Question about Acer AL1717 17" LCD Monitor
Need to turn off internal audio on flat screen to use headset
I want to turn off the internal speaker on my Acer AL1717 flat screen monitor so that i can use the headset.
  • Marcos Anguiano
    Marcos Anguiano May 11, 2010
    is there a green audio jack goin from back of pc to monitor?
    Scholar:
  • 89 Answers
When you plug in a headset or mic into the bottom or the side of the monitor, this should automaticly disable the internal speakers on the monitor.
Posted on May 26, 2009
Why in my Acer monitor AL1717 comes vertical lines in middle of the screen ?
Try updating your display driver and also try with another monitor cable, in case its broken.
Apr 28, 2014 | Acer AL1717 17" LCD Monitor
How do I turn on the Acer AL1717 speakers?
the internal speakers, RTM it tells you how.
you plug them in to the PC, audio part conn.
then unmute the audio.
then up the volume.
also RTM the monitor OSD may have speaker enable , selection.
that is it.
Sep 26, 2013 | Acer 17" AL1717 Flat Panel Color LCD...
My AL1717 monitor shows a flickering power signal (blinks off & on) but shows black screen and nothing else. Thank You
Most likely a problem with internal capacitors either blown or swelling or leaking. Can be repaired by replacing the faulty capacitors but recommended that this be carried out be a qualifed technician
Dec 30, 2010 | Acer AL1717 17" LCD Monitor
Why does it take so long to see my desktop icons when I power on my Acer AL1717 monitor?
bsellers, Tell me in "seconds", "minutes", how long is "so long". Do you even see the "boot screen" pop-up when booting the pc? You should see that first if lcd monitor is turned on first. Are you running a Windows OS? Will a "known-good" VGA monitor work ok when connected to your PC?? Will your AL1717 do same thing when connected to different "known-good" PC?? Did you even look at the "date of manufacture" on the rear of your monitor? Retrevo .com lists 1717 as time to retire??? Was your unit produced in "06" or "07"?? Let me know results of doing some simple "swap-out" tests. 12fixlouie
Dec 15, 2010 | Acer AL1717 17" LCD Monitor
How do i activate built in monitor speakers
connecet audio jack between your acer monitor & your CPU audio output.
Oct 25, 2010 | Acer AL1717 17" LCD Monitor
Vertical Red Line down the screen of my Acer Al1717.
Try hooking an external monitor. If it will still show on the other display, possibly it is a video card problem. But I highly doubt it. Usually for this issue, it will have a good display on an external monitor. Try if it will still appear n the BIOS page. Press F2 several times immediately after turning the computer on. If problem still shows there, then it is the LCD that is causing it to happen. You need to replace the LCD.
Sep 21, 2010 | Acer 17" AL1717 Flat Panel Color LCD...
Built in speakers do not work
Have you connected them to the pc's sound card - it doesnt go through the video cable.
Apr 24, 2009 | Acer AL1717-BBMD 17" LCD Flat Panel...
Black lines in Acer AL1717
On the power supply PCB are two 25V 220uf capacitors that will be leading. Replace them and the picture should be back to normal.
Dec 28, 2008 | Acer AL1717 17" LCD Monitor
Frequency disturbance at monitor
evidently there is a loose connection within one of the ribbon cables going to the screen, you will have to open the monitor and reseat them.
otherwise quit using the internal speakers as the vibration may kill the monitor dead.
Feb 15, 2008 | Acer AL1717 17" LCD Monitor
No audio
Hi
Pls check if the audio settings on the monitor are correct. Along with the monitor menu button, there will be another button for audio for some models. For other models the audio option will be available in the menu button itself.
Pls check with another set of powered speakers and not headphones.
Also check for the drivers and any driver updates for your sound card.
Hope this helps fix your problem.
Jan 28, 2008 | Acer AL1717 17" LCD Monitor
Acer AL1717 17" LCD Monitor Logo
205 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
