Question about LaCie (300728U) 250 GB Hard Drive
Dead 500GB HDD fix?
Hello, any one know how i can go about fixing a 500gb External HDD it just stoped working randomly a few months ago i tryed changing the case but dident work fan inside the actual HDD makes strange noice is there any way i could take apart the HDD and maby get the fan inside working or something like that? As i would rly like the data which is on the HDD? Any ideas thanks.
  • Matt Marley Oct 22, 2007
    No point Taking it to a professional as it would cost more than getting brand new 1TB External HDD
    Novelist:
    Champion:
  • 382 Answers
If you open that drive, you will destroy it. Those drive are airsealed, and are manufactered in a sterile environment. You will need to seek out professional recovery.
http://www.drivesavers.com/
Hope this helps.
Posted on Oct 21, 2007
  • 2 more comments
  • Keith Seekwhensir
    Keith Seekwhensir Oct 22, 2007
    Right, it de[pends on what it crucial.. the drive or the content. But i would not cut corners on big drive with inferior enclosures...whats a half TB drive when it fails and is unrecoverable......I recovered drives and switch enclosure on drive for whoms peoples career mattered. So it comes down again to the content or the drive. Instead of purchasing a 1 TB drive, try 2 500 GB drive, and use one to back up the other. In the intimidating world of RAIDS, cheap bridge boards and inferior backup software.......backing up has always been the first and berst preventative measure....
    Hope this helps, and don't forget to rate the advice.
  • Keith Seekwhensir
    The delivery above is the result of troubleshooting in the morning with no coffee......
  • Keith Seekwhensir
    Hey,
    Thanks lots for the rating......it's not like I didn't spends a good amount of time giving real advice, or that I was the cause of your malfunction. You even got an answer same day, 4 for that matter. I see why people give up on this site after a while. Not to mention your only advice was for someone to use the product warranty......if that's what you call a solution, then that figures.....again thank you for negative score.......i'll remember who was my first.
  • Keith Seekwhensir
    Oh and by the way, those drives dont have fans in them. But, I've already wasted enough time, I won't go into it.
SOURCE:
I have a seagate Freeagent Go 500gb and suddenly it is not recognized by my laptop.
Try with another PC, If still not recognising, then You have to open the Casing of your external drive. If you have any Warrenty remaining for this Drive, then let company people fix this. if no warrenty then Remove the HDD from the casing, Connect HDD to the PC with another External casing, and backup your Data. If no ditection with this method, then your HDD is Dead. Keep finger crossed best of luck
Feb 01, 2011 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
5OOGB TRANSCEND USB DEVICE NOT RECOGNIZING
have you tried on another computer? (computer necessarily 100% working and clean of viruses)
if the same problem repeatedly, trying to change the usb cable on your trancend.
if still reached a dead end, get an external cassing, make sure that you get is 100% working.
put you TRANSCEND 500GB hdd into another cassing.
good luck
Oct 19, 2010 | Transcend StoreJet 25 Mobile 500GB USB 20...
Suddenly stopped working
i think your hdd is dead,Because your hdd light not even turn's on....
Apr 09, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Ineed to know what power supply the mdhd500-ue hard uses
I presume you are trying to fix that unit. i suggest you remove the hard drive (if you already have it open and it isn't under warrenty). hook it up to your desktop computer as a spare drive and see if your computer recognizes it.
Sep 16, 2009 | Iomega HDD External Desktop (32660) 80 GB...
Freecom Classic 500GB External HDD Power Problemo
Hello and Welcome to FixYa!
Grab the solder gun and get started. No problem at all. Just replace the power button and your hard drive is perfect again. Only do this if you can have soldered anything previously. Try a matching button so that it may fix in the proper position.
Dont hesitate to comment if you have any other question.
Kindly rate me if i was helpful.
Regards,
Waqar
Sep 03, 2009 | Computers & Internet
Device i/o error on 500gb external usb hard drive, less than 6 mo
perhaps this? http://www.lacie.com/us/support/support_manifest.htm?id=10253&guideid=10167
Apr 01, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Is my LaCie External USB 2.0 500GB fried/dead???
You're not missing any step at all, because with SATA hard drive if its really working your computer should
automatically detect it and since this hard drive suddenly stop working there's a possibility that its already
fried but if you want you can try this hard drive again to a different computer and if still not detected by
second computer its already dead.........
Nov 07, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Seagate 500 external hardrive
It could be that the PCB or the connection within the external casing has a problem.
Try disassembling it and putting the Hard Disk into another external case to see if the disk is okay, if it is then viola! you have your data back.
Jan 14, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
LaCie 500GB external HDD stoped working ?
It sounds like its an internal problem with the pcb board inside,which may not be an actual problem with the hdd it self but the mother board.my advice would be to change the board that links between the hdd and the usb cable.
Jul 19, 2007 | LaCie (300728U) 250 GB Hard Drive
LaCie (300728U) 250 GB Hard Drive Logo
133 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
