Question about GE Profile PDS22MHR Bottom Freezer Refrigerator
Clicking of Ge Model PDS22SBRBRSS; serial No; AHO45649
This model Clicking over and Over and after 10-12 hours clicking stops. And the actual Temperature  of Freezer or Refrigerator are not displayed.Looks like working. Because food in refrigerator and freezer are OK. ALREADY DISCONNECTED electrically for 30 to 60 minutes and connected the ferrigerator. No help from this. The above problem appeared again.
NEED HELP.
  • kmandindira May 26, 2009
    Have not received any solution.
  • kmandindira May 27, 2009
    Think,the answer makes sense. Is it easy to replace the mother board?. Please give me replacement instructions of mother board which is behind the refrigerator. Need help.
  • 1,543 Answers
Replace the mother board. It is only a matter of time until you experience cooling issues.
Posted on May 26, 2009
  • Carl Schulzetenberg
    Carl Schulzetenberg May 27, 2009
    Yes, the WR55X10656 motherboard is easy to replace. It is mounted on four plastic pins, which you will see need to be squeezed to release the board from the pin. All Electrical connections are push on multi pin style plugs, plus a ground wire which is screwed to the cabinet. It is just slightly harder than changing my rating to a 4 diamond Fix-Ya.
  • folsomrn Feb 12, 2011
    Wow, 5 yr old refrig and I have to replace the MB? GE must be ****.
What's your problem?GE Model # GDL20KCSABS clicking sound Clicking sound
The clicking noise would generally be the overload on the compresser. Which means the compresser is locked up and unable to pump and needs to be replaced. Sorry You can install a 3in1 hard start which may free the compresser rotor and give you a little more time out of it but will need to be replaced eventually Good luck
Sep 08, 2012 | GE Refrigerators
Condenser fan motor not working on ge model PDS22SBRBRSS
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Oct 06, 2010 | GE Refrigerators
I have a GE side by side fridge. First the water would stop working intermittently. Then the ice and water stopped all together. Now on top of that its making a clicking noise and the freezer works for...
Your model needs attention soon to prevent damage to the control board. Something simple as a fan going bad will cause a chain reaction on your model. Let me know if you would like my assistance or your you would like to call in a technician. I can help you repair from here or my site. Thanks, Sea Breeze
Nov 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My refidgerator & freezer stopped getting cold. It is running but no cold air on both sides. (It was making a clicking noise that was coming from the circuit board on the back of the unit) but that has...
Replace the mother board. (it's the board you heard clicking) The only thing you hear running are fans. Check your model and serial number with your parts supplier, as you may be able to get the board free. (only certain models / serial numbers qualify)
Nov 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
HotPoint fridge clicks and the fan doesn't turn
14 vac indicates a bad motherboard.Clicking could possibly be a bad start relay on the compressor.
Relays are inexpensive. I would replace the relay and hope for the best. Next step would be the motherboard that GE has had trouble with from day one
Jul 21, 2009 | GE Refrigerators
Clicking of Ge Model PDS22SBRBRSS; serial No; DL047209
IF the below mentioned information does not help, then contact a elextrical engineer worksman who can check the circuit board as it might also cause a short cicuit.
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
May 31, 2009 | PDS22SFS Stainless Steel
Clicking sound - not cooling
The problem is most likely the condenser fan motor at the back-side/bottom/right of the unit. If this fan is not turning, unplug the connector to this fan (inside the protective cover on the wires near the fan)... if the clicking stops, then this fan needs to be replaced.
What is happening is that this fan has failed but continues to draw a heavy load from the circuit board... It draws enough power from the circuit board to drop the voltage on the circuit board to 5-6 volts and the relays on the board open up and disconnect the power to the fan. The the voltage jumps back up to 12-13 volts and the relays turn back on causing the voltage to drop again and the relays to open.... ON....OFF...ON...OFF..... thus the clicking!
The exact part number for this fan may vary depending on the model and serial number of your unit... My model is GBS22K-BRBBB and the fan part is WR84X10055 and should cost $60-$70 though I have seen it being sold for as much as$130.
Mar 12, 2009 | GE GBS22KBS Bottom Freezer Refrigerator
Ge side by side refrigerator
what is your serial #
Jan 06, 2008 | Refrigerators
Side by side stopped working but clicling noises every second two.
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
Dec 02, 2007 | GE GSL25JFR Brushed Steel Side by Side...
Open Questions:
See all GE Profile PDS22MHR Bottom Freezer Refrigerator Questions
GE Profile PDS22MHR Bottom Freezer Refrigerator Logo
507 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
