Question about Paradyne ADSL/R 6381 Router (6381-a2-200)
What is the IP address, Username and Password for the 6381-A2-200? Thanks for your help!! my website is block and i can not open it
  • 105 Answers
Hi there
ip 192.168.1.1
user Admin
Password Admin
link to manual
http://www.zhone.com/support/manuals/docs/63/6382-A2-GB20-00.pdf
Regards Al "Alstech"
Posted on May 26, 2009
How to block lan IP
IP filtering is a method used to block computers on an internal network from accessing the Internet. This is often used on critical machines on the network, such as servers. It blocks users from accessing the Internet to protect these machines from malware. You can filter IP addresses on your router using the administrator console provided by the router's manufacturer. Once the block is set up, each user machine listed in the filter settings will no longer be able to access the Internet.
Open your web browser and type in the IP address for your router. For most default settings, the IP for the router is 192.168.1.1. Enter your admin username and password. If you have not set them up, try leaving the username black and the typing "admin" for the password. Click the "Security" tab at the top of the window. This opens a new console screen. Within this screen, click the "Filter" link. A list of text boxes is shown where you enter the IP addresses you want to filter. Enter a range of IP addresses you want to block. You can enter one IP address or several. Click the "Save Settings" button. Hope this helps.
Dec 07, 2012 | D-Link DSL-2540B ADSL2/2 Modem with 4-Port...
After trying to connect my mac laptop to ethernet suddenlink had a failure at the same time. NOWI CAN NOT OPEN THE ROUTER OOR ANYTHING. jim FOUTTY
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | Linksys WRT160N Wireless Router
I have a trendnet tew-625brp, i just opened it, i can connect to it perfectly by cable howeve i want to set it up wirelessly, when i go to 192.168.10.1, i type in admin for username and password, and it...
You must complete the setup with a wired connection. Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Sep 07, 2011 | Computers & Internet
How to remove website block
Type 192.168.1.1 into the address bar of your browser. Enter your username and password (if you set it up) or try the default username:admin and default password: password. Select Block Services under content filtering on the main menu. You should see displayed on this screen blocked sites, services, and their schedules and IPs etc. Select and remove the IP/URL/Service you no longer want blocked.
Aug 22, 2011 | NetGear WNR1000 Router
What is the ip address of paradyne 6381 a3 300 router
To configure your router, open your web browser. Type the default IP address (http://192.168.1.1) into the Location field of your browser and press the Enter key. A Login screen will appear. Use the below to log into your router.
The default IP address is 192.168.1.1
The default user name is Admin
The default password is Admin
Both are case-sensitive.
Jan 08, 2010 | Paradyne ADSL/R 6381 Router (6381-a2-200)
The IP number is: 192.168.1.1.
The login info is UserID: Admin (case sensitive)
The password is Admin (case sensitive)
Also here is a link to the users manual:
http://www.zhone.com/support/manuals/docs/62/6210-A2-GB21-10.pdf
Good luck and if you found my solution to be helpful please rate it.
Apr 02, 2009 | Paradyne ADSL/R 6381 Router (6381-a2-200)
Default login information on a 6381-a3-200
first write 192.168.1.1 on address bar a login window will apear write user name and password admin
Jul 25, 2008 | Zhone Paradyne 6388-A1-200 Router
How to know the username password
connect your computer to it
go to start->run and type "cmd", press enter
type "ipconfig"
look for "default gateway..." and note the ip address(ie http://192.168.1.1)
go to your browser and type
http://192.168.1.1:8080
if that doesn't work..type
http://192.168.1.1
you can always call your isp technical support and ask them for it.
