Question about Garden
Engine shut off
I have a Craftsman GT5000 lawn tractor w/kohler 25hp v-twin engine, model# 917.276040. While mowing, the engine shut off as though i had turned the key off. Now it won't start or even turn over. There is no power to the lights either. What would you suggest I do...?
  • dtmblues May 26, 2009
    Thanks a heap. There's a new battery on it and the terminals are clean but i haven't checked the fuse yet. Any other sugestions if the fuse isn't the case...?
  • dtmblues May 27, 2009
    lights don't work. Fuse blows when ignition is turned on start. I suspected a short in the brake pedal saftey switch. I pulled the switch on the brake pedal and jumped the white and replaced the fuse. Turn the ignition and the fuse blew. I then jumped the black wires and tried again, the fuse blew again.
  • 284 Answers
Check your battery and connections for corrosion and clean and redue if needed
check fuses
Posted on May 26, 2009
  • panilling9
    panilling9 May 26, 2009
    do you lights work without the engine running?
    or does the engine have to be running and they brighten as the engine speed increases?
    Make sure your negative ground wire to the frame is tight from the battery
    keep in touch we will fix it with your feedback too.
What is the head bolt torque specs for a Kohler Pro 25HP V-Twin engine?
Go here and look up your engine model
Owners Service Manuals
Here is a Manual for the Kohler Command Pro CV26
http://www.kohlerengines.com/onlinecatalog/pdf/24_690_02_EN.pdf
The picture shows the torques of the Kohler Command Pro
Aug 19, 2014 | Craftsman Garden
Exmark 44
When you say 'going forwaed', is that while mowing or does it do it without the blades engaged or 'not mowing'?
Jun 13, 2013 | Kohler Engines NEW 25HP KOHLER ENGINE...
How do I wire a 18hp Briggs & Stratton engine to a craftsman GT5000 lawn mower
I dont have all your anwers. In my experience, Kohler frequently has wires to start, run and stop the engine. They also frequently have a low oil and/or high heat control (engine shut down). Also expect a wire from the charging system. On your tractor, you probably have similar plus 'operator presence' wires. These wires require to you to be sitting in the seat for the machine to operate - a seat switch for example. On my tractor, I can depress the 'brake' (which isnt exactly a brake in fact) and the engine will run when I dismount. However, if the mower is engaged, no matter what, if I get off the tractor, the engine shuts down.
You will have to determine what every wire is for and connect it properly. You may lose some engine 'functionality' or tractor safety features. It is never easy to put a Ford starter on a Chevy. Good luck with your project.
Thanks for your interest in FixYa.com
Dec 02, 2012 | Garden
My cub cadet 2165 PTO clutch has no voltage getting to it to activate it. the normally closed switch is ok. could it be the relay? how do I test it?
on my cub the blades keep shutting down when im mowing . I replace the pto switch and it doesnt help .. got a recommendation
Feb 03, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
I have a craftsman Dlt 3000 riding mower with a 20hp kohler v twin . engine starts and runs for 5 seconds and shuts off
no model # on my DLT3000. Replaced rear fender a few years ago where the model # used to be. I can't get the right parts w/o model #. It was by my dad sometime between '04 and '07. It's red w/42" cut, 20hp koler pro motor.
Sep 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Nov 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
175 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
