Question about Mtd LAWN MOWER PART # 16998A DECK ASS'Y-21" RD
Ride on mower mtd will not start
Put new battery new selonode engine turns very slow as if the battery is flat
  • 420 Answers
Use a jumper cable from the battery to the post on the starter where the wire from the solonoid connects, if it spools up normal its the cable to the starter motor, if it continues to turn slow remove the starter and clean up the places where the starter and engine case contact each other (to ensure a good ground). If none of these solutions correct the issue the starter could be dragging and need to be replaced.
Posted on May 26, 2009
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
Yard man riding mower
By crossing the terminals on the solinoid you have taken this component out of the picture, so the problems has to be in the engine or the starter, if the auto deco valve in the engine is not working the engine will be sluggish to crank over.
Sep 28, 2013 | Mtd Garden
My' MTD riding mower will not start? the battery is fully change? but just will not started. when I check the oil? it was not good; it was very black, and the oil lever was very high above normal
can you rotate the engine by hand?try and bypass wiring and jump at the starter if ok they bypassing the safety switches and bypassing each battery cable
Apr 21, 2012 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Ride on mower drive problem
sounds like a belt to me not tight enough against the pullys
Nov 09, 2009 | Mtd Gold 42" Zero-Turn Mower -
I have a riding yard machine. It does not seem to
Sounds like the alternator under neath the flywheel has gone bad. This could happen from jumping the mower of a vehicle still running. The alternator on the vehicle puts out to much power for the mower and will damage or blow the alternator on the mower.
Sep 29, 2009 | Mtd Garden
Mtd riding mower model 13AT688H731 B&S 21HP
Did you change the voltage regulator???
Apr 20, 2009 | Garden
MTD riding lawn mower twine B@S
Is the air filter clean? Try a complete tuneup and have the battery load tested - new or not. Make sure all wire connections are clean and tight.
Mar 31, 2009 | Garden
Riding mower goes slow in forward speed
There is a variable speed pulley that is a double pulley....one belt from engine to pulley and one from pulley to transaxle....remove both belts...pushing in the clutch will help with removal....remove o ring on top of pulley and pull up......the middle piece of metal is stuck....this piece is meant to slide up and down.....put the middle piece of metal on your pulley in your vice...wd40 the hell out of the shaft on pulley .....grasp the top with one hand and the bottom with your other hand...work the stuck pulley free.....put lithium grease on shaft...reinstall....done
Mar 09, 2009 | Mtd Garden
Mtd LAWN MOWER PART # 16998A DECK ASS'Y-21" RD Logo
303 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
