Question about GE GSH22KGR Side by Side Refrigerator
Thermo-Rigid walk in cooler for flowers is not cool enough,Help
The condensor was replaced 3 yrs ago.the temp should be around 35 degrees for flowers and it will not cool off under 45-50.Please help me
SOURCE: Ge Side by Side not cooling
check the freezer panel in the back for frosty ice build-up. is the freezer evaporator fan running?
Posted on Aug 04, 2008
  • 531 Answers
SOURCE: Freezer is not cooling
you may have defrost problem chech and see if you have ice build up back wall of freezer
Posted on Apr 06, 2009
rockitman187
  • 2559 Answers
SOURCE: TRUE COOLER COMPRESSOR CYCLES ON 45 SECONDS AND OFF FOR 2 MIN.
The unit has a temperature swing adjustment screw located behind the thermostat plate.If you remove the knob and the face plate you will see it,It can be adjusted there.It may also be the thermostat bulb is going bad or touching something and giving a false signal to the compressor.
Posted on May 03, 2009
  • 19 Answers
SOURCE: My GE Profile wine cooler temp does not respond to any temps
Call GE answer center 1-800-626-2000 ask for tech help,have Model # off data plate ready.
Posted on May 09, 2009
  • 306 Answers
SOURCE: Frost on back of freezer, not cooling right in both boxes
You probably have a defrost heater, timer, or temperature switch failure. The heater is the most common problem. What happens is frost has clogged the cooling coils and very little cold air is being circulated through it to do the cooling. Clean out the freezer and remove the back panel to thaw out with a hair drier or wet vac blower etc. Now find the cause. http://www.appliance411.com/faq/howdefrostworks.shtml
Posted on Jan 31, 2010
Danby DWC2727BLS temperature does not go lower than 60 degrees
am having the same problem, and same circumstance. Did you find a solution?
Jun 11, 2012 | Danby Silhouette® DWC276BLS Wine Cooler
I have a sullair ls - 120 we have been having problems with it getting hot and shuting off oil levels have been fine we have tryed different oil types we have took apart the unloader valve cleaned it and...
Get yourself a temperature gun and check a couple things:
1) Measure the oil injection temperature to the airend. This is a line going into the bottom side of the airend. 2) Measure the discharge temperature from the airend (this should be the same reading as the temperature gauge/readout on the compressor, but check to be sure)
You should get a temperature rise of about 25-30 degrees F over the airend. If you have more rise, you probably have an oil restriction: try an oil filter change.
If your oil injection temp is more than 160 degrees F or so, check the operation of the thermostatic valve. The thermo valve is a T shaped valve in the oil circuit. The oil line out of the bottom of the sump probably goes to a tee which splits flow to the cooler and the thermo valve. The oil goes through the cooler then to the other side of the thermo valve. The thermo valve should then mix the hot oil from the sump and the cool oil from the cooler to maintain the injection temp in the 150-160 degree range.
If you have cool oil coming from the cooler (should be maybe 140 F or less, and the injection temp is high, the thermo valve is bad. You can get a thermostat kit from your vendor to repair. If you've replaced the cooler, this thermo valve is probably the problem.
Mar 30, 2011 | Air Tools & Compressors
Food compartment cools ok; bottom freezer doesn't.
the problem when a fridge needs a condensor fan is that it causes the unit to work harder there is a good chance that it cooked the sealed systm also might want to check the condensor for a clogg or dirty condensor.the temp around the unit ideally these are to be used in rooms of 65 to 96 degrees so if in garage can be hard to work well
Jun 03, 2010 | GE PDS22MBR Bottom Freezer Refrigerator
Refigerator is not cooling properly. Temp
Refrigerator or freezer is not cold enough check this part:
* Check the temperature setting
* Assure that there is enough room for air flow in the refrigerator or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condensor coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Mar 28, 2010 | GE Profile Stainless Bottom-Freezer...
I have had a GE Profile Artica Refer for 6 years and have nothing but problems. After 3 years, we had to have I think the mother board replaced because the refer would not cool....would run at 50 degrees...
The old style ice boxes used a mercury bulb switch that shut power on and off according to the desired temp. Not now brother. We decided that was not good enough so what brainiacs came up with were electronic monitoring. Sound familiar? A group of thermisters are placed around the icebox to monitor ambient temps. 177300d.jpgThese thermisters( thermostat resisters) change in resistance when temperatures change. The fancy control board relies on these suckers to give it good intel when to shut down cooling systems. You should consult your tech sheet to see if the ohms readings on each thermister is within 10% of specs.
Mar 20, 2010 | Refrigerators
Kenmore 253.74813404 not cold enough - ice cream soft - outside in garage - 35 - 65 degrees now - almost 5 yrs old - evap coil not frozen so it is defrosting - perhaps temp control ?
IS THE TEMP IN YOUR GARAGE ABOVE 40 DEG. THE THERMOSTAT WILL NOT CLOSE IF THE AMBIENT TEMP IT TOO LOW, OTHER THAN THAT IF ITS NOT RUNNING IT POSS. COLD CONTROL
Jan 13, 2010 | Kenmore Refrigerators
39 ltr engle fridge freezer wont shut off when at temp
hi,
the temp should be around 35-40 in the fresh side and below freezing in the freezer. If the probe is positioned wrong then it may not shut off. Does the probe need to be in the freezer compartment?If the freon level is wrong then the freezer may not get cold enough to shut down the control tstat. The low side pressure should be around 5 PSI.
thank you for using fixya,rate my answer
vijay
Oct 01, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Oven temp low. recalibrated up 35 degrees, 375
no you need to still recalibrate the unit if your using the baking style thermo they are famous for being off 75 degrees
Aug 09, 2009 | Kitchen Ranges
Avanti N252BG beverage cooler does not get cold enough
Brand new installed avanti beverage cooler. In a basement undercounter so room temp. around 65 degrees. Only gets to around 45 degrees inside even though temp is set to 34 degrees. Most of the time it sits for days without being opened but still not cold. Any suggestions on how to fix this problem?
Mar 26, 2009 | Avanti N252BG Beverage Cooler
Kenmore side-by-side with thermo switch problem?
Acting like a bad thermostat, One thing to check is make sure compressor isnt overheating. If really hot you could have a relay problem on compressor.
Jan 05, 2008 | Refrigerators
GE GSH22KGR Side by Side Refrigerator Logo
270 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
