Question about Jandy AQUALINK RS TELELINK KIT
Jandy Aqualink RSO301 keeps blowing fuse
Lightning hit blew the fuse on RSO301 PCB. It takes a 3.15 Amp but electric store said 3 Amp is ok. Replaced fuse and closed breaker, Tried several times and the fuses keep blowing. Help.
  • mbh2000 May 27, 2009
    Closer inspection showed it fried the PCB and will have to replace. Many thanks for your quick attention and assistance !
  • Samuel Charles Spriggs May 11, 2010
    If lightning "hit" this unit, the circuit board(s) are destroyed.
    A 3 amp fuse versus a 3.15 amp is not the problem. It's a short apparently caused by the lightning hit.
    Could you describe the lightning incident?
    President:
  • 1,489 Answers
Great discovery! You're welcome.
Could you please take a few and rate my assistance.
thanks...
Charlie
Posted on May 27, 2009
Reset Jandy PS6, still flashing red and green
turn off heater if ok then replace ignitor if not keep removing auxs until stops blowing breaker
Apr 02, 2014 | Jandy Aqualink Pda Ps6 Wireless Handheld...
I get no power indications to my Aqualink. I checked the circuit breakers, Any idea what is going on?
check back of PCB board fuse might be blown if keeps blowing fuses unplug all auxs then plug in 1 at a time till it blows thats whats wrong or check powersupply should be 24 volts ac on back board
Sep 23, 2012 | Jandy AQUALINK RS TELELINK KIT
My jandy rs aqualink rs8ps circuit board fuse keeps blowing. is this a problem with the transformer?
no with an aux mark all auxes wich goes where unplug all then replace fuse hook up one at a time to see which one blows fuse then check that relay and wiring maybe motor shorting out or lights got water or bad wire
Mar 19, 2011 | Jandy AquaLink RS2/6 All Button Dual...
Screen is blank ... changing to new batteries does not help?
see if voltage coming into transformer if ok check transformer for 24 volts ac at back plug of PCB board also check fuse on back of board
Jan 04, 2010 | Jandy AQUALINK RS TELELINK KIT
Power to the box but fuse keeps blowing.
Yes their are 2 fuses on a aqualink. most fuses are clear mome are white make sure the fuse was the same, becuase a white fuse will burn slower, take more heat.
Oct 03, 2009 | Jandy AQUALINK RS TELELINK KIT
My jandy pool control panel has gone dark as if it has no power. is there a fuse or something of that nature that i can check?
check the breaker that is marked rs in jandy service panel first.Then check the red terminal bar in the upper left corner of service panel. It may be unplugged or have loose or broken wires.then check the red terminal bar on the inside remote
Oct 01, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Firmware screen
shorted wire to controller or plugs if all ok bad pcb board
Jun 12, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
No power at the power panel( Aqualink RS8)
if unit comes on write down all auxs then remove plugs replace fuse turn on then plug one in at a time till it blows then you know which auw then see if wires are burnt
Apr 25, 2009 | Jandy AQUALINK RS TELELINK KIT
Jandy AQUALINK RS TELELINK KIT  Logo
861 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Craig Butler
Craig Butler
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
