Question about Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer
Maytag Dryer What do I have to do to vent my dryer on the side instead of the back. There is a cut out on the side of the dryer for it.
  • 290 Answers
You can order a side vent kit for it or make one yourself. The kit has a couple of extensions and an elbow that will turn the exhaust out the knock out on the side. You can pick up everything you need at the hardware store but the kit has precut pieces and installation instructions. If it is not a big inconvienience to wait for it, I would recommend you order the kit through a maytag dealer or sears. That way you have the right pieces and instructions to follow.
Posted on Oct 21, 2007
  • Michael  Lindley
    Michael Lindley Oct 23, 2007
    Just wanted to follow up on your dryer and see if you need further assistance.
    Thanks/Mike
  • Michael  Lindley
    Michael Lindley Nov 08, 2007
    musigal
    Just wanted to see if you were able to install side vent.
    Thanks/Mike
MgDC300XW 4-venting options
read the manual, it could go out on sides and at the back
Mar 26, 2013 | Maytag MGDC300XW Gas Dryer
Maytag dryer is taking forever to dry clothes, can even smell bad while running? how do i clean it besides the lint catcher?
Make sure the vent is not clogged. Its in the bottom of back side. Typically vented outside. Also, verify your heater elements are working by running dryer with door open to check for heat
Jul 27, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Is it possible to re-configure the rear vent on a Bosch dryer
Most dryers have that option but not on the left side. You will need to cut a hole in the left side dryer housing. Then you will need to dis-assemble the back panel of the dryer and disconnect the vent pipe connection inside the dryer. Then run the moisture vent into the dryer housing from the left side opening and connect it to the venting system inside the dryer. You might not be able to put the opening in the same spot as the right side so you should do a visual inspection inside the dryer before making the opening to verify nothing is in the way.
Jan 22, 2010 | Bosch Dryers
How do i side vent my maytag atlantis electric dryer?
Attached is a link to a diagram of your dryer.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170653
You would have to remove the back panel. Remove the existing vent pipe, install a 90 deg elbow of the same size diameter. Then cut a hole in the right or left side of the dryer cabinet that would line up with the new elbow.
Check the side cabnet of your dryer, it appears on the diagram that there may be a 4" knock out for a side exit vent.
Good luck, let me know.
Regards,
Jul 21, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Does maytag make an electric dryer with bottom vent?
you want to vent of of the base of the dryer, directly down? None of the maytag/whirlpool line can handle this anymore. Only side vent options. GE may still be able to bottom vent. no dryer is really made for it out of the factory but some can be converted to it with a kit. usually if they can there will be a knock out panel for the duct in that place. GEs heater is on back wall making more room on the base for this kind of thing.
Jul 11, 2009 | LG DLG2525S Electric Dryer
Exhaust Need to install side exhaust on maytag dryer
There will be an indented area about 4 inches in diameter if your able to put one in easily. Other wise you'll need either a hole saw 4" or cut a hole in the side of the dryer but before you do make sure your inside piping will reach the new area you want to come from.
Another suggestion would be make a base for your dryer to set on 6 to 8" high cut a hole in the side of it and in the top where you can run the dryer hose through then continue on outside with the hose-vent.
If this helps you please rate me accordingly and good luck.
Mar 13, 2009 | Maytag Dryers
Dryer shuts off
Hi!!! You seem to have a bad timer on the dryer..Or your vent on the back of the dryer can be plugged and the thermal cut off switch in the dryer turns it off..Good luck//
Jan 02, 2009 | Maytag PYE2300AY Electric Dryer
Maytag performa model#pyg2300aww takes four cycles to dry
how long is dryer vent run ? does it go up or out to the side ? Sounds like the dryer vent is clogged. A long run on your vent will also cause this problem with a small amount of lint. Try cleaning out your lint screen on the dryer vent they can get pretty caked up with lint. If you have a long dryer vent run post back the length and direction and I will get you the maximum length for your specific run. You may need a booster fan if it is excessively long or straight up as through the roof.
Dec 29, 2008 | Maytag PYE2300AY Electric Dryer
Maytag performa dryer vent clogged and dryer stopped
I am not 100% sure I understand your question but if you need to know how to reassemble your dryer after cleaning it out,.use this link .. It has exploed views and parts lists .. http://www.pcappliancerepair.com/model-display.php
If my reply does not answer your question, please clarify your concern and I will assist you.
Regards,
Rick
Dec 01, 2008 | Maytag Performa PAV2200
Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer Logo
352 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
