Question about Samsung HLR5067WX 50" Rear Projection HDTV
SAMSUNG HLS5086W Hello, I stumbled across this web page and am hoping it will help solve some of my questions. I just had this TV sent from overseas from the US to Germany where I am stationed. Upon arrival it does not turn on. When I hit the power button the light turns green, and then turns off and the STD BY / LAMP LED goes flashing red. I removed the back cover to see if I could see anything happening, and it appears that the light turns on very briefly, and then turns off. I have never worked on a DLP TV, and have no idea where a good place to start is. I would think the bulb is fine if it powers up. I removed the light and reseated about 3-4 connections with no improvements. I am somewhat electronically competent and should be able to gain access to multimeters and any other instruments i might need. I was wondering if there is an easy way to test the ballast, or would it be ok as well if it was able to power on the bulb even tho brief. If not the ballast, are any of these symptoms pointing towards the DMD board? If you have any sugjestions, it would be much appreciated. Thanks I have the same problem with my samsung hls5086W. My TV shuts off at least 10 times an hour. sometimes not at all the next day, then back to the same issue the following day. I wish I knew how to fix this or even know what the issue could be. The standby/temp and lamp lights up and flash! is this an overheating problem? Please somebody let me know what I need to fix this inconvenience. Thanks alot.
  • 54 Answers
With the back cover off there is a small switch with a blue actuautor near the lamp. press it up and hold it while you turn on tv. if tv works ok replace the switch
Posted on May 26, 2009
Have a Samsung LED tv model #un75f6300afxza that has a 3 inch shadow across the lower third of the way up from bottom of set
Hello!
Here you can find manuals for a number of Samsung LED TVs. Hope you can find here a manual for your device (or a similar device) and solve the problem.
https://manualsbrain.com/en/brands/samsung/led-tvs
Oct 04, 2017 | Samsung Televison & Video
I sent a question on this subject yesterday, Oct. 13,2014. Your system now says there is no relevent questions on this subject! How are you going to help if this sight don't receive the question that is...
Doris,
You might get faster service if you find a web page with people who answer questions that are paid for doing so.
On this web page, you get old retired geezers giving answers at their leisure if they happen to stumble on a question that someone asked.
Oct 13, 2014 | Saws
I have a 61 inch samsung TV. A message flashed across the screen saying "check fan # 1 " then a few minutes later it shut down.
Hello
Not much to do by web, this message mean you most likely need a new fan, tv shuts down due to overheating. Contact service.
Aug 21, 2011 | Samsung Televison & Video
When i start my samsung hls5086w dlp tv it makes a buzz when it starts up
Probably your color wheel or a bad fan, either problem will need expert help
www.classtorations.com
Jun 08, 2008 | Samsung Televison & Video
SAMSUNG HLS5086WX/XAA
I have the same tv that i'm working on. If the two lights on the front are flashing check the switch in the back of the tv that keeps the tv from working when the cover is off. The switch is located on the back and right in the middle of the chassis. Make sure its not damaged from shipping.
Apr 26, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Black lines across page
are black lines appearing on paper after printing from computer or when a fax is sent or recieved or both?
Jan 15, 2008 | Samsung CLX 3160fn All-In-One Printer
My Samsung 50" HLS5086W wide screen tv keeps shutting off....
I am not in my shop, so, I cannot look at the schematic. The only problem I have seen with two lights blinking with this set is an intermitent thermal fuse above the lamp. Sometimes the lamp door switch is in the up position and it needs to be down (This normally occurs when the lamp door has been opened and it also comes from the factory in the wrong position. The set has a one year warranty. Contact: 1-800-SAMSUNG for a local servicer.
Aug 25, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HLS5086W - spider crack
You will need to get the screen from here:http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP67%2D00261A&search%5Fmodel=HLS5086W You should also get the service manual for this TV set, as that will show you how to disassemble the TV set. Good Luck
Jul 05, 2007 | Samsung HLP5685W 56" Rear Projection...
Samsung HLR5067WX 50" Rear Projection HDTV Logo
422 people viewed this question
Henry  Thomas
Henry Thomas
