Question about Fedders A7D18E7B Thru-Wall/Window Air Conditioner
No cold air.
My air conditioner sounds like it is running. but no cold air comes out . then it just shuts down.. but it won't turn off
  • 10,865 Answers
Is the air conditioner completely dead? See section 1. Is the thermostat knob turned to the proper setting? Is the compressor motor running? The compressor is a football-sized case with no apparent moving parts. It is located inside the air conditioner at the center. Is it humming or making any kind of continuous noise or causing the lights to dim? If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of these areas:
  • Compressor
  • Condenser
  • Evaporator
These items are not user serviceable. You will need to contact a qualified appliance repair technician to repair these components.
If the compressor is not running but you do have power to the air conditioner there may be a problem in one or more of these areas:
  • Compressor
  • Overload and/or relay
  • Thermostat (Open thermostat)
  • Burnt wiring
  • Bad selector switch
  • Capacitor
Posted on May 26, 2009
Go to www.Edenair.biz
Posted on Jul 03, 2009
Duo Therm A/C (2009 Sabre RV) won't shut off
bad compressor relay on control board. The relay is not opening the circuit, allowing the compressor to stay running when unit is turned off. This overheats the compressor and opens a thermal disk shutting the compressor off. When thermal disk cools down, the compressor restarts under load and trips breaker.
Jun 06, 2013 | Dometic Rooftop RV Air Conditioner
My unit is making a loud noise and is spitting water out with the cool air
i have had units turned too cold and ice forms on coils. shut unit down and take it out of window. turn /tilt and when all water runs out, re install and turn back on to a Higher , less cold setting.
Jul 29, 2012 | Hampton Bay HBLG5004 Air Conditioner
Airconditioner not getting cold
do you hear the compressor come on? shut it down for a munite or two and thenstart it back up you should hear the compressor come on with a diffrent sound thatn the fans. let me know Jon
Aug 04, 2011 | Kenmore 70088 Air Conditioner
Air conditioning cycling on and off to fast, does not seem to know when to shut off, clicking or shut off sound when it wants to shut off but doesn't it keeps running. It is blowing ice cold air.
It sounds to me like the thermostat needs replaced. If what you hear clicking noise but the unit does not shut down that is probably the problem. Thank you.
Jul 25, 2011 | Dometic Rooftop RV Air Conditioner
I have an RV with a duo therm rooftop air conditioner... when i turn the air on.. the compressor will run for a few minutes.. it blows cold air and then the compressor shuts down. Low freon??
Quite possibly low on refrigerant. Sounds like a pressure switch is shutting the comp. down after it pumps down for a few minutes. Someone will have to check the refrigerant with guages if you don't have any of your own. There should be ports to connect a set of guages near the compressor under the cover.
Apr 13, 2011 | Dometic Rooftop RV Air Conditioner
Blows cold but shuts down no freeze up
Check the capacitor. It should be a dual capacitor , runs both compressor and fan. This sounds like your problem only because both the compressor and the fan go out together. Good Luck Hope I helped
Dave
Sep 16, 2009 | Dometic Rooftop RV Air Conditioner
Ice forming on inside of unit air not cold
clean the filters and check the drain, to clear the drain run a jug of warm water down the pipe
Aug 19, 2009 | Dometic Rooftop RV Air Conditioner
Fedders wall air conditioner
If the compressor only turns on after the units it's shut off then it is a control board problem (stuck relay)
Jun 19, 2009 | Fedders AEY12F7F Wall/Window Air...
Fedders A7D18E7B Thru-Wall/Window Air Conditioner Logo
268 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
