Shut down-turns off after few minutes
I have an SU-G70 Technics Ampilfier. It stared out by working for hours, maybe all day, then it would just shut down, completely off. Now it's to the point it will only work for a few minutes before it turns itself off. I could get it fixed locally if I could get a schematic sheet on it. Or, if anyone has a suggestion I'm open for it.
  • mistapatch May 27, 2009
    Thanks for your reply. I was afraid of that. I have heard that the older units are repairable. Is the unit worth fixing and are parts still available for it? Or, can new updated units be found?
    Thanks Sam
  • Evans St. Romain, Jr.
    Evans St. Romain, Jr. May 11, 2010
    These things are susceptible to heat. Sounds like after it gets hot, it shuts off to protect itself from burning up. Sounds like it's done it so many times it's burned now and won't stay on any more. Have you tried running it where there is good airflow or maybe pointed a fan at it? Sounds like it may be too late but try it again where it can stay cool and see if it makes a difference.
  • 556 Answers
SOURCE: Panasonic CT-32HX42F Powers down by itself
it is due to plug or socket loose or sparking in that area. if it is ok then it is due to some component failure in power supply of tv. as per schematic is concern please go to. www.serviceinfo.com go in search & give model no.it is freely available.
Posted on Oct 06, 2007
  • 586 Answers
SOURCE: T V Shuts off by itself, after a couple of minutes.
here is some tips for ur TV which blinks 4 time.
1 Probable
Cause
Location
Solution • +13V is not supplied.
(A Board)
• IC503 voltage list is faulty.
(A Board)
Detected
Symptoms
• Has entered standby state
Solution after horizontal raster.
•Vertical deflection pulse is
stopped.
•Power line is shorted or power
supply is stopped.
this info must remady ur problem.
Posted on Dec 25, 2007
SOURCE: closing itself down DEW
camcorder when turned on flashes in red DEW and closes it self down. i have taken all the batteries out and replaced sometimes after a few days the camcorder will work then DEW will rea ppear and shut itself down
Posted on Jan 05, 2008
SOURCE: Technics SU-G70 clicks but doesn't display or sound
I just got mine back from repair shop, same symtoms, they replaced power supply, in your case it was hit and miss for a while, so maybe bad power supply connections inside.
Posted on Jan 18, 2008
  • 106 Answers
SOURCE: over heating
make sure there is nothing within several inches of it to start off. if need be, use a small house fan pointed at the amp to help cool it, if all else fails and/or you don't want to hear the noise from the big fan; get a computer fan the same size as the one in the case. connect it in place of the fan that does not work(may have to cut/splice the wires). that should work. oh, check the voltage and whether the fan is AC or DC from the stereo. this makes a huge difference!!!! if the fan says "DC" DO NOT CONNECT AN AC FAN TO IT!!! the fan will short and BLOW UP!!!
Posted on May 23, 2008
Technics su-g75 amp goes to loud static after a few minutes
Hi Aawpharmd,
system control error.
please go for repair shop.
regards,
nuwan
Jan 13, 2014 | Technics SU-G75 Amplifier
1997 Trans am Cuts off then restarts shut down later
I have experienced a car with a heat sensitive crankshaft sensor so I would opt for that as my first choice. I doubt the fuel pressure regulator would cause your problem but it could be the fuel pump or water or dirt in the fuel tank.
Nov 07, 2017 | 1995 Pontiac Firebird
I have a 2001, Panasonic 27
Suspect either bad solder connections somewhere or a issue in the power supply of the set----set will shut down for a number of reasons--it monitors voltages inside and if some go high or low it will shut down.
May 16, 2012 | Televison & Video
I had the 7 blinking lights problem after tv shut
7 blinking Defective Board (possibility)
SC, SU, SD, P board (SC,SU,SD>D,P).
Connect
the connectors SC2(*2),
and SC20 to the SC board. Remove the SU board. Turn the TV on. Does the TV power up
and stay on IF YES REPLACED SU BOARD IF ON
Install
the SU board and
Remove the SD board. Turn the TV on. Does
it power up
and stay on? IF YES REPLACED SD BOARD
Feb 03, 2010 | Panasonic TH-42PX75U 42 in. Plasma...
Technics amplifier stuck on standby mode
Hi...
If all your speakers are good ( try another set to make sure ) and theyre connected good at both ends but your amp is not-being-nice, I would say that it's either a blown output module/output transistors
Apr 07, 2009 | Technics Audio Players & Recorders
Jan 04, 2008 | Audio Players & Recorders
Tv shuts down
does the main board have the flyback on it? if so the yokes or CRTs can be intermittently shorting which in turn triggers your shut-down.
turning it off or unplugging just resets the shut down circuit.
Sep 04, 2007 | Samsung HL-R4266W 42" HDTV-Ready...
150 people viewed this question
 Grubhead
Grubhead
