Question about Sharp 32C-240 32" TV
Sharp X Flat 32" started randomly changing input source last week
Can sometimes watch TV with not problems. Other times the input changes every couple of minutes. Took the batteries out of the remote and still had the problem. Repairable? Worth repairing? Paid $399 for set 4 years ago.
snakehead
  • 1074 Answers
SOURCE: tv will not cut on
there is no recall on sharp tv that i know about if your tv is still on warranty take it back to the supplier.if the warranty is finish call a tech the tv has a problem in the power supply and related circuit.good luck.
Posted on Apr 14, 2007
  • 40 Answers
SOURCE: Way too dark screen during night scenes on sharp 32" standard screen
patrioticdog-I have just answered a similar problem, you can remove the back and find the flyback transformer. The big part with the round rubber plug hooked to the pix tube. there will be two controls on the flyback one for focus one for screen. turn up the screen ever so slightly,your screen will brighten up.Also if you check the main pcboard ass'y there may be a sub bright control same thing small adjustments. maybe tell the guy to give a bit off cause of repair ,good luck let me know. cooltek Feb15/08
Posted on Feb 15, 2008
johnnydiode
  • 647 Answers
SOURCE: When I turn on my 32
A sticky input or source switch on the TV could be the problem- Why don't you hook into input 2 instead of input 1.
Posted on Oct 11, 2009
fosg2000
  • 229 Answers
SOURCE: sharp tv keeps changing the source channel on its own
you may fave a faulty switch in the key controller, may best advice is replace it
Part numbers:
KC792
XC792WJ
Fred
Posted on Jun 18, 2012
comicallyins
SOURCE: sharp tv changing channels
I put the plugs into the Input 2 for my SNES and it works now. That seems to be the solution. The TV also made a faint clicking sound.
Posted on Jan 13, 2013
I have a Sharp LCD that keeps changing inputs and will randomly turn itself on.
Sounds like you have another infared source that the LCD is seeing. Put opaque tape over the infared receiver and see if the issue continues. Look for another IR device in the area.
Nov 09, 2014 | Sharp Televison & Video
How to change pc mode of sharp into tv mode
Use the input selector to change back to TV. Usually the first input on the list.
Jun 26, 2014 | Sharp LC-32SB24U 32 in. LCD TV
32" samsung hdtv flat panel: switches when you don't want it from tv to av/pc or av to tv/pc.
Sometimes, TVs will switch to a new input when they sense a new signal on the new input. So if you're watching TV and someone turns on the AV device (or makes a change that alters or starts a video signal), the TV may switch over to that signal. This is a function of the TV. Some TVs allow you to disable this function, others do not. I looked in the manual and didn't notice where this could be enabled or disabled. If you want to only watch one source, make sure the other sources are turned off.
May 14, 2014 | Samsung LN32A330 32 in. LCD TV
Sceptre TV unexpectedly changes input source away from HDMI
My sceptre tv just started randomly changing through input modes, sometimes once or twice before stopping and sometimes it continues
Jun 30, 2012 | Sceptre X405BV-FHD3 40 in. LCD HDTV
Sharp tv keeps changing the source channel on its own
Part numbers:
KC792
XC792WJ
Fred
Jun 18, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
I have a Sharp 32 inch 720p tv, power works, no other buttons do
Unplug TV set from the outlet, wait 30 seconds, plug it back in, select right input with your remote if you using cable box or Punch the channel that you want to watch if you have cable service connected directly to the TV.
Nov 05, 2009 | Sharp LC-32SB23U 32 in. LCD TV
Blue screen, no video, but has sound
Did you hit the "input" or "video source" button by mistake on the remote or TV? That would change the input from the one the cable/video source uses. You're getting sound, so it's working......sounds as if the input was maybe changed. I'd hit the input/video source button a few times to go through all the available inputs and see if you get video back.
Dec 08, 2008 | Sharp LC-32SH20U 32 in. LCD HDTV
Sharp TV switches to "input 2"
There's an option on the menu to tuen 'demo mode' on and off. If it's set to on, that's your problem. It will be switching input sources every 2 minutes or so. Switch this off and it'll be ok again.
Feb 13, 2008 | Dual XDVD8181 Car Video Player
Mine does the exact same thing. I've had it for a few years no, and it just started doing this. It's so annoying. I don't think the weather has anything to do with it, though. It started switching itself just every once in a while, not it is almost every time I turn it on. Sometimes it takes an hour or so to start doing this, other times it's right away. Help!!
Jan 20, 2008 | Sharp 32C-240 32" TV
Protron 32 inch HDTV
I have the same problem as above - any response?
May 29, 2007 | Protron PLTV-37 37 in. LCD Television
Sharp 32C-240 32" TV Logo
230 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
