Question about Sharp AR-235 Copier
SHARP AR-287 F2-00 error code
Machine does not reintialize and is stuck on F2-00 (toner control sensor open)
Machine called for more toner and has been refilled.
Used reinisitalize codes "14" and "16" to restart, but goes back to F2-00.
What else can we try?
  • petses May 27, 2009
    Thank you 'swan34'; can you rec repair servicer in Brooklyn 11209?
Although this appears to be an ATC (automatic toner control) problem and it may list as such in service manual which gives brief description of error code it is often something else.
There is a sponge roller at bottom of toner that wears down considerably and when the hopper is very low or out of toner the otner light will come on(triangle of dots). The customer puts the new toner in and the sudden surge of a large amount of toner cascading into the hopper causes an excessive amount of toner to go past the sponge roller and directly into the developer unit which is directly under toner hopper.
The ATC sensor is on the bottom of developing unit and "reads" the density of the developer /toner ratio and with a very overtoned situation as the one created above you would get an F2-00 code.
What is normally done is to either dump toner out of hopper and replace sponge roller and seals or replace toner hoppers as a whole which is quicker and costs almost rh same as cahnging the sponge roller and seals is more labor intensive.
Also the developer is now contaminated with an excessive amount of toner and the recommende solutin is to replace the developer and calibrate theu service program.
This is hardley recommended by a service man unfamiliar with this mode let alone the customer. I ahve been in the Bay Ridge area for years and as a matter of fact bought an investment property thru Petses Realty. Frank
Posted on Sep 03, 2009
    President:
  • Sharp Master
  • 990 Answers
Hello sir;There have nothing need to reset, the factor caused the problem is toner senser, just need toner senser replace then will take care of you.
Posted on May 26, 2009
I have a sharp AR-M355N machine and I keep getting error code F2-00, what does this mean, is there a specific fix for it
This code is Toner Control Sensor open/trouble.
Check connection of the toner control sensor.
Check connection of connector and harness to the main PWB.
Check for disconnection of harness.
If all is fine, replace the sensor.
Nov 09, 2010 | Sharp AR-M355N Copier
Sharp MX-M450N getting F2-00 error and the AR455NT toner not working.. i know it means sensor open it is a new machine and already getting error... cant find nothing in manual on how to repair this issue
F2 00 Content Toner control sensor open/sensor
trouble
Detail Toner control sensor output open
Cause Connector harness trouble
Connector disconnection
Sensor trouble
Check and
remedy
sensor.
Replace the sensor.
This is right from the service manual...one thing you can try.
1)copier must be up to ready state.
2)press #,*,clear,*(that will enter you into a simulation mode)
3)press 14, execute,yes.
4)or 14, print button.
5)press CA (clear all) button.
that should reset it to a working state without causing any damage to the copier.
Jul 29, 2010 | Sharp AR-BC260 Color Copier
Solution for SHARP AR 5127 error U2-40 call for service
This means that the cartridge's sensor is miscommunicating with the copier memory thus the code U2 -40. You should clean the inner sensor connector and the toner sensor of the spilled toner by low blower. Perform this code ;# , interrupt , C, Interrupt keys in that order and press 16 then Print key and the code will be cleared.
Feb 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
I have sharp ar-287 error ha-04. How to fix?
this sounds like you have a jam in your fuser unit.To remove this jam open the door at the left hand side,you should see a green lever to the back end lift up and take paper out,after doing this you then have to reset this error code.To enter service mode press P interupt C interupt key in 14 press start key then press CA.Photocopier should reboot if this does work then you need to get your service engineer out
Sep 15, 2009 | Sharp AR-507 Copier
F9-00 (Print Function) Error Code on Sharp AR-287
this copier will display f9-00 if the nework is not connected or the card is bad this means network connection lost usaally resting copier will work if the network is on if not call service
Mar 03, 2009 | Sharp AR-235 Copier
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
Sharp AR-287 fault code E7-11
Hello sir; The error code means there have communication problem between main board and sub board,operation board, icu board or print, my suggestion, go buy a new copier, it not worthy to repair !
Feb 27, 2009 | Sharp AR-235 Copier
Sharp AR-287 error code HR-00
The AR 287 does not have any codes that begin with "HR". Please recheck the display and post again with correct code and I will try and help you.
Dec 24, 2008 | Sharp AL-1641CS Laser Digital Copier
I want a solution for a Sharp AR - 287 Digital Image problem
H4 for an error code on all Sharps indicates that the fusing temperature isn't correct. It needs to have a new thermistor installed or the heating lamps need to be replaced.
Oct 21, 2008 | Sharp AR-235 Copier
Sharp Ar-507
An F2 code depending on the secondary code is related to the toner or drum.
F2 00 Toner control sensor open 22 LCC 24v power abnormality
02 Toner motor connector unconnected 50 Non supported option connection (Desk Unit)
31 Process control trouble (Drum surface reflection) 51 Non supported option connection (LCC Unit)
32 Process control trouble (Drum Mark) U7 00 RIC communication trouble
37 Drum marking sensor gain adjustment error U9 00 Operation control communication trouble (ICU)
39 Process thermistor breakdown
Jan 02, 2008 | Sharp AR-507 Copier
Sharp AR-235 Copier Logo
1,630 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
