Question about Mitsubishi VS-50607 50" Rear Projection Television
Mitsubishi VS50607 Self Diagnosis 2-3
I've read All the boards can't really determine how to fix. Should I do this:MitsubishiDMRepair  or this: SelfDiagnosis2-3. My TV has rolling horizontal lines in the picture and is blinking error code 2-3. I have the service manual, just need someone to point me in the right direction. What parts need to be replaced? And any tips or shortcuts would be greatly appreciated. Thanks!
I have a mitsubishi vs 50607 50in. TV
While watching tv it has started shutting off then in a few minutes I can turn it back on untill it does it again sometimes in a few minutes sometimes longer before I can get it to come back on.
Posted on Oct 18, 2008
  1. Turn on your TV. If he TV request your secret code press QV and 9 at the same time.
  2. Press menu to view the main menu.
  3. Use up or down key to select "Chip Parent Lock" and press enter.
  4. The on screen display wil ask for your current passcode. Press QV and 9 at the same time.
  5. The on-screen display will now ask you to enter a new code.
  6. To cancel the passcode permanenly, press menu or home.
  7. To change to a new passcode, use the number buttons to enter a new code, then press enter.
  8. You must use the remote control included with thisTV. You cannot use a universal remote.
Posted on Nov 10, 2007
  • fixitforcash Nov 10, 2007
    fixitforcash posted solution for unlock code on wrong repair question. sorry.
My Mitsubishi WD-52725 will turn off while watching and the lamp led will go red. It will sometimes come back on without unplugging and sometimes you must unplug wait 2 minutes and the plug back in. I...
Thats a common symptom of when the power board capacitors fail. It will make the lamp light turn red and a self diagnosis 34 for lamp abnormality. Usually install the power board repair kit will solve that issue. Heres a link to the power board repair kit for your model. The kit contains the capacitors and detailed instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Jul 11, 2009 | Mitsubishi WD-52725 52". Rear Projection...
HOW DO I FIX THE RED FLASHING LIGHT PROBLEM IN SELF DIAGNOSIS MODE
if your TV is a mitsubishi thats the code for short protect which is most often related to the convergence Ics having shorted especiallif its a WS55809. Post your model number and I can assist you with determining whats wrong.
May 20, 2009 | Televison & Video
Wont turn on
I'm not a tech but I read the self diagnostic repeats itself 5 times. That being said I think it is telling of a 2-2 problem. A result of 2-2 is a short protect problem. Hope that helps.
Dec 04, 2007 | Mitsubishi WS-65819 TV
Self-diagnosis
2-4 is already listed you have to read the threads to keep from causing a repeat of the same fix.
Oct 07, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Where is the Dm board? Does anyone have a picture for this model
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT.
Sep 07, 2007 | Mitsubishi WS-65611 65" Rear Projection...
PROBLEM WITH MITSUBISHI WS 55411
I had the same problem with my model as well. Luckily, I had the extended warranty and a technician came out and said that many people with TVs of this model have the same problem. He replaced the main system board and the problem was fixed. It has been about 4 months now and the problem just came back again. My TV is out of warranty now, but I hope I can get a warranty on that newly replaced party which appears to have gone bad again.
Sep 06, 2007 | Mitsubishi WS-55513 55" Rear Projection...
WS-55315 with only red bulb
It seems that you donot have the 200+ V line for the GREEN,BLUE. This line is the same as the read line, check connectors located on crt boards make sure they did not come apart. Also you can:This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB
Aug 24, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi vs50605 turn on and dhuts down and light flashes 3 time
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Mar 29, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-45607 picture goes out intermittently
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
Dec 13, 2006 | Mitsubishi VS-45607 45" Rear Projection...
VS50607 Mitsubishi
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.....
Sep 24, 2006 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
675 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
