I've replaced the shocks and made sure it is level.
Reminds me of a old car I used to have lol
sorry about that.
Try making sure your load is spread evenly inside.
If it is then and it's perfectly level the the barrel is out of balance
you would need to pull it apart to see where it's knocking.
Sometimes it's as simple as getting a spirit level and just levelling it off both front and horizontal
SOURCE: thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
SOURCE: my kenmore 417.42042100 model front
Here's what the problem is.
http://www.youtube.com/watch?v=UwpKP_9_fAA&feature=player_embedded
It's been designed to fail so that you buy an expensive part.
SOURCE: Our new GE front load washer shakes/ vibrates and
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