Feb 23, 2008 | Computers & Internet
Parental control
The following types of parental control can be configured on the VDI-604/VDI-624: Domain Blocking URL Blocking -------------------------------------------------------------------------------- Domain Blocking Domain Blocking will allow/deny access to certain websites. Step 1 Open a web browser and type the IP address of the VDI-604 or VDI-624 in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username and password is listed below for your version of firmware: VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing). VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password. Click OK. Step 3 Click the Advanced tab at the top and then click Parental Control on the left. Step 4 Below Parental Filters, select Domain Blocking. Step 5 Below Domain Blocking, select Allow users to access all domains except "Blocked Domains" to only allow to all websites except those listed or select Deny users to access all domains except "Permitted Domains" to only allow access to the websites listed. Step 6 Enter the website (i.e. disney.com) below the option you selected in Step 5 and then click Apply. -------------------------------------------------------------------------------- URL Blocking URL Blocking will prohibit access to websites than contain certain words. Step 1 Open a web browser and type the IP address of the VDI-604 or VDI-624 in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username and password is listed below for your version of firmware: VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing). VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password. Click OK. Step 3 Click the Advanced tab at the top and then click Parental Control on the left. Step 4 Below Parental Filters, select URL Blocking. Step 5 Below URL Blocking, select Enabled, enter the word, and then click Apply.
Feb 16, 2006 | D-Link AirPlus Xtreme Super-G DI-624...
How do I setup filters on my wireless router?
IP Filters IP filters block access to ports or a series of ports from an IP address on the LAN. For example, if you did not want the computer with IP address 192.168.0.100 to access the Internet, then you would block that IP address from accessing port 80. Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click OK. Step 3 Click the Advanced tab and then click Filters to the left. Step 4 Select IP Filters using the radio buttons. Step 5 Select the Enabled radio button. Step 6 In the first field next to IP enter the IP address you want to block access from. If you want this to apply to a range of IP addresses, then enter the ending IP address in the second field. Step 7 In the first field next to Port enter the port you want to block. To block a range of ports, enter the ending port number in the second field. Then select the protocol type (TCP, UDP, or Both) using the drop-down list next to Protocol Type. Step 8 Next to schedule select Always using the radio buttons to continuously enable this filter, or select the From radio button to set a schedule using the time and day drop-down boxes below. Step 9 Click Apply and then click Continue to save the new settings. URL Blocking URL Blocking is used to block web sites that contain certain keywords. Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click OK. Step 3 Click the Advanced tab and then click Filters to the left. Step 4 Select URL Blocking using the radio buttons. Step 5 Select Enabled using the radio buttons. Step 6 In the text box below enter a keyword to block. To delete a keyword, select it from the box below the text box, and click Delete. Step 7 Click Apply to add the keyword to the list. MAC Filters MAC Filters allow you to allow or deny access to the LAN by specifying MAC addresses. Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the (default password is blank (nothing). Click OK. Step 3 Click the Advanced tab and then click Filters to the left. Step 4 Select MAC Filters using the radio buttons. Step 5 In the section MAC Filters, select the radio button for the mode you would like to use. Disabled - Disables this feature and will allow all wireless clients to connect. Allow - Blocks all clients except for what you enter in the list. Deny - Allows all clients except for what you enter in the list. Step 6 Enter the name used to identify the entry next to Name. Step 7 Enter the Ethernet MAC address that you wish to Allow or Deny next to MAC Address. Step 8 Click Apply and then click Continue to save the new settings. Domain Blocking Domain blocking lets you allow or deny access to certain websites. Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click OK. Step 3 Click the Advanced tab and then click Filters to the left. Step 4 Select Domain Blocking using the radio buttons. Step 5 In the section Domain Blocking, select the radio button for the mode that you would like to use. Disabled - Disable this feature and will allow all clients on the LAN to access any website. Allow - Permits access to all websites except domains specified in the Blocked Domains section. Deny - Allows access only to domain specified in the Permitted Domains section. Step 6 In the Permitted Domains section, enter a domain to permit. In the Blocked Domains section, enter a domain to block. - or To delete a keyword, select it and click the Delete button. Step 7 Click Apply to add the domain the list.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Paradyne ADSL/R 6381 Router (6381-a2-200) Logo
399 people viewed this question
Top Paradyne Computers & Internet Experts
Michael Galve
Michael Galve
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
