Question about Adidas Candy Digital watch
Light button causes the time to reset, why?
When i hit the light button time resets.
Your battery is low and needs to be replaced, the light uses much more power than it takes to run the display
Posted on May 26, 2009
How do I reset my watch time on a q-seven watch
All you have to do hold the "reset" button for about 10 secs. Then one-by-one the time, date, and seconds will and use the "ST/STP" button to change it. Then, you have everything set right, hit the "reset" button and that will finalize it.
Feb 25, 2015 | Watches
How to reset time on armani exchange ax1010?
Hold down the "set" button until the "light" ON flashes. This is the top left button. Next hit the mode button ( bottom left button). use the Mode button to cycle through all the options available to set. Use the reset button AND ONLY THE RESET BUTTON to change the selection. That means going from 2099 all the way down to 2012. Note to get PM as the time just cycle to the number you want again to see the A go to a P for PM. Lastly hit the Set button (again top left) to close the setup.
NOTE: If you hit any other buttons out of order during set up you will have to hit mode again until you reach the time setting. Wait a second and start the process again to finish any settings you missed.
Good Luck!
Apr 08, 2012 | Armani Exchange AX Black Polyurethane...
Cannot set time on my new Adidas Response ADP6005 watch. manual is useless in this regard
Just talked to Adidas. Manual is wrong on this watch type. To change time: press top-left button "set/light" and hold till "light off" appears. Then, hit bottom-left button "mode," toggling until you reach the hours/minutes/etc. Use top-right and bottom-right buttons to change numbers as needed. Hit top-left "set/light" button when finished.
Jun 16, 2011 | Watches
Need to change the time. turn off sound and alarms
For alarm:
Hit START and RESET (rightside buttons normally)
For hour chime:
Hit RESET and MODE (bottom left and right buttons normally)
(Hit the button listed first, then press the other while still holding it.)
Thats how it works on mine, worth a shot. :-)
Sep 14, 2009 | Freestyle Shark Classic Midsize...
Can't set time, etc. on Ottimo Billboard Solar watch.
I just picked up this watch.  Setting it is easy.  Hold down the button marked "RESET" (lower right) until the numbers start blinking.  Hit the "MODE" button (lower left) until the the settings you want to change are blinking.  Hit the "ST/STP" button (upper right) to change that setting.  Keep on hitting these two buttons until the settings are as you would like them.  Hit "RESET" button to finish.  So, to change just the day, I would hold down "RESET," hit "MODE" four times, hit "ST/STP" until the date is correct, hit "RESET" to save.
Dec 20, 2008 | Bulova Watch
GapKids Digital Watch - Need to know how to set
Light button is A
Mode button is B
Start button is C
Reset button is D
Standard Time Adjustment:
1) To set time, date, etc. press button B three times (assuming you start in standard time display mode)
2) Press button D until the area you'd like to change is flashing. (i.e.: minutes, date, day, etc.)
3) Press button C to change. Press once for one unit increment of change. Hold for 3 seconds for speedy advance.
4) Press D again until the next area you'd like to change is flashing.
5) At completion of changes press Button B to resume standard time display mode.
Nov 29, 2008 | Nike Triax Fly WK0006 009 Watch
Prospirit watch
in order to SHUT OFF THE ALARM:
go to the normal time setting, where nothing is flashing. then press and hold reset. then the time you want the alarm on shows up. in order to turn the alarm off press start...press start again to turn it on
May 15, 2008 | Watches
Setting Bench Watch
Reset Instructions Bench. (BC0013BR)
Time and Location
If you hold in the light, start and the reset button for a few seconds a screen will appear with the 12h or 24 h clock setting and also the date and country.
Once you have that screen if you press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time.
Once you have changed the date and time to the correct date press the light button, start button and reset button and it will save the settings.
Alarm
Hold in the light, start and the reset button for a few seconds a screen will appear
press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time. Use the light button to set the screen.
Feb 27, 2008 | Watches
Adidas Candy Digital  watch Logo
213 people viewed this question
Top Adidas Watches Experts
Ansel Alberto
Ansel Alberto
Geoff
Are you an Adidas Watch Expert? Answer questions, earn points and help others
