Question about E-Machines eMachines Desktop PC
I deleted programs and i think I deleted a driver becuz when I restarted computer I got blank screen that read "cannot display this video mode". How can I fix it?
I was deleting programs and I think I deleted a driver for my monitor because when I restart I get a blank screen that says - Cannot Display This video Mode. Any idea how I can get back onto my computer to restore back to original settings?
  • 105 Answers
Hi there
bring your pc up in safe mode by pressing f8 untill you get the start up menu then select safe mode once the pc is up rght click on a blank area of the desktop .select properties ,settings, then advanced change the refresh rate down to 60hz then restart as normal your pc should now display
Regards Al "alstech"
Posted on May 26, 2009
No screen display after resolution change
Restart your computer press F8 key from the displayed option select safe mode. After entering in to the safe mode go to device manager in my computer property, Hardware option. In that remove the display driver and restart your PC.
Sep 30, 2010 | Computers & Internet
I have a sony vaio vgn-ls25e all in one pc,the problem is when i intall it the video card drivers when the pc restart the pc goes in blank i have to run the pc on a recovery mode to delete the drivers and...
Check Sony's website and look for a support section, you can most often find manufacturer's drivers on the site. If not check out the computer specifications on google and look for the display chipset or the graphics controller it's either somthing with one of 3 things ATI, nVidia, or Intel Extreme. Then you can find a driver support site like driverguide.com and then load the drivers through there. it is free if you don't mind viewing an add or 2 and is pretty good with driver support. Do not use a program like driver detective most programs may identify a device but will charge you money to install the driver for you. My best suggestion, look for drivers on sony's website.
Apr 06, 2010 | Computers & Internet
When I try to use my 17'' Soyo monitor with Windows 7 program the screen turns black and then ''out of range'' wording is all I get on the monitor. I have tried booting in safe mode, set the resolution to...
When you power up the compute press F8 key then enter in :"Enable vga mode" then go to display property and set screen resolution to 1024*768.
Then check .
If still same then enter in safe mode and uninstall graphic driver then start computer normal mode then install graphic driver.
Also in safe mode go to start->run type in run "chkdsk /r" then press ok then press "y" then restart computer then it fix and recovers error on harddrive.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 23, 2010 | Soyo Dymond DYLM017A 17" LCD Monitor
No input signal at the monitor when I plug it to a laptop, only when in safe mode I can see the desktop of laptop
When you power up the computer press F8 key then you can see safe mode and other menu enter in "enable VGA mode"
Then go to start ->control panel ->display- settings.
Change screen resolution to 1024*768
Then apply and ok.
then restart then check.
If you still get blank screen then enter in safe mode and uninstall graphic driver from control panel -> add remove program wizard or device manager.
Thanks.
Nov 04, 2009 | Westinghouse L1975NW Monitor
Sony VGC-LS35E BLANK SCREEN
Do you mean after windows has booted you have a blank screen?
Boot into windows in safe mode (by pressing F8) during the boot up process.
When booted go into device manager and remove any video drivers under display adapters, if it asks to delete the files as well answer yes.
Reboot into normal mode and let windows find the driver for you.
Apr 19, 2009 | Sony Computers & Internet
My HP monitor (f50) has malfunctioned
Try these 2 steps if they don't work get back to me :)
Step 1. Connect the video cable and turn on the computer. What happens?
  • If the monitor screen remains blank (no startup screens or onscreen display messages), the monitor must be connected to another computer using a different cable to determine if the monitor is bad. Skip to the Step to connect the monitor to another computer.
  • If the monitor is capable of displaying boot screens but is unable to display Windows, use the following steps to set the computer to a compatible resolution:
    NOTE: Find the native display resolution for your monitor in the User Manual or in the product specifications for the monitor model. If you are unable to find the native display resolution for your monitor model, temporarily use 1024x768 for troubleshooting purposes.
