Question about Music
Distortion stopped working
The distortion stopped working on my amp.
  • Michial Gueffroy May 11, 2010
    Can you please tell me what brand and model of amplifier it is? I have schematics for lots of different ones and access to more.
  • 73 Answers
Hi there. Check the foot switch. Plugged in all the way? Still not working? Use an ohm meter to check the foot switch. (unplug from amp and check for continuity across the plug. click switch on and off.) If alway open (no continuity) bad switch.
Thanks
Paul
Posted on Jul 11, 2009
Marshall Amplification Marshall MG2FX Guitar Combo Amp power turns on but no sound
Hi!
At this point, I would just take it to a tech rather than poke around in it. It sounds like the power section is the problem as you have guessed, but without the technical knowledge you'd be shooting in the dark. That particular amp is right on the line of being expensive enough that would be worth repairing, but you might do just as wel to check Ebay for another used one.
Good Luck!
May 21, 2014 | Marshall Amplification Marshall MG2FX...
Hey my Pyle pro heavy metal distortion peddle isn't working. Everythings fine until I switch to distortion, than no sound comes from my amp. Any suggestions?
Check the switch to see if it is functional with an ohm meter. Also check length of plug and make sure it engages the jack securely as there are about 5 different lengths of 1/4 inch jack available. Are the effects powered by battery or through the amp, or on thier own power?
Jan 27, 2012 | Music
When i plug an MXR micro amp (volume boost) in front of the supersonic, it works on the clean channel but does not affect the burn channel, Why? By the way, when plug in to the effect loop it does work...
DO NOT USE a guitar pedal in effects loop as it has the WRONG signal levels.
Also, when you boost the gain preceeding a distortion setting in an amp, the amp will just limit out and it will appear that the effects in the amp aren't working... but what is happening is you wind up with too much input signal and the "flat topping" distortion occurs right at the inout of the amp so no further can occur when you select a distortion in the amp.
Jun 22, 2011 | Fender SuperSonic 22 22W 1x12 Tube Guitar...
My ltd deluxe ec-1000(vintage black) is not producing any distortion on my Marshall mg100hdfx. this is the first time i have had an active pickup guitar, i put a new 9v battery in it but still no change in...
Distortion is not produced in the guitar. Distortion is generated in the amp by circuitry that increses the gain until the waveforms "flat top". This creates higher harmonics and a buzzy sound. If you are getting a very low output from your guitar it is possible that you don't have enough output to get the distortion in the amp to work. Other settings in the guitar add harmonics by mixing more than one pickup. This is not ditortion but adding these harmonics changes the sound immensly.
LOOK AT THIS SITE AND FIND A SCHEMATIC THAT MATCHES THE RESOURCES OF YOUR GUITAR... You might be able to figure where the wire goes... It may be a ground.
http://www.guitarelectronics.com/c=D65u46R1H9tko6CKpPLsjBhiJ/category/wiring_resources_guitar_wiring_diagrams/
Apr 24, 2011 | ESP Ec 1000 Ltd Deluxe Electric Guitar In...
My hot rod deluxe has internal distortion problems.
There are many components in the system. Electrolytic capacitors are most suspect. C49, C50, C45, C51
There are many others but these are top suspects. You MAY be able to detect a change by cooling these components with circuit cooler spray.
ALSO check the +/- 16 volt power sources in the unit.
Jul 08, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Will this amp have metal distortion if i add a distortion pedal
The amp can accept most anything you can get out of a distortion pedal. If you play it too loud you can damage any amp.
I would HIGHLY recommend you either take your amp to the store where you are buying your pedal and try it with your guitar before buying.
ALSO don't forget to get a power adapter as the pedals "eat: batteries.
May 02, 2010 | Fender Frontman 65R 65W 1x12 Guitar Combo...
My amp has 2 channels, clean and distortion. distortion works, but the clean channel doesnt. When i hit the button, it switches the distortion off, but there is no sound. The distortion light stays on...
initially you want to think bad solder joint, but it think its a bad mosfet or rectifier or diode. it would be hard for an untrained person to identify your problem let alone an experienced tech. it may be time to move on to another amp. in my shop it would be at least 65 bucks for the repair. so where did the "heat"/energy go from that point and what parts were affected. there may be a domino affect. burn one part, not usually.
yostamplifier.com
Jan 17, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
My BOSS Distortion(DS-1) pedal buzzes whenever the distortion is up. I've changed the battery, outlet, and amp, but it continues to sound. I tried a different pedal, and it worked fine. How can I stop it...
This sounds like a broken ground wire or trace within the unit if an IDENTICAL pedal does not act the same AT THE SAME SETTINGS.
Sometimes a circuit trace gets broken on the board inside pedals and can cause this.
Since an identical pedal doesn't have the problem, service is required.
If you know electronics you can open the pedal and look for obvious problems.
HINT: Use a bright LED penlight to "candle" the circuit board to look for cracks.
Look for broken solder joints... this can take an experienced eye to spot.
A distortion pedal NORMALLY is very simple circuitry.
Nov 08, 2009 | Boss Music
How to set up with amp and distortion pedal
With everything switched off. I will surmise that you are using the onboard battery with the foot pedal and not a power supply.
1. Plug lead from guitar/instrument into INPUT side of pedal
2. Plug lead from OUTPUT side of pedal into amplifier INPUT.
3. Turn amplifier volume to about 10 o'clock - to stop blowing your ears out.
4. Turn volume up on guitar to acceptable level.
5. press foot switch on pedal and adjust pedal controls to suit your type of distortion.
6. Play like Hendrix.
Good Luck
ps Just as an after thought rechargeable 9volt batteries are the way to go. I've been using them for years as I always get caught up in the power cable.
If you're going to add another pedal like a Phaser, Compressor, Flanger or what just use small connect leads between each pedal but always, always put the compressor pedal last in the line.
Sep 12, 2009 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
Distortion stoped working on my amp
Hi there. Sounds like the distortion foot switch is stuck. Try a shot of WD-40 where the button goes into the switch and then click it on and off a bunch of times.
Thanks
Paul
May 28, 2009 | Music
Music Logo
140 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
