Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
F 51. I know its a fault.
What does it mean????
  • 3 more comments
  • elishaman Nov 16, 2007
    I am getting a F51 code on my Cabrio washer. Can you please tell me how to check the sensor and repair the problem?
  • biglefty Dec 03, 2007
    Our cabrio is giving us a F51 code when we use the normal cycle, the sheets cycle and the quick wash cycle. I don't think we have warranty on it anymore. Can you please walk us through on how we can resolve this issue with this machine?
  • Anonymous May 21, 2008
    I am getting the F51 Error code on my Whirlpool Cabrio Washer. It is just over a year old. Please tell me how I might be able to fix.
    Thanks, Dave
  • Anonymous May 24, 2008
    I am getting a F51 code and i only used my machine 2 times. Should i have my machine replaced? Is this a Good machine?
  • jlstrief Jun 03, 2008
    F51 error on my 18 month old washer. How can this be fixed?
  • 290 Answers
It is a rotor position sensor code. The control is no longer recieving a signal from the motor. It can be a failed sensor or control, but usually it is a bad connection where the wires plug on to the sensor. If the machine is less than a year old, it will be repaired in warranty. If not, post back and I will try to walk you through the repair if you want to try it.
Posted on Oct 21, 2007
  • Michael  Lindley
    Michael Lindley Oct 21, 2007
    Thanks for rating my answer. Since you rated it almost solved, I assume you want more information. What would you like to know about the F 51 code?
Posted on Jul 31, 2009
Our machine is over a year old and this is getting very agrravating, would you please post directions on how check and repair if necessary. Thanks!
Posted on May 28, 2008
  • 18 Answers
U need part # W10130544.
Posted on May 10, 2008
How to repair if engine cannot race up when vehicle is running in Toyota Model KDN190R-CRPSYT vehicle?
If it is a Tercel or MR2, it is T and E1 terminals. Code 21 is main oxygen sensor signal fault. Code 51 is A/C signal on; DL contact off (in transmission shifter with diagnostic connector jumped). I have no idea what that 51 means.
May 28, 2015 | Toyota Cars & Trucks
What is Technical Fault 51?
The most common reason for this code is :-
F51 error is caused by a faulty or blocked heater pressure switch. It is not a job for an unqualified person.
"The program is interrupted and the drain pump is operated. The display shows Technical fault F51. Call Service Department. The buzzer is activated for 2 minutes. "
Apr 14, 2015 | Washing Machines
What does fault code 51 mean
if you have a 51 fault the machine must be a diverter valve model machine which has a water save function,check the diverter has nothing jammed in it and that the soleniod is ok with a multi meter if it passes both checks then it your main computer board
Sep 30, 2014 | Fisher and Paykel Fisher & Paykel Washer
Washing machine comes up with code fault 51. Could you please explain?
Hi just read your posting.The error code you have indicated is called RECIRCULATION FAULT.This means that when your machine is on the recirculation mode it is losing water.Please look under the machine for me to confirm which pump style you have in your model of machine.If you see a black fan to the front right you have the older style.Please reply and let me know if you have the older pump or newer pump.If you have the new style of pump then you will not have the black fan.This information will help me guide you in rectifying this fault.Looking forward to your reply.
Sep 20, 2010 | Fisher Paykel Eco IWL16
What does fault code 51 mean?
Error code 51 usually means a faulty diverter valve. Try and run a wash cycle, and observe the drain hose. If water comes out, the diverter valve should be fine, if no water comes out you should take your diverter valve out and check for debris, or continue to read through the following possibilities of why your washing machine is acting up, and the actions to take.
1. Diverter valve
Action - Check diverter valve continuity. If open circuit, replace diverter valve.
2. Motor Controller Board (drive circuitry blown).
Action - Replace Motor Controller Board
3. Diverter valve harness/connectors.
Action - Replace wiring harness
Jul 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Error code 51? F & F intuitive washer
Hi just read your posting.Error code 51 means you have a Recirculation Fault.This means while the machine is filling or washing it loses water.Error code 37 means you have Pump Block error which means the machine is not draining.Please look under the machine to the front right and you should see a pump with a red or black fan attached.Can you confirm this please? I think there is a problem with your diverter valve and the information on your type of pump will help me rectify this problem for you.Please reply with additional information on the type of pump in your machine.Looking forward to your reply.
Jul 01, 2010 | Fisher and Paykel Washing Machines
Airbag dash light flashing code 51
Common fault on FORD
Usually due to a poor connection in the YELLOW PLASTIC CONNECTOR underneath the passenger seat.
Just push it together properly and it should clear the AirBag fault
May 18, 2009 | 2003 Ford Focus
Fisher&Paykel Intuitive eco IWL 16 Auto washer Fault code 51
Our washer did the same but it was after I took the excess drain hose and pushed it into the drain in the wall. I thought it looked "more tidy" In doing so I created a siphon effect. Once I pulled the excess hose back out it was fine.
Jan 23, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washer full and then stops and gives a beep while flashing F 51
On Kenmore F51 means Motor RPS Failure, the motor is not spinning or the motor sensor detects a fault.First unplug the power cord for one hour or so to check if it is a jammed sensor, and see if reset.
Dec 06, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
685 people viewed this question
Dan Webster
Dan Webster
Sal De
