Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 washer that spins but clothes are still too wet...
I have a Kenmore 80 series washer that seems to be functioning properly as far as it following the correct cycles and draining, etc. but it doesn't seem to be spinning out the clothes completely. It is most noticeable with heavier items such as jeans and towels.
Any suggestions as to what may be causing the issue? Thanks so much!
  • PrettyInPink
    PrettyInPink May 27, 2009
    It is not spitting any oil thank goodness. Is it likely that the transmission will go out very soon as well?
  • 89 Answers
To me this sounds like a clutch,
or possibly worse, your transmission that is spitting oil onto your clutch
lift the front of the washer and check to see if there is a puddle of oil on the ground. if so, its most likely your transmission. and a clutch would be a temporary fix
but if no puddle, it is most likely just the clutch that needs replacing
Posted on May 27, 2009
  • slypp187 May 27, 2009
    no, the transmissions in those are bullet proof,
    the only reason you would ever need to change your transmission is if it is leaking too much oil, and you change it only because the clutch will keep wearing out.
    those transmissions are capable of running with almost no oil in them at all. the oil is 90% for noise reduction 10% lubrication.
    you issue is most likely the clutch 95% sure.
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Kenmore 80 Series Mod:110.23832100 top load that with heavy clothes (towells robes) won't drain and leaves excessive water after spin cycle. Everything appears to function otherwise, no odd noises. No...
When you are putting the heavy clothes (towels robes) the sleeves of the towels will come out easily and get stuck in between the drain out valve so it will not sent the water out properly please avoid heavy clothes(towels robes) try to give a normal load
Dec 23, 2009 | Kenmore 15864/15862 Top Load Washer
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Kenmore 80 series washer not completly spinning clothes dry
Belt going..
A bit of a pain to replace, but doable..
Belt dressing will keep it going for a while..
Dont get your fingers caught in it..
Serious injury is possible, unplug the machine
and stand on the plug while moving the
belt to goop it..
(why? that way it cant get plugged in!)
Feb 07, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
306 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
