Question about Sony PlayStation 2 (PS2) Console
My PS2 won't run my games.
My playstation 2 used to play games fine. Now, whenever i put in a game and turn on the concole, the PS2 menu pops up but it doesn't run the game. What can i do to fix this?
  • 6,784 Answers
HI, you will need to preform a lens cleansing by using a cleaning disc. try to recover lens function be cleaning the lens with a good len cleaning disc. if the lens cleaner dose not fix this issue, this will confirm optical lens assembly failure and, you will need to replace the lens assembly in this case.
Just to make sure that this isn't a control fault, unplug the PS2 for 5 minutes. if the unit still freezes up or , the unit will not play the disc, replace the optical lens assembly.
Posted on May 26, 2009
My PS2 is not loading Grand Turirsmo 4!
If your PS2 works fine with most of the games and won’t play a few..Then you should try this trick to play them too on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:6e4cb56.jpg
  3. Press the (triangle) Button to enter Version Information Menu that looks like9d90dc8.jpg
  4. Highlight the Play Station Driver as above and again press (triangle).
  6. Highlight the Disc Speed as above and press X button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the game loads itself. If your lens is in good condition then it will play game in first go else try again till it PLAY your game. If still your Grand Turismo 4 DVD wont work then you must clean your PS2 lens.Watch following video to learn about cleaning lens:
Thank you and Good Luck!
Dec 16, 2009 | Sony PlayStation 2 (PS2) Console
How to fix my playstation 2 that won t read grand theft auto san adreas
Your console is an old one,and your lens too is probably weak.Try cleaning your PS2 lens Watch Video at end of solution to clean your PS2 at home....
You can also follow these steps to make your PS2 to play GTA San Andreas:
  2. On menu screen go to [options] by pressing 'triangle' button.
  3. A new screen will appear select by pressing 'X' [DISC SPEED]and set it to [FAST]
  4. Then insert the game disc.
  5. Turn off your PS2.
  6. Press and Hold the [Reset Button] till the blue light turns on.Release the Reset button and press it again.
It will take a bit more time to play game,but first i recommend you to clean your PS2 lens,watch this video.
I've got something else to add.......you can follow above steps to play DVD movies if your PS2 dont play any.....!!!
Nov 19, 2009 | Sony PlayStation 2 (PS2) Console
IT WILL PLAY A MUSIC DISC, BUT WILL NOT PLAY A VIDEO OR GAME DISC
it might need a clean out try takeing the back off and getting a little paint brush and brush it down
Jun 07, 2009 | Sony PlayStation 2 (PS2) Console
Playstation 2 will load the game, but then only show black screen
You might of had one of the wires connected from the TV to the PS2 damaged and may need new ones or just make sure that the wires connecting each other from the TV to the PS2 are well connected. My little brother use to drop my PS2 a lot too and that happened to me once, but it turned out to only be that the wire got pulled too much when it fell and it disconnected from the TV to the PS2 and I had to only put it in well.
Apr 07, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 reads all other games except guitar hero world tour.
To all you guys having this problem with PS2 - I bought World Tour for my brother and put it in this morning. It worked the 1st time we put it on, but we restarted the game because both guitars weren't connected, and it would NOT work after that (we have an old fat PS2 by the way). After reading online, I found out this disc is a Dual Layered DVD, and can cause problems reading it
Here's what I did to fix it - I took out all 8 screws on the bottom of the PS2, popped the case off, and then took out the 2 tiny screws for the DVD drive. After taking that case off, you can see the laser lens. All I did was clean it with an alcohol-soaked Q-tip, then buffed it clean, and after turning the game back on - it works fine! We're so pumped over here, and to anyone else having the problem, I bet this will fix it! Good luck!
Nov 22, 2008 | Sony PlayStation 2 (PS2) Console
Wont play games or movies
my playstation wont play ps3 games but it will play movies and ps2 games.if i put a ps3 game in it frezzes...
Sep 19, 2008 | Sony Playstation 3 (PS3) Console
Playstation 2 stopped working
It sounds like the disk reader could be damaged. PS2 is an old console so I think it is just dying. You could try this. How to Fix PS2 Disk Read Errors
Mar 12, 2017 | Sony PlayStation 2 (PS2) Console
Playstation 2 USB + HDD
actually the USB port on the PS2 is for game paraphernalias like ps2 keyboard or ps2 webcam and other accesories and it also depends on the game
if you're trying to play a game saved on an HDD using the USB, it really won't work
Jun 17, 2008 | Sony PlayStation 2 (PS2) Console
Game concol
Simple your games a different region.
You need a Disk called swap-magic or similar, Or get a modchip fitted.
Mike @ compurepair.
Mar 29, 2008 | Sony PlayStation 2 (PS2) Console
Can't play a different game immediately after playing one game
It is best when finished with one game and moving to another game to reset your PS2 console before starting the new game. This way your sure to have fresh uninteruppted memory.
Dec 03, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
99 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
