Question about Cobra 148 GTL 120-Channels Base CB Radio
Cant find 7 volt battery for dynamike plus cobra
I have a dynamike plus looking for battery 7volt can anyone help?
At a pinch you can use 5 x LR44 button cells, yes that does add up to 7.5 volts but that's near enough, the 5 cells on top of each other are exactly the same size height and width as the 7 volt battery. I am using them in a "Telex" mike
Gray
Posted on Feb 18, 2010
  • 105 Answers
Available from cpc.co.uk
Regards Al "alstech"
Posted on May 26, 2009
I put a mosfet irf 520 final kit and a swing kit in my cobra 25 ltd now i have a 40 watt radio but have run dynamike all way up ...
I believe that your installation is faulty. Check for any shorts, solder bridges, and that instructions were followed correctly.
Feb 27, 2015 | Cobra25-LTD40-Channel CB Radio with...
I have a cobra power mic that I cant identify , almost blue in color ,5 wire with a 9 volt battery . Has DM 475 on the board inside but cant find anything online about this thing . I'd like a wiri
look in the socket on the cb by the amount of pins you can work out what end you need to fit i.e. 4, 6 , 7 etc...then look up your cobra on the internet.
Dec 29, 2012 | Cobra 29 LTD CB Radio
Where can buy a dynamike switch for cobra 142gtl cb radio
the dyna mike is a control or variable resistor and most shops should be able to get it, unless removed etc they rarely fail and can easily be cleaned.
Sep 04, 2012 | Cobra Radio Communications
I can recieve but i cant transmit have new antenna and new mic
Check that your mic gain or dynamike knob is turn clockwise if it is full counter clockwise you will have no modulation with your tx power.
I would like to help but one sentence describing your problem can lead to a vague solution.
Be aware that not all 4 pin mikes are wired the same.
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Aug 28, 2011 | Cobra 29 LTD CB Radio
Dynamike bettery
Use a stack of hearing aid batteries they are about 4$ a package.
Jul 18, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Old dynamike plus wiring for a super star 3900
1-Shield
2-White
3-Red
4-Black
Check the mike plug to make sure that none of the wires have broke off.I would also check the mike cable with an ohm meter.
Jan 02, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cant transmit out
Not really enough info to help you, but you MUST check the SWR of your antenna system. I've seen many cases where the antenna studs were incorrectly installed, shorting the antennas to ground. Also, make sure the Dynamike control on the CB radio is turned fully clockwise.
Aug 23, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Works sometimes and sometimes it doesnt.
Sounds like a "cold" or broken solder connection on the PC board.
Jul 09, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
1,161 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