    1. Turn on the computer and press the F8 key repeatedly when the first startup screen appears.
    2. If you are using Windows Vista, select Enable low resolution video (640 x 480) , press Enter , and wait until Windows opens. To set display settings that match the monitor, use the steps in the HP support document, Changing Display Settings, Background Image, and Screen Saver in Windows Vista . If you are using Windows XP, select Enable VGA Mode , press Enter , and wait until Windows opens. Continue using these steps to set display resolution. If you are using Windows 98 or ME, select Safe Mode and perform the following steps to enter into a standard VGA mode:
      1. Once Windows opens to the desktop in Safe Mode, click Start , and Run .
      2. In the Open field type msconfig and press Enter . The MS Configuration Utility window appears.
      3. Click the Advanced button, and select VGA 640 x 480 x 16 if it is available.
      4. Click OK and restart the computer.
      5. After Windows opens, click Start , and then click Run .
      6. In the Open field type msconfig and press Enter .
      7. Click the Advanced button, and remove the checkmark next to VGA 640 x 480 x 16 .
      8. Click OK . Do NOT restart the computer.
    3. After Windows opens, right-click on an open area of the desktop and select Properties (Windows XP, 98/Me) or Personalize (Windows Vista).
    4. In Windows Vista, Scroll down and click Display Properties . In Windows XP, 98, or Me, click the Settings tab.
    5. In Windows Vista, select the native display resolution size using the Resolution slider. Set Colors to Highest (32 bit) . In Windows XP, select the native display resolution size using the Screen resolution slider. Set Color Quality to Highest (32 bit) . In Windows 98 or Me, select the native display resolution size using the Screen Area slider. Set Colors to True Color .
    6. Click Apply after you have made your adjustment. The screen should blank out temporarily and come back.
    7. If you are satisfied with the new display settings, click Yes on the Monitor Settings windows. If you are not satisfied or if the screen just goes black, wait: Windows sets the screen back to the way it was before. Try another setting until you find a display configuration that is compatible with the monitor and meets your needs.
      NOTE: If the native resolution is not available, download and install updated video driver software for your computer. Updating the video driver software can add more resolutions (graphics modes).
    8. Restart the computer. The monitor should now display a full screen image in high quality. You are done.
Step 2: Connect to another monitor
Using a different cable, connect the monitor to another computer that has video. Turn on the monitor and the newly connected computer. What happens?
  • If the monitor works, the video hardware on the original computer is likely to be the source of the problems. You can try connecting the original computer to another monitor that works to update its video drivers.
  • If the monitor remains blank, repair or replace the monitor.
Dec 27, 2008 | HP Pavilion F50 17" Flat Panel LCD Monitor
Screen blank
Sounds like its simply going into power save mode. Does your screen come back on when you move the mouse or press a key on the keyboard? Is the computer still on? Check your power options in control panel.
Nov 29, 2008 | Computers & Internet
Monitor won't stay on. Error message comes up that says "no input signal", then monitor goes out.
Problem with the monitor, monitor cable, or video output. For monitor, if you have more than one input, make sure it's set to the correct one. Try a different cable. Try a different monitor. Check your video card settings--if you see the BIOS bootup screen while it's coming up then the Windows splash screen, then monitor blanks out, it's a Windows display setting. Boot into safe mode, then change settings--
  • Turn the computer on or Restart the computer
  • Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected (the top option)
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with troubleshooting, close all programs and restart the computer as you normally would.
Oct 31, 2008 | HP Computers & Internet
Stupid blank screen on my Craptop
Could be a simple video driver problem, try starting up your laptop in safe mode (Pressing F8 on boot up). If and when screen comes up highlight 'Start Windows in Safe Mode' Next a list of startup drivers etc will stream down the screen and tell you you are starting in safe mode, allow this. If your lcd screen stays on then it's a driver problem, go to add/remove programmes and uninstall driver the driver and restart your laptop. This should then start in VGA mode all icons will be bigger than normal. Either re-install video drivers from setup/restore disk or go to laptops manufacturer website to download drivers. If no screen even in safe mode LCD probably dead. Please rate solution.
Nov 15, 2006 | Syntax ValueBook VT5000 PC Notebook
E-Machines eMachines Desktop PC Logo
59 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
