Question about Sharp AR-164 Copier
Prints are only at 80%
Printer is set to print out 8 1/2 x 11 copies but, only prints out 80 % of copy.
    Scholar:
  • 95 Answers
Make sure your paper is not set to "ltr-r"or "letter r" which is the same size paper, just turned the other way. The control panel should show you the paper size its set for, or you can turn the original sideways if the platen/target glass allows for this size. This machine is a digital copier, so it should be able to turn it the proper direction unless its programmed for "ltr-r" copying.
Posted on May 26, 2009
My xerox 6015 will print documents that I have previously printed even tho I am not requesting it to be printed. Nothing is in the print queue to cancel. what is wrong with it?
I assuming you mean you get 2 prints when you only asked for one. Looks like the driver default settings are set to 2 copies.
If you can use the copy facility and print one copy that sort of eliminates the printer. The problem must be further up stream towards the computer sending the print.
You also. If he like to remove the print driver and reinstall it, the default must always be set to 1 copy.
Feb 21, 2015 | Xerox Workcentre 6015/Ni Color Laser...
Is there a way to print dual receipts so I can give customer their copy and I'll have a copy also.
Probably you should use a printer that uses 2 or 3 part paper so that when you print, the receipt will have a copy. Look for a printer like Epson MX 80. That should solve your problem
Oct 08, 2014 | Computers & Internet
When I print a one page document, tray 1 prints on multiple papers at a time. 1 page prints on 5 pages.
If you don't have a manual, you can find one here
My guess is either on the printer or the driver. Skimming the manual, it doesn't seem that you can set the default number of pages printed per sent print job on the printer, but that is something I would look into. This is a nice office printer, perhaps the printer is set to print multiple copies of everything it is sent. You could determine if it is the printer or driver/computer by printing to it from another computer.
If it is the computer, go into the control panel and select the properties for this printer. In there, check if the number of copies is improperly set to 5. This would happen for every print job sent from this system.
Does it print 5 copies of documents sent from different programs (i.e. Web Page, Word, Excel)? Quite possibly, one time you set it to print 5 copies and that application retained that as default. In that application, rather than clicking "print" click "printer setup" and look through the settings to see if it is requesting multiple copies.
I am 95% sure one of these three solutions will solve your problem.
May 05, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
How to set a printer to print only 1 copy no matter what # is put
You cannot do it -- when you request '3' copies, the computer sends 3 times as much text & commands to the printer. So, the printer cannot tell when the 2nd and 3rd copy begins.
Sep 14, 2009 | HP LaserJet 1200 Printer
Printer is making 2 copies instead of the requested one
when you go to print a page, click page setup, and change setting for copy's from 2 to 1...shia
May 22, 2009 | HP Photosmart C4280 All-in-One InkJet...
Hp Photosmart C4100 series (copy 6) printer missing!
check you printer's properties settings
file, print, properteis or preferences
on the main/general tab
check that your set to
" printing all pages "
and not from-to ( this will only print so many )
hope this helps
Regards
Richard.
Apr 22, 2009 | Office Equipment & Supplies
Help printing out more then one copy
In the print dialog generally accessed through File -> Print... or Ctrl+P), set 'Number of copies:' to the number of copies you require.
Mar 30, 2009 | Lexmark X4270 All-In-One Printer
Trying to print multiple copies and only one copy prints
Hi, my name is Juanita and I will try to help you with your problem.
What kind of printer do you have? And when you say you can't print multiple copies, is it the problem with setting the number of copies in the print dialogue box, or is it the problem for printer settings?
For this problem, I contacted the Inti Prima Karya. It is a cheap printing solution for all your printing needs. It would be much cheaper to use their offset printing solution.
Nov 05, 2017 | HP DeskJet 6122 InkJet Printer
Getting more copies at once
In almost any windows application there is a command in the FILE dropdown menu that is labeled "Print..." It's usually right above "Print Preview". To print multiple copies click "File" then click "Print..." and you will get the following Windowa63a80c.jpg Just select the number of copies you want by clicking the up/down arrows where it says "Number of copies"
Dec 19, 2008 | Office Equipment & Supplies
My hp 1320 prints multiple copies instead of one copy
Go to "printers and faxes."
Right click on your printer and select "Printing preferences."
Select "Advanced" tab
Double click "paper output"
If "Copy count=2" then change to 1 and apply
IF IT ALREADY IS SET TO 1 THEN:
Set "copy count=2" then APPLY
Repeat the above and now set "copy count=1"
The process of setting and resetting the copy count fixed my issues.
Dec 03, 2008 | HP LaserJet 1320 Printer
Sharp AR-164 Copier Logo
67 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
