Question about Kenmore Elite Oasis 27052 Top Load Washer
Error code CI
I have a Kenmore Elite Calypso top loader that worked fine. Then, a new load went in and the machine made draining sounds for 10 seconds and flashed CI. What does this mean and how can I make the machine work again? Thanks, bv
  • 15,935 Answers
The ?Cl? fault indicates that there was an instantaneous current spike of 26 amps at the motor windings in the washer. This could be caused by overloading the washer. It can also be caused by problems with the drive motor, thermal protector or the motor controller.You should have been able to clear the display by pressing the STOP/CANCEL button.
If you try running the washer again and continue to get this fault code even with a small or medium load, I recommend calling a service technician to diagnose and repair the washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Kenmore Elite Calypso top loader and error code ce
Com error between control and motor. See page 51. Check for corrosion on the pins at the quick connect. Check for broken wires
Sep 16, 2011 | Kenmore Elite HE4 Electric Dryer
Error code FL and does not drain completly
most probably needs the water pump replaced.  not hard to do if you are a little handy..  there were a lot of problems with this machine regarding the water pumps.
Jul 22, 2010 | Kenmore Washing Machines
Kenmore elite calypso model 22086102 will not clean clothes.Detergent is same. Getting a CI error code continuously. Have had techs twice to check it out and both times they say it is fine. Any tips?...
The owners manual says
"CA" or "Cl" (Current Limit)
Is the washer overloaded?
Press STOP/CANCEL to clear the display.
Does it automatically do this when you start a load? Any further info you could give me would be helpful.
I hope this helps.
Ken
Mar 18, 2010 | Kenmore Washing Machines
Kenmore elite calypso top loader clothes still wet after spin
more than likely the machine has a bad clutch or motor.. in most cases it is cheaper to just buy another top loader.
Mar 06, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Calypso won't drain
CL or CA is an over amp draw most likely caused by the motor thermal protector or motor controller It can be caused by too large of a load try to press "STOP/CANCEL" to clear if the problem returns you will need to get inside the unit
Jul 09, 2008 | Washing Machines
The most likely thing to cause the code and the leak is the water pump. If the shaft seal on the pump leaks, the water gets into the drain pump motor and shorts it out. The code is telling you there is a high current/amp draw at one of the motors.
You can see if the pump is leaking by tilting the machine back, removing the screws that hold the bottom to the front edge of the machine and looking at the pump. If the pump is leaking, you will need a new pump and possibly a new motor control board.
Post back if you need further instructions and we will walk through the repair.
Nov 09, 2007 | Washing Machines
Kenmore Elite Oasis 27052 Top Load Washer Logo
146 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
