Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
158cc yard machine, starts then dies.
This does not have a throttle just a primer. if i keep pushing the primer it will stay running.
  • 376 Answers
Your fuel tank and carb need to be removed, both cleaned and replace pump diaphragm between carb and tank. If you want to do it yourself, let me know and I;ll tell you how. Not a difficult job. Dwain
Posted on May 26, 2009
  • robert barrett May 09, 2013
    Yes... Please tell me how. Bob...
I have a Yard Machine snowthrower that starts then shuts down in a few seconds. I can keep it running if I push the primer button when it starts to die...any suggestions? I have: drained fuel and put in...
you need to remove the carb from the engine, tear down(don't worry they don't have many parts inside) and soak and then use carb cleaner or compressed air to blow out the ports insind the carb. this should solve your problem.
Nov 27, 2010 | Garden
I have a yard machine mower model number 11A-549R729 that will not stay running. Have replace plug,drain fuel tank and clean carb. If you push the primer bulb it will continue to run. But once you stop...
Your carbs main jet is blocked. Using the primer supplements the fuel input and keeps the engine from becoming fuel starved.
You need to remove the main jet and run a strand of fine wire through the jet to clear it.
Aug 17, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Starts but doesn't stay running
carb needs cleaning and also replace air filter
May 15, 2010 | Mtd Products Yard Machines 158CC Tiller
Edger will not stay running
Your diagfram is bad replace it in your carb and you will be ok
Apr 12, 2010 | Yard Machines Red Edger
My yardmachine snowblower won't stay running. It starts if I pump the primer. Fires up than dies. The fuel line isn't clogged, but once it starts it seems like the throttle cable has no tension (floats...
empty the fuel bowl & tank. start out with fresh fuel for one. then get a new spark plug if it still dont start. as far as the cable thats another deal completely but it shouldnt cause it to stall out. but if it ran last year it will this year too. always run it empty for summer storage. its your personal choice if you use a summer storage lubricant.
Feb 09, 2010 | Mtd 22" Yard Machine Push Mower
"how do i change the primer bulb on my yard machine lawn mower"
You should be able to remove the old one with a screw driver or needle nose pliers. The new one should have a new gasket with it.
Jun 17, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Tiller won't stay running
If you choke or prime the engine, it starts up for a second or two and dies, the carburetor need to be cleaned/repaired.
May 25, 2009 | Mtd Products Yard Machines 158CC Tiller
Won't stay running
Check the oil level. It may be overfull. If so, a carburetor problem may be allowing fuel to get into the crankcase.
May 18, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Can't keep mower running without consistently pushing the primer.
It sounds like there is water in the gas. The only way to remedy this is to take the carb off of the gas tank and replace the diaphragm, there is a small reservoir between the tank and carb...clean with WD-40 to remove water
Apr 05, 2009 | Mtd 22" Yard Machine Push Mower
Mower won't run....starts then stops
lawn mower only starts if i prime it. yard machine push mower. m/n 11a-549q229
Mar 01, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
972 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
