Question about Graco Pack 'n Play
Problems re opening the Graco Pack N Play - one side won't lock
There are bottons in the middle of the pack n play side that you need to push to collapse the sides. After doing this and packing it up I traveled to the sitters and tried to reopen it. It doesn't seem to want to open. Should I force it or am I missing something? Thanks One side of our pack and play will not lock. Any suggestions? We know how to set it up, but only one side will not lock. The brand is Graco. Thanks Lynn
  • 125 Answers
If so try always from turnig and pulling up the center and then with some help squeeze pulling up the side of each pack. then try to push everything down.
it's treaky and coming back blocked very fast. you have to manage all of them at the same time
Good luck
Pls let me know if I helped
Posted on Oct 06, 2009
    New Friend:
Thank you!!!! @Blondemechan I was ready to trash this until I found your advice to keep the center up and lock it the sides. This Grandma is now a happy camper.
Posted on Jun 01, 2014
2 Suggested Answers
  • 72 Answers
SOURCE: Problems re opening the Graco Pack N Play
you have to pop the sides up before you push the bottom down. when you first start to put it up let the sides fall but keep the middle up. then grab the middle of sides, either length wise or width, one in right hand, opposite side in left hand and snap up. then do the same with the other two sides....then spread out four corners and press down on the center. if you let the center down at all first, the sides will never lock. Also check your lot # there was a recall on some of them
Posted on Mar 21, 2009
Graco posey pack n play side won't lock in
I've had this problem b4 and all I had to do was to **** it up really hard and fast, then it would catch and lock. Hopefully it will work for you too. Good luck! :)
Jul 11, 2012 | Graco - Pack N Play with Newborn Napper -...
Cannot get the grayco pack and play sides and ends to raese back up
did you read the directions? the bottom part needs to not be all the way down when the sides lock open try and pull the sides up with the bottom not locked down then after the sides are up the bottom can be pushed down.
Mar 12, 2011 | Graco - Pack N Play with Newborn Napper -...
I have a pack and play that will not lock at the bottom and i was wondering if there was any way someone could help me
the center of the pen must be up the do the sides while the middle is up then push the center down.
Jan 26, 2011 | Graco Pack 'n Play
We cannot breakdown our pack and play. How do we get the top rails down?
In order to break down the top of your Graco Pack 'n Play, you must find the middle of the bars. It's easiest to collapse the the shorter ends first. The middle of the bars should have a nodule. Squeeze that nodule and pull up on the side, sometimes you may have to do this firmly and **** the side. When the first side collapses, repeat for all sides. Once they are collapsed, pull up on the bottom of the Pack 'n Play, and it will fold together.
Dec 07, 2010 | Graco Pack 'n Play
How do you put up a graco pack play
Hi, to set up the pack and play, first latch each of the four sides together. (Each side rail latches together in the middle -- just straighten the rail.) Once all four sides are locked and straight, push down on the center of the pack and play bottom (it's probably red) until it snaps into place.
To fold the pack and play up, just follow these instructions in reverse -- pull the bottom up first, then press in the button on each side rail to fold up each side.
Always make sure the pack and play is completely set up and locked before putting a child in it!
Aug 02, 2010 | Graco 9445DOH Crib
How cani open graco play pen
To open the Graco Pack 'n Play from the folded position, you have to latch each side rail by pushing the two ends of each rail until they are horizontal and form a straight line. They will latch into place with an audible snap -- do this for each of the four sides. Then push the center of the Pack 'n Play's floor down until it is flat as well.
If you can't latch the side rails, the floor of the Pack 'n Play might be down too far. Push the floor up until its center reaches at least halfway up the sides of the Pack 'n Play. (You can do this by pushing the sides of the Pack 'n Play in toward each other.)
Were you able to open it using these instructions?
Jun 24, 2010 | Graco Pack 'n Play
DIRECTIONS FOR GRACO PACK 'N' PLAY
pull and turn the center of it then try to open the side lock. they have to be horisontal from both side of each
Good luck
Sep 09, 2009 | Graco Pack 'n Play
Mar 13, 2009 | Graco Pack 'n Play
Pakc & play set up
I had the same problem with the pack & play that I used for my youngest. It turns out that the centerpiece (looks like an extra leg for support of the pad) needed to be pushed all way down, where the leg was resting firmly on the ground, before you lock the sides. When it was time to fold the pack & play back up, you have to pull the middle up first for it to unlock properly.
I hope this helped!
Jan 13, 2008 | Graco Quattro Tour Kentshire Stroller
Graco Pack 'n Play Logo
3,415 people viewed this question
Top Graco Toys Experts
thegtw
ray gallant
Tom Chichester
Are you a Graco Toy Expert? Answer questions, earn points and help others
