Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Icemaker not working
After cleaning fridge, icemaker is not working. Everything else is fine. I turned OFF the fridge while cleaning. whirlpool
  • 6,784 Answers
In most cases, this will be a water valve inlet issue. check the water valves operational value. you can use a ohm or volt meter to test the terminal clips on the valve assembly. if the meter picks up resistance and the valve isn't allowing proper water flow, replace the valve Assembly asap.
Posted on May 26, 2009
Whirlpool side by side fridge. Everything freezing in fridge. cannot lower temp below 38. Icemaker affected with less water flow, small cubes falling through opening to produce ice
Check to see if the condenser is clean. If the coils are no free of debris, this will affect the fridge and the freezer temps. How old it it?
Oct 26, 2017 | Whirlpool Refrigerators
What would cause a very faint intermittent beep on Whirlpool refrigerator? Not all of the time. Everything works great on it. It's brand new. Beep is bugging me though.
Hi,its not like the sound when you leave the door open on the fridge door,if you are not shore try leaving the door open for a fuw momments to see if it sounds the same.
Just a thought,I hope you get it fixed it would iritate me as well.
Jun 10, 2015 | Whirlpool Refrigerators
Whirlpool fridge freezer no water getting through to icemaker
Check the line going from the back of the fridge through the freezer wall. Sometimes you can get a chunk of ice in the line. Also, did you check to make sure the solenoid valve works? Disconnect the solenoid valve outlet and when there is a demand for water, it should click and water should flow
Jan 14, 2018 | Whirlpool Refrigerators
Whirlpool top freezer 18c.ft w/ icemaker: freezer works fine. fridge does not cool below 56 degrees. vacuumed dust from bottom, turned entire unit off and restarted but still not working, in back of
i think you have to check to make sure that
the fan inside the freezer is cycling on.
it will be concealed of course but you should
be able to hear it. i replaced one once with
the same symptoms and that fixed fridge
portion of a 2002 or 3 whirlpool. make sure
to listen closely and not mistake it for the
stronger fan motor which operates in
conjunction with and nearby the compressor.
Feb 05, 2013 | Whirlpool Refrigerators
My icemaker is not dumping the ice when it's frozen.
Replacing the icemaker is neither expensive nor hard. Order a replacement on the Internet.
Sounds like a malfunction in the icemaker itself.
May 27, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water going in the ice maker but water dispener
Pour about 2/3 cup of water into icemaker . If it freezes and does not dump , replace the icemaker . Check to make sure the coils are clean of dust , lint , pet hair , etc . If it does dump , and does not refill with water , replace the water inlet valve ( piece behind refrig where the wall water line connects to on the fridge ) . Check to make sure the fill tube that fills the icemaker is not blocked with ice , still indicating a bad water inlet valve ( slow seep ) .
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool conquest fridge; freezer isn't working
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 03, 2017 | Whirlpool Freezers
Whirlpool fridge icemaker stuck upside down (side by side fridge)
it seems the ice maker cam asm is broke it will have to be replaced
Dec 20, 2008 | Refrigerators
Whirlpool refridgerator issue
YOU FIRST SOLUTION TO THE DRAIN HOLE FREEZING UP YOU NEED TO GET A TECHNICIAN TO HAVE A LOOK AND REPAIR IT,IT WILL BE BEST IF HE INSTALLS A PAD HEATER TO KEEP THE DRIP TRAY FROM ICING UP.YOUR SECOND PROBLEM YOU NEED TO SEE IF THE DRAIN HOLE IN THE FRIDGE SECTION IS NOT BLOCKED WITH ANYTHING IF SO HAVE IT CLEANED AND POUR SOME HOT WATER DOWN TO WASH OUT WAT IS IN THE DRAIN PIPE.GOOD LUCK.MOHAMED
Aug 20, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Nov 08, 2007 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
188 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
