set to dc volts you could check the harness by touching the probes to the wires listed above where you will be looking for a 12 volt reading.
Don't forget to check the on/off button with the key turned partway on or in the position that displays the parking and interior lights.
Feb 28, 2010 | Clarion DXZ545MP CD Player
WHERE IS FUEL PUMP RESET SWITCH
It should be on the passenger underneath the dash on the side panel just before the door
Aug 12, 2009 | 2001 Ford Windstar
New wired Heath/Zenith doorbell buzzes until disconnected
it sounds like you have a bad push button . if the wires where crossed you would most likely have this problem as soon as you turned on power .
Mar 15, 2009 | Honeywell Electrical Supplies
Adding new extension to Nortel Norstar Meridian Phone System
They should have terminated your voice on a block in your phone room. If that is the case you now need a punch down tool and a spool of cross connect wire. You would punch down one side of the cross connect wire on the tip and ring of the switch pairs and the other end of the cross connect wire on the blue pair of your station cable.
Jan 15, 2009 | Lands Phones
Rudd furnace
You have a safety limit switch that is either bad or needs to be manually reset. Some have little buttons between the two wires going to the switch that you can push to reset. If not they are automatic switchs then one is bad. You have to do an ohms test to see if each switch is bad or good.
Jan 02, 2009 | Ruud UBHC Air Conditioner
Saws Logo
66 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
