Question about Home
I'm trying to find tuscan bronze cabinet pulls and knobs to match the Pfizer Price sink and shower faucets I purchased.I've looked everywhere. Lee Ann
  • lajollawv May 26, 2009
    I don't have a picture but I just purchased them. They are Pfiser Price and you can view them on any website that carry's Pfiser Price. The color is Tuscan Bronze.......all of their Tuscan bronze faucets are the same color.
  • 331 Answers
Hi my name is Ray
I am sure we can find what you are looking for.
Where you looking for a tuscany bronze twist or just tuscan?
Would you happen to have a picture of the Pfizer Price faucet and shower
Posted on May 26, 2009
How do I get the handle off
if it is a single handle or mixer tap
look under the handle and there will be a plastic plug ( probably red/blue ) pull that plug out and there will be a hex screw that will unscrew and allow the handle to come off
Apr 28, 2016 | Price Pfister " 808-TMYY Hanover Tub &...
How to fix delta shower single knob faucet
Take handle off (either set-screw from side or bottom of handle, or phillips screw under cap on end of handle), pull off sleeve that's behind handle, unscrew nut that holds cartridge (strap wrench works great) and pull cartridge out.
Apr 29, 2015 | Delta & Single Handle Shower Faucet
Pfister tub faucet is blocked
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
He has a very extensive list of repair parts for faucets and knowledge of how these work.
Rod
US Parts Center
Jan 29, 2013 | Price Pfister Pfister 806-dy11 Treviso...
Have a pfizer three piece faucet and the handle all the sudden is getting hard to move.
When the cartridge starts to fail it becomes hard to move like that.
Turn off the water under the sink, then remove the cartridge out of the center of the assembly. Depending on the valve system, you may need to get the proper tool.
It's a relatively simple process, but sometimes the cartridges become trapped into place with mineral deposits from the water. Just work with it a while and it will eventually come out and the new cartridge generally slips right into place.
Good luck.
Feb 19, 2011 | Price Pfister 532-7PCC Marielle Pull-Out...
Price Pfister tub/shower facuet needs much force turn on and off
put water off at mains . step 1.-open your i box mixer. step 2-u will see a 2 mm pin. mabe yours looks difrent. bt there were u change between bath and shower that button... that nob wil have a pin at the back. try to put q20/oil in there or sope. if that dosent work u will have to get a plumber in to unscrew the mixer and clean out the inside. not recomended if not a plumber bt if u do wane try it ur self and the sope and oil dident do the job let me know im a plumber will walk u threw it
Jul 04, 2010 | Price Pfister 07-81PC Savannah 2 Handle...
How do I install rough plumbing for a 015-BD0K side spray by Price Pfister?
The side spray hose has to connect through your faucet diverter. If this is not equipped with a side spray outlet you can still run splitters available at any local hardware however your side spray unit will not have any temperature control.
Feb 16, 2010 | Price Pfister 015-BD0Y Body Spray Trim Kit...
My hot water in the shower is not as hot as from the sink right next to it. I know you can adjust the flow of hot and cold in a single faucet arrangement and open the shower handle and see two brass or...
Looking in at the screws from the shower side, first, check to see if you can feel any threads sticking out from either adjuster. Try to set them the same. Counter clockwise will give you more water from the pipe you adjust. If either of your pipes are smaller or filled with more corrosion than the sink pipes, you will have impared flow. If adjusting the valve doesn't give you the desired temperature, if you have the ball type valve, the seals need to be replaced. If you have the cartridge type valve, the cartridge needs to be replaced.
Aug 13, 2009 | Delta & Single Handle Shower Faucet
My 3 handle bathtub fauset [price pfisher] cycles hot and cold
You will need to either replace center "shower diverter"assembly or a quicker fix would be to remove old tub water fill spout and replace with a "pull up diverter knob" type water spout. Cost about 10 dollars Hdepot Pull Knob to divert water to shower when showering.
jthomefix
Mar 15, 2009 | Price Pfister Ashfield Widespread Bathroom...
Home Logo
49 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
